| Running ExternalTools headless [message #990545] |
Wed, 12 December 2012 19:41  |
Philip Bedingfield Messages: 26 Registered: August 2011 |
Junior Member |
Is this possible?
I've read that I need this 'org.eclipse.core.externaltools' plugin. I managed to intall it by installing the 'org.eclipse.platform' feature but it fails when I run it because it's trying to activate "org.eclipse.debug.ui"
Any help appriciated.
ERROR: An error occurred while automatically activating bundle org.eclipse.debug.ui (142).
org.osgi.framework.BundleException: Exception in org.eclipse.debug.internal.ui.DebugUIPlugin.start() of bundle org.eclipse.debug.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:463)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.debug.core.DebugPlugin.getStatusHandler(DebugPlugin.java:584)
at org.eclipse.debug.core.model.LaunchConfigurationDelegate.saveBeforeLaunch(LaunchConfigurationDelegate.java:252)
at org.eclipse.ant.internal.launching.launchConfigurations.AntLaunchDelegate.saveBeforeLaunch(AntLaunchDelegate.java:868)
at org.eclipse.debug.core.model.LaunchConfigurationDelegate.preLaunchCheck(LaunchConfigurationDelegate.java:208)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:809)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:696)
at org.eclipse.buckminster.core.commands.Launch.internalRun(Launch.java:209)
at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(WorkspaceCommand.java:91)
at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(AbstractCommand.java:200)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:350)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:145)
at org.eclipse.buckminster.cmdline.Headless.start(Headless.java:165)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.IllegalStateException: Workbench has not been created yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
at org.eclipse.debug.internal.ui.contextlaunching.LaunchingResourceManager.startup(LaunchingResourceManager.java:546)
at org.eclipse.debug.internal.ui.DebugUIPlugin.getLaunchingResourceManager(DebugUIPlugin.java:315)
at org.eclipse.debug.internal.ui.DebugUIPlugin.start(DebugUIPlugin.java:516)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 47 more
| Re: Running ExternalTools headless [message #990710 is a reply to message #990545] |
Thu, 13 December 2012 03:49   |
Lorenzo Bettini Messages: 1119 Registered: July 2009 |
Hi Philip
in this plugin, part of my project,
http://sourceforge.net/p/xsemantics/code/ci/master/tree/examples/it.xsemantics.xsemantics.ui.examples/
I have a build.xml which basically creates some zips, and I have the
corresponding
org.eclipse.buckminster.ant.AntBuilder
in the .project
with that, an headless build automatically calls the ant targets (and in
this case it creates the zips).
Is that what you would need?
as for features installed in headless buckminster I only use these ones
org.eclipse.buckminster.cmdline.product
org.eclipse.buckminster.core.headless.feature.feature.group
org.eclipse.buckminster.pde.headless.feature.feature.group
hope it helps
cheers
Lorenzo
On 12/13/2012 01:41 AM, Philip Bedingfield wrote:
> Is this possible?
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> created yet.
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 47 more
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
FUDForum. Page generated in 0.01601 seconds
