Home » Newcomers » Newcomers » Eclipse custom view fades out when switched to another view and returned to the old view.(Eclipse plugin development - custom views)
icon8.gif  Eclipse custom view fades out when switched to another view and returned to the old view. [message #989990] Mon, 10 December 2012 11:14
Abdul Rehman Shaik is currently offline Abdul Rehman ShaikFriend
In my custom created view if I switch to another view and comeback, my view is faded out (the the view has two tabs which will be visible but the composite inside the tab all turns white). Looks like view rendering issue. Need some suggestions badly! Below is the stack trace:
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. com.sap.ndb.studio.modeling.tools.actionSet
at org.eclipse.core.commands.contexts.Context.getParentId(Context.java:201)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.getLevel(ContextSet.java:48)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:38)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:1)
at java.util.Arrays.mergeSort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at java.util.Collections.sort(Unknown Source)
at org.eclipse.e4.ui.bindings.internal.ContextSet.<init>(ContextSet.java:76)
at org.eclipse.e4.ui.bindings.internal.BindingTableManager.createContextSet(BindingTableManager.java:90)
at org.eclipse.e4.ui.bindings.internal.BindingServiceImpl.setContextIds(BindingServiceImpl.java:236)
at sun.reflect.GeneratedMethodAccessor8.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:88)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:318)
at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:332)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activate(EclipseContext.java:630)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activateBranch(EclipseContext.java:635)
at org.eclipse.e4.ui.internal.workbench.PartActivationHistory.activate(PartActivationHistory.java:52)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:561)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:532)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java:2836)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2417)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:5152)
at org.eclipse.swt.widgets.Tree.WM_SETFOCUS(Tree.java:7064)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4598)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5958)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:1098)
at org.eclipse.swt.widgets.Control.setFocus(Control.java:3303)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:1040)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:1038)
at org.eclipse.ui.part.PageBookView.setFocus(PageBookView.java:881)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.delegateSetFocus(CompatibilityPart.java:178)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:235)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:206)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:106)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$2.setFocus(ContributedPartRenderer.java:101)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer$9.mouseUp(StackRenderer.java:941)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:220)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Previous Topic:Eclipse stability
Next Topic:resizing of graphical layout
Current Time: Thu May 24 18:04:44 GMT 2018
Powered by FUDForum. Page generated in 0.02941 seconds
