Home » Eclipse Projects » BIRT » birt parameter dialogue do not display for all the report in the customer production site(birt parameter dialogue do not display for all the report in the customer production site)
birt parameter dialogue do not display for all the report in the customer production site [message #989757] Fri, 07 December 2012 15:35 Go to next message
steven chen is currently offline steven chenFriend
the story is as below for your reference:
one of our customers are using our birt report solution(2.6.2). after the jboss has been running for a while, all the report could not be accessed 'cause the parameter diglogue just does not show up and the report could not continue since after. Only after restarting the related JVM , it goes back to normal. Could you help to show me how to troubleshoot this issue? all the CPU/Mem/Threadss(JVM and OS) were working fine.
Steven
[Updated on: Mon, 10 December 2012 04:59]
Report message to a moderator
Re: birt parameter dialogue do not display for all the report in the customer production site [message #989822 is a reply to message #989757] Sat, 08 December 2012 02:50 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
I've not heard of this happening before. Do you access by URL? If so, you can add the __parameterpage=true parameter to the url and see if it helps.
Michael
Developer Evangelist, Silanis
Re: birt parameter dialogue do not display for all the report in the customer production site [message #989831 is a reply to message #989822] Sat, 08 December 2012 05:58 Go to previous messageGo to next message
Hi, Micheal
Thanks for your tips. I tried,i.e.,<IP:port/scereports/frameset?__report=report/ZTE_***2.rptdesign&poptions=l&__parameterpage=true> but without anythingreceived in the returned page.
So i just want to trace the related servelets to troubleshooting this issue. Could you help to share some skills regarding this or any other ways to find the root cause?
Steven
Re: birt parameter dialogue do not display for all the report in the customer production site [message #989857 is a reply to message #989831] Sat, 08 December 2012 15:09 Go to previous messageGo to next message
I wonder if this is related to the memory leak issue that was in 2.6.2. Do you get any errors or anything? Have you checked the log files? Is there any way you can upgrade your BIRT runtime version? You also might try just redownloading the viewer/runtime.
Michael
[Updated on: Sat, 08 December 2012 15:10]
Re: birt parameter dialogue do not display for all the report in the customer production site [message #989922 is a reply to message #989857] Mon, 10 December 2012 04:32 Go to previous messageGo to next message
Hi, Micheal
Here is the birt runtime error flooding within the log file and the related java file could be found here @h-t-t-p-:-/-/opensourcejavaphp.net/java/birt/org/eclipse/birt/data/engine/odaconsumer/ParameterMetaData.java.html.
Also wonder any bug with the JDBC(ojdbc.jar) version which could impact the birt viewer? our customer is using ojdbc6.jar with oracle 11g RAC.
I found a bug mentioned the above, h-t-t-p-s://bugs.eclipse.org/bugs/show_bug.cgi?id=384925
2012-: Cannot get the type for parameter: 1.ine.odaconsumer.ParameterMetaData getRuntimeParameterType
ä¸¥é‡ at sun.reflect.NativeMethodAccessorIm
org.eclipse.biræ"¯æŒçš„特性oda.jdbc.JDBCException: Cannot get parameter type.
