Home » Eclipse Projects » Target Management » Remote Shell Commands Not Executing(Pressing [Enter] does not execute commands)
Remote Shell Commands Not Executing [message #990904] Fri, 14 December 2012 18:57 Go to next message
Peter McCann is currently offline Peter McCannFriend
I can open a Remote Shell to both local and remote targets.
However, I cannot execute commands. I can type the command,
but when I press [Enter], the focus shifts to output window
and nothing happens.
My installation is Eclipse Juno SR1 (build ID 20121004-1855)
running on Windows 7 with the following additional packages:
Eclipse IDE for Java Developers
1.5.1.20121004-1506
epp.package.java
Remote System Explorer End-User Runtime
3.4.1.201209191030-7L7IFBY83omx__z0RFpKdWB-r5MS
org.eclipse.rse.feature.group
Eclipse TM Project
Remote System Explorer User Actions
1.1.400.201209191030-31FBV773573L5L5393
org.eclipse.rse.useractions.feature.group
Eclipse TM Project
Any idea what I'm doing wrong? Any way I can debug what the
problem is?
-Pete
Re: Remote Shell Commands Not Executing [message #991058 is a reply to message #990904] Mon, 17 December 2012 08:53 Go to previous messageGo to next message
Martin Oberhuber is currently offline Martin OberhuberFriend
What connection type are you using ?
- If using SSH, please try the Terminals subsystem rather than remote shell.
Re: Remote Shell Commands Not Executing [message #991144 is a reply to message #991058] Mon, 17 December 2012 13:51 Go to previous messageGo to next message
The problem happens when I am using a Local Shell or a
Dstore connection to a remote machine. I have not used
the SSH connection type yet.
-Pete
Re: Remote Shell Commands Not Executing [message #991175 is a reply to message #991144] Mon, 17 December 2012 15:34 Go to previous message
David McKnight is currently offline David McKnightFriend
I think in the most recent builds of Eclipse, the key events have changed.
It used to be that up key events would contain the "enter" key but now it
seems to have changed to the down key events.
I've opened the following bugzilla for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=396766
"Peter McCann" <forums-noreply@xxxxxxxx> wrote in message
news:kan813$rsg$1@xxxxxxxxe.org...
> -Pete
Previous Topic:Analyzing core dumps
Next Topic:Project deployment over FTP
Current Time: Tue Apr 24 03:17:29 GMT 2018
Powered by FUDForum. Page generated in 0.02043 seconds
