| dealing with Papyrus's files [message #990508] |
Wed, 12 December 2012 14:52  |
chriss matt Messages: 3 Registered: December 2012 |
Junior Member |
Hello all
i'd like to ask about adding attributes and operations to xml file of UML class diagram(one attribute and one operation for each class)and then reverse them to graphical as viewed in *.di
My question is :the addition operation should be on *.uml and *.anotation?or this need other transformations before adding those stuffs?
Remark:i use JDOM for editing XML file
Greetings
Chriss
| Re: dealing with Papyrus's files [message #990576 is a reply to message #990508] |
Thu, 13 December 2012 04:31   |
Camille Letavernier Messages: 224 Registered: February 2011 |
Hello Chriss,
The UML file contains all the semantic information of your model.
The Notation file contains the diagrams.
The DI file contains information about the available editors (e.g. diagrams, tables, ...), and their layout.
So, in your case, you only need to edit the *.uml file, then reverse it to generate the changes in your *.notation file.
If the diagram already exists, you don't have to edit the *.di file.
Camille
| Re: dealing with Papyrus's files [message #990713 is a reply to message #990508] |
Wed, 12 December 2012 15:40   |
Christian W. Damus Messages: 550 Registered: July 2009 |
Hi, Chriss,
Rather than use JDOM, you really should be using the Eclipse UML API to
modify the contents of a UML model. It will be difficult, in general,
to ensure the correct structure of a UML model using JDOM.
Using the UML API, it is as easy as asking a Class to
createOwnedAttribute(...) and createOwnedOperation(...) . The diagram
should automatically present the new attribute and operation of each
class, so you shouldn't have to modify the *.notation file.
HTH,
Christian
On 2012-12-12 20:34:36 +0000, chriss matt said:
> Hello all
> stuffs?
> Greetings
> Chriss
| Re: dealing with Papyrus's files [message #990769 is a reply to message #990688] |
Fri, 14 December 2012 03:25   |
Hello Chriss, Hello Christian,
> The diagram
Actually, in Papyrus, the diagrams only display a subset of the model. If you create a new Operation/Property in the semantic model (i.e. using Class#createOwnedAttribute), they won't appear in the diagram, until you explicitly add them.
> ii- Please clarify this sentence:
> "If the diagram already exists, you don't have to edit the *.di file"
The *.di file contains links to all existing "pages", i.e. nested editor. If you create a new diagram, it needs to be known by the *.di model. But if you modify an already-existing diagram, you won't have anything to do in the *.di model.
Camille
| Re: dealing with Papyrus's files [message #997664 is a reply to message #990916] |
Mon, 07 January 2013 10:33  |
Hi, Chriss,
On 2012-12-14 20:48:31 +0000, chriss matt said:
> Hello Christian, Hello Camille
> thank you for the fruitful discussion.
> i-in the case of using Eclipse UML API instead of jdom , so, performing
> modifications on UML file reflected in other files?in other words, the
> other files automatically will updated?only adding them explicitly(drag
> and drop)is required ?
No, sorry, this was a misunderstanding on my part, corrected by
Camille. I had thought that the attribute and operation compartments
in Papyrus class diagrams use a "canonical edit policy" as in Ecore
Tools diagrams. That's not the case. So, the Eclipse UML API helps to
construct structurally sound models (which is considerably more
complicated than you might expect) and Papyrus/GMF provides the API
required to update the notation model (diagrams) to visualize new
elements that you add to the UML content.
> ii-Do Eclipse UML API supports the operations of different kind of
> model elements and applying standard and user-defined profile?
The Eclipse UML API provides complete coverage of the entire UML
metamodel, including working with profiles and stereotypes. The
"getting started" articles on the Wiki should help:
http://wiki.eclipse.org/MDT-UML2#Articles
> iii-Where I can find examples of using the Eclipse UML API and from
> where I can download the latest version of it?
The Eclipse UML2 SDK is available for installation from the Eclipse
simultaneous release update site along with most other Eclipse modeling
projects. If you need it for non-Eclipse deployment, you can download
the latest releases here:
http://www.eclipse.org/modeling/mdt/downloads/?project=uml2
> Greetings
> Chriss
FUDForum. Page generated in 0.01627 seconds