SQL error #1:ä¸reflect.Delegati
; æ"¯æŒçš„特性
java.sql.SQLException: ä¸oviders.java.RPC
at org.eclipse.birt.report.data.oda.jdbc.ParameterMetaData.getParameterType(ParameterMetaData.java:159)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaParameterMetaData.getParameterType(OdaParameterMetaData.java:177)
at org.eclipse.birt.data.engine.odaconsumer.ParameterMetaData.getRuntimeParameterType(ParameterMetaData.java:233)
at org.eclipse.birt.data.engine.odaconsumer.ParameterMetaData.<init>(ParameterMetaData.java:97)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.mergeParamHintsWithMetaData(PreparedStatement.java:1674)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getParameterMetaData(PreparedStatement.java:1525)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getParameterMetaData(PreparedStatement.java:1539)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getParameterType(PreparedStatement.java:798)
[Updated on: Mon, 10 December 2012 06:31]
Re: birt parameter dialogue do not display for all the report in the customer production site [message #989923 is a reply to message #989922] Mon, 10 December 2012 04:33 Go to previous messageGo to next message
Also here is the tomcat information for your reference:
JVM
Free memory: 2524.23 MB
Total memory: 4063.00 MB
Max memory: 4063.00 MB
ajp-***%2F10.30.9.170-8209
Max threads: 200
Current thread count: 0
Current thread busy: 0
Max processing time: 0 ms
Processing time: 0.0 s
Request count: 0
Error count: 0
Bytes received: 0.00 MB
Bytes sent: 0.00 MB
ajp-***%2F10.*.*.*-8209
Stage Time B Sent B Received Client V. Host Request
P: Parse and prepare request S: Service F: Finishing R: Ready K: Keepalive
http-wms%2F10.30.9.170-8280
Max threads: 200
Current thread count: 44
Current thread busy: 8
Max processing time: 195569 ms
Processing time: 4797.107 s
Request count: 13988
Error count: 2086
Bytes received: 1.66 MB
Bytes sent: 133.07 MB
http-wms%2F10.*.*.*-8280
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
K 14301 ms ? ? 10.*.*.11 ? ?
K 14303 ms ? ? 10.*.*.11 ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
K 4415 ms ? ? 10.*.*.* ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
S 31 ms 0 KB 0 KB 10.*.*.* 10.*.*.* GET /status?full=true HTTP/1.1
R ? ? ? ? ? ?
R ? ? ? ? ? ?
K 14307 ms ? ? 10.*.*.* ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
K 14306 ms ? ? 10.*.*.* ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
R ? ? ? ? ? ?
S 3763 ms 0 KB 1 KB 10.18.167.11 ***POST /scereports/frameset?__report=report%2Fbilling%2FZTE_StoreIssueQuery_V2.rptdesign&__showtitle=false&__timezone=Asia%2FHong_Kong&__locale=zh_CN&__offsetMin=0&__sessionId=20121210_042631_261 HTTP/1.1
R ? ? ? ? ? ?
P: Parse and prepare request S: Service F: Finishing R: Ready K: Keepalive localhost/
Start time: Mon Dec 10 02:20:22 UTC 2012
Startup time: 2 ms
TLD scan time: 0 ms
Active sessions: 0
Session count: 0
Max active sessions: 0
Rejected session creations: 0
Expired sessions: 0
Longest session alive time: 0 s
Average session alive time: 0 s
Processing time: 3 ms
JSPs loaded: 0
JSPs reloaded: 0
Status Servlet [ /status ]
Max time: 0 ms
Request count: 1
Error count: 0
Load time: 21 ms
Classloading time: 9 ms
default [ / ]
Processing time: 0.0010 s
Max time: 1 ms
Request count: 4
Error count: 0
Load time: 1 ms
Classloading time: 1 ms
jsp [ *.jsp , *.jspx ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
Classloading time: 0 ms
localhost/admin-console
Startup time: 7 ms
TLD scan time: 2 ms
Active sessions: 0
Session count: 0
Expired sessions: 0
Processing time: 1 ms
JSPs loaded: 0
JSPs reloaded: 0
Faces Servlet [ *.seam ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 1 ms
default [ / ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
localhost/jmx-console
Startup time: 2 ms
TLD scan time: 0 ms
Active sessions: 0
Session count: 0
Expired sessions: 0
Processing time: 0 ms
JSPs loaded: 0
JSPs reloaded: 0
DisplayOpResult [ /DisplayOpResult ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 1 ms
DisplayMBeans [ /DisplayMBeans ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
HtmlAdaptor [ /HtmlAdaptor ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
ProfileServiceDebugServlet [ /ProfileServiceDebugServlet ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 1 ms
ClusteredConsoleServlet [ /cluster/ClusteredConsole ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
default [ / ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
ClusterView
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
InspectMBean [ /InspectMBean ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 1 ms
localhost/invoker
Start time: Mon Dec 10 02:20:18 UTC 2012
Startup time: 4 ms
TLD scan time: 1 ms
Active sessions: 0
Session count: 0
Expired sessions: 0
JSPs loaded: 0
JSPs reloaded: 0
default [ / ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
EJBInvokerServlet [ /EJBInvokerServlet/* ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 2 ms
JMXInvokerServlet [ /JMXInvokerServlet/* , /readonly/JMXInvokerServlet/* , /restricted/JMXInvokerServlet/* ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
ReadOnlyJNDIFactory [ /ReadOnlyJNDIFactory/* ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 1 ms
JNDIFactory [ /JNDIFactory/* , /restricted/JNDIFactory/* ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 2 ms
Classloading time: 2 ms
localhost/barbecue
Startup time: 2 ms
TLD scan time: 1 ms
Active sessions: 0
Session count: 0
Expired sessions: 0
JSPs loaded: 0
JSPs reloaded: 0
net.sourceforge.barbecue.BarcodeServlet [ /* ]
Processing time: 2.008 s
Max time: 199 ms
Request count: 578
Error count: 0
Load time: 3 ms
Classloading time: 3 ms
default [ / ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 1 ms
localhost/web-console
Startup time: 18 ms
TLD scan time: 13 ms
Active sessions: 0
Session count: 0
Expired sessions: 0
JSPs loaded: 0
JSPs reloaded: 0
UCLs
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 2 ms
JSR77 J2EE Apps
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 39 ms
Classloading time: 6 ms
Clear Monitor Alerts [ /ClearMonitorAlerts ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
AOPFolder
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 5 ms
Acknowledge Active Alarms [ /AcknowledgeActiveAlarms ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
Manage Threshold Monitor [ /ManageThresholdMonitor ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 1 ms
JSR77 WebModule
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 2 ms
HTTP Invocation [ /Invoker/* ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 2 ms
MBeans
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 1 ms
SystemFolder
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 122 ms
default [ / ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 8 ms
Classloading time: 8 ms
J2EEFolder
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 16 ms
JSR77 Domains and Servers
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 2 ms
Manage Snapshot [ /ManageSnapshot ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 4 ms
Classloading time: 4 ms
Create String Threshold Monitor [ /CreateStringThresholdMonitor ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 2 ms
Create Threshold Monitor [ /CreateThresholdMonitor ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 5 ms
Classloading time: 5 ms
Create Snapshot [ /CreateSnapshot ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 2 ms
JMS Message
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 2 ms
Manage String Threshold Monitor [ /ManageStringThresholdMonitor ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 1 ms
JSR77 EJBModules and EJBs
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 4 ms
MonitorsFolder
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 1 ms
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 21 ms
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
localhost/jbossws
Startup time: 1 ms
TLD scan time: 1 ms
Active sessions: 0
Session count: 0
Expired sessions: 0
JSPs loaded: 0
JSPs reloaded: 0
ContextServlet [ /services/* ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
default [ / ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
PortComponentLinkServlet [ /pclink ]
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
Max time: 0 ms
Request count: 0
Error count: 0
Load time: 0 ms
localhost/scereports
Start time: Mon Dec 10 02:20:28 UTC 2012
Startup time: 7 ms
TLD scan time: 107 ms
Active sessions: 14
Session count: 156
Max active sessions: 92
Expired sessions: 142
Longest session alive time: 6082 s
Average session alive time: 2539 s
Processing time: 405 ms
JSPs loaded: 25
JSPs reloaded: 25
Processing time: 0.317 s
Max time: 11 ms
Request count: 421
Error count: 0
Load time: 1 ms
ViewerServlet [ /frameset , /run ]
Processing time: 4724.949 s
Max time: 195569 ms
Request count: 1783
Error count: 0
Load time: 744 ms
Classloading time: 113 ms
default [ / ]
Processing time: 4.276 s
Max time: 563 ms
Request count: 10913
Error count: 2024
Load time: 0 ms
EngineServlet [ /preview , /download , /parameter , /document , /output , /extract ]
Processing time: 52.047 s
Max time: 14000 ms
Request count: 205
Error count: 0
Load time: 104 ms
[Updated on: Mon, 10 December 2012 04:37]
Re: birt parameter dialogue do not display for all the report in the customer production site [message #989924 is a reply to message #989923] Mon, 10 December 2012 05:32 Go to previous messageGo to next message
Is this a particular report that is running into the issue? Or are there many different reports? If just a single report, can you attach it in here? When you encounter this issue, if you use "run", in the url, rather than "frameset", does it make a difference?
Michael
Re: birt parameter dialogue do not display for all the report in the customer production site [message #989928 is a reply to message #989924] Mon, 10 December 2012 06:43 Go to previous messageGo to next message
this is for all the reports instead of just single one. now though the issue is not happening yet in customer site but interesting thing is that after change the mapping from frameset to run, the parameter dialogue could be displayed which could not work in frameset mapping even in the good condition for customer set.
our system does not access reports by directly typing the report url. Instead, the other module will read the url from oracle database which could be,i.e., </frameset?__report=report/Catch_Weight-Catch_Data_Packing_Slip.rptdesign&poptions=p> then access it in background. For the record, the report url records in the database are all frameset mapping, no run mapping.
Also wonder did you try adding some logs to the following tow servelets to troubleshooting the similar issues?
h-t-t-p://eclipsesrc.appspot.com/jsrcs/org.eclipse.birt.report.viewer/birt/WEB-INF/classes/org/eclipse/birt/report/utility/ParameterAccessor.java.html
h-t-t-p://eclipsesrc.appspot.com/jsrcs/org.eclipse.birt.report.viewer/birt/WEB-INF/classes/org/eclipse/birt/report/listener/ViewerServletContextListener.java.html
Steven
[Updated on: Mon, 10 December 2012 06:46]
Re: birt parameter dialogue do not display for all the report in the customer production site [message #989945 is a reply to message #989928] Mon, 10 December 2012 07:49 Go to previous messageGo to next message
FYI, this afternoon the issue happened again and the report could not be used again. but the parameter dialogue could be displayed and I found the below error regarding the xml parsing. this XML error could be mapped to a snapshot the end user provided to us.
2012-: Line Number:1 Error Code:Error.XMLParserException.SAX_ERROR Exception:org.xml.sax.SAXParseException: Premature end of file. Message:SAX detected an error with the basic XML syntax oo
3831054 严é‡
f the file.
3831055 2012-: invalid design file /**/**/jboss-5.1.0.GA/server/scprd-reports1/tmp/au94q-d9opan-hai5xcpw-1-hai5y33w-9s/scereports.war/report/ZTE_ScatterOrder_V4.rptdesign
3831056 严é‡
3831057 2012-: Failed to open the design!rt.report.engine.api.impl.ReportDocumentReader loadReportRunnable
3831058 严é‡
3831059 org.eclipse.birt.report.engine.api.EngineException: The design file /*/jboss-5.1.0.GA/server/scprd-reports1/tmp/au94q-d9opan-hai5xcpw-1-hai5y33w-9s/scereports.war/report/ZTE_ScatterOr der_V4.rptdesign has error and can not be run.
3831060 at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:260)
3831061 at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:274)
3831062 at org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:601)
3831063 at org.eclipse.birt.report.engine.api.impl.ReportDocumentReader.loadReportRunnable(ReportDocumentReader.java:851)
3831064 at org.eclipse.birt.report.engine.api.impl.ReportDocumentReader.getOnPreparedRunnable(ReportDocumentReader.java:903)
3831065 at org.eclipse.birt.report.engine.api.impl.ReportDocumentReader$1.run(ReportDocumentReader.java:1560)
3831066 at org.eclipse.birt.report.engine.api.impl.ReportDocumentReader$1.run(ReportDocumentReader.java:1)
3831067 at java.security.AccessController.doPrivileged(Native Method)
3831068 at org.eclipse.birt.report.engine.api.impl.ReportDocumentReader.getClassLoader(ReportDocumentReader.java:1555)
3831069 at org.eclipse.birt.report.engine.api.impl.ReportDocumentReader.loadVariableLazily(ReportDocumentReader.java:967)
3831070 at org.eclipse.birt.report.engine.api.impl.ReportDocumentReader.getParameterValues(ReportDocumentReader.java:918)
3831071 at org.eclipse.birt.report.context.ViewerAttr
Also found this error:
2012-12-10 06:03:18,517 ERROR [org.apache.catalina.core.ContainerBase.[jboss.web].[localhost].[/barbecue].[net.sourceforge.barbecue.BarcodeServlet]] (http-wms%2F10.*.*.*-8280-29) Servlet.service() for servlet net.sourceforge.barbecue.BarcodeServlet threw exception
java.net.SocketException: Broken pipe
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:92)
at java.net.SocketOutputStream.write(SocketOutputStream.java:136)
at org.apache.coyote.http11.InternalOutputBuffer.realWriteBytes(InternalOutputBuffer.java:724)
at org.apache.tomcat.util.buf.ByteChunk.flushBuffer(ByteChunk.java:449)
at org.apache.coyote.http11.InternalOutputBuffer.flush(InternalOutputBuffer.java:299)
at org.apache.coyote.http11.Http11Processor.action(Http11Processor.java:950)
at org.apache.coyote.Response.action(Response.java:186)
at org.apache.catalina.connector.OutputBuffer.doFlush(OutputBuffer.java:343)
at org.apache.catalina.connector.OutputBuffer.flush(OutputBuffer.java:314)
at org.apache.catalina.connector.CoyoteOutputStream.flush(CoyoteOutputStream.java:98)
at javax.imageio.stream.MemoryCacheImageOutputStream.flushBefore(MemoryCacheImageOutputStream.java:177)
at javax.imageio.stream.MemoryCacheImageOutputStream.close(MemoryCacheImageOutputStream.java:163)
at javax.imageio.ImageIO.write(ImageIO.java:1567)
at net.sourceforge.barbecue.BarcodeImageHandler.writeImage(Unknown Source)
at net.sourceforge.barbecue.BarcodeImageHandler.writePNG(Unknown Source)
at net.sourceforge.barbecue.BarcodeServlet.outputBarcodeImage(Unknown Source)
at net.sourceforge.barbecue.BarcodeServlet.doRequest(Unknown Source)
at net.sourceforge.barbecue.BarcodeServlet.doGet(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:19
[Updated on: Mon, 10 December 2012 08:19]
Re: birt parameter dialogue do not display for all the report in the customer production site [message #989950 is a reply to message #989945] Mon, 10 December 2012 08:45 Go to previous messageGo to next message
error snapshots provided.
Steven
[Updated on: Mon, 10 December 2012 08:46]
Re: birt parameter dialogue do not display for all the report in the customer production site [message #990093 is a reply to message #989950] Mon, 10 December 2012 20:49 Go to previous messageGo to next message
Do you have the possibility to try using a newer runtime, like 3.7.2, in a test situation, to see if it encounters the same issue?
Michael
Re: birt parameter dialogue do not display for all the report in the customer production site [message #990244 is a reply to message #990093] Tue, 11 December 2012 14:51 Go to previous messageGo to next message
Hi, Micheal
I downloaded the runtime 3.7.2 and tried to replace the 2.6.2 lib folder jars with the jars from 3.7.2 but failed. could you let me know is there any practical upgrade document regarding how to upgrade the birt runtime from 2.6 to 3.7.2?
Steven
Re: birt parameter dialogue do not display for all the report in the customer production site [message #990336 is a reply to message #990244] Tue, 11 December 2012 23:09 Go to previous messageGo to next message
Really, the upgrade would just be to set up a second deployment of the newer runtime and copy over your designs and test them. If everything works, then you switch out your current viewer, with the new one. Any initial testing for an upgrade might be easier with the designer, though. You definitely don't want to just switch your live production deployment. Smile
Michael
Re: birt parameter dialogue do not display for all the report in the customer production site [message #990352 is a reply to message #990336] Wed, 12 December 2012 06:01 Go to previous messageGo to next message
Hi, Micheal
Thanks for all the kind help Smile .
our BIRTreport module does not set up sticking to the original birt runtime architecture.
Basicly our birt war has been named scereports.war instead of birt.war based on the runtime 2.6.2 which is a little different from the folder architecture in 3.7.2. I tried to created the folder existing in 2.6.2 which 3.7.2 does not have and move the the report design files and related customized jar files from 2.6.2 to the cooresponding 3.7.2 folders and renamed the birt.war(3.7.2) to scereports.war. After that I tried to start the report server(JBoss based) and got the below error.
INFO: Initializing Mojarra (1.2_12-b01-FCS) for context '/admin-console'
05:46:40,170 INFO Initializing Mojarra (1.2_12-b01-FCS) for context '/
admin-console'
05:46:42,170 INFO deploy, ctxPath=/
05:46:42,351 INFO deploy, ctxPath=/barbecue
05:46:42,402 INFO deploy, ctxPath=/jmx-console
05:46:52,449 INFO deploy, ctxPath=/scereports2
05:47:05,021 INFO deploy, ctxPath=/scereports3
05:47:07,816 ERROR org.eclipse.birt.report.exception.ViewerException: F
atal error occurred when try to startup report engine.
05:47:07,818 ERROR at org.eclipse.birt.report.service.ReportEngineS
ervice.setEngineContext(ReportEngineService.java:334)
05:47:07,819 ERROR at org.eclipse.birt.report.service.BirtViewerRep
ortService.setContext(BirtViewerReportService.java:1022)
05:47:07,820 ERROR at org.eclipse.birt.report.listener.ViewerServle
tContextListener.contextInitialized(ViewerServletContextListener.java:62)
05:47:07,820 ERROR at org.apache.catalina.core.StandardContext.list
enerStart(StandardContext.java:3910)
05:47:07,821 ERROR at org.apache.catalina.core.StandardContext.star
t(StandardContext.java:4393)
05:47:07,822 ERROR at org.jboss.web.tomcat.service.deployers.Tomcat
Deployment.performDeployInternal(TomcatDeployment.java:310)
05:47:07,823 ERROR at org.jboss.web.tomcat.service.deployers.Tomcat
Deployment.performDeploy(TomcatDeployment.java:142)
05:47:07,823 ERROR at org.jboss.web.deployers.AbstractWarDeployment
.start(AbstractWarDeployment.java:461)
05:47:07,823 ERROR at org.jboss.web.deployers.WebModule.startModule
(WebModule.java:118)
05:47:07,870 ERROR at org.jboss.web.deployers.WebModule.start(WebMo
dule.java:97)
05:47:07,871 ERROR at sun.reflect.NativeMethodAccessorImpl.invoke0(
Native Method)
05:47:07,872 ERROR at sun.reflect.NativeMethodAccessorImpl.invoke(N
ativeMethodAccessorImpl.java:39)
05:47:07,873 ERROR at sun.reflect.DelegatingMethodAccessorImpl.invo
ke(DelegatingMethodAccessorImpl.java:25)
05:47:07,874 ERROR at java.lang.reflect.Method.invoke(Method.java:5
97)
05:47:07,875 ERROR at org.jboss.mx.interceptor.ReflectedDispatcher.
invoke(ReflectedDispatcher.java:157)
05:47:07,876 ERROR at org.jboss.mx.server.Invocation.dispatch(Invoc
ation.java:96)
05:47:07,877 ERROR at org.jboss.mx.server.Invocation.invoke(Invocat
ion.java:88)
05:47:07,878 ERROR at org.jboss.mx.server.AbstractMBeanInvoker.invo
ke(AbstractMBeanInvoker.java:264)
05:47:07,879 ERROR at org.jboss.mx.server.MBeanServerImpl.invoke(MB
eanServerImpl.java:668)
05:47:07,879 ERROR at org.jboss.system.microcontainer.ServiceProxy.
invoke(ServiceProxy.java:206)
05:47:07,880 ERROR at $Proxy38.start(Unknown Source)
05:47:07,881 ERROR at org.jboss.system.microcontainer.StartStopLife
cycleAction.installAction(StartStopLifecycleAction.java:42)
05:47:07,882 ERROR at org.jboss.system.microcontainer.StartStopLife
cycleAction.installAction(StartStopLifecycleAction.java:37)
05:47:07,882 ERROR at org.jboss.dependency.plugins.action.SimpleCon
trollerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62)
05:47:07,883 ERROR at org.jboss.dependency.plugins.action.AccessCon
trollerContextAction.install(AccessControllerContextAction.java:71)
05:47:07,884 ERROR at org.jboss.dependency.plugins.AbstractControll
erContextActions.install(AbstractControllerContextActions.java:51)
05:47:07,885 ERROR at org.jboss.dependency.plugins.AbstractControll
erContext.install(AbstractControllerContext.java:348)
05:47:07,886 ERROR at org.jboss.system.microcontainer.ServiceContro
llerContext.install(ServiceControllerContext.java:286)
05:47:07,887 ERROR at org.jboss.dependency.plugins.AbstractControll
er.install(AbstractController.java:1631)
05:47:07,888 ERROR at org.jboss.dependency.plugins.AbstractControll
er.incrementState(AbstractController.java:934)
05:47:07,890 ERROR at org.jboss.dependency.plugins.AbstractControll
er.resolveContexts(AbstractController.java:1082)
05:47:07,892 ERROR at org.jboss.dependency.plugins.AbstractControll
er.resolveContexts(AbstractController.java:984)
er.change(AbstractController.java:822)
05:47:07,893 ERROR at org.jboss.dependency.plugins.AbstractControll
er.change(AbstractController.java:553)
05:47:07,894 ERROR at org.jboss.system.ServiceController.doChange(S
erviceController.java:688)
05:47:07,894 ERROR at org.jboss.system.ServiceController.start(Serv
iceController.java:460)
05:47:07,895 ERROR at org.jboss.system.deployers.ServiceDeployer.st
art(ServiceDeployer.java:163)
05:47:07,896 ERROR at org.jboss.system.deployers.ServiceDeployer.de
ploy(ServiceDeployer.java:99)
ploy(ServiceDeployer.java:46)
05:47:07,897 ERROR at org.jboss.deployers.spi.deployer.helpers.Abst
ractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62)
05:47:07,898 ERROR at org.jboss.deployers.spi.deployer.helpers.Abst
ractRealDeployer.deploy(AbstractRealDeployer.java:50)
05:47:07,899 ERROR at org.jboss.deployers.plugins.deployers.Deploye
rWrapper.deploy(DeployerWrapper.java:171)
05:47:07,900 ERROR at org.jboss.deployers.plugins.deployers.Deploye
rsImpl.doDeploy(DeployersImpl.java:1439)
rsImpl.doInstallParentFirst(DeployersImpl.java:1157)
05:47:07,901 ERROR at org.jboss.deployers.plugins.deployers.Deploye
rsImpl.doInstallParentFirst(DeployersImpl.java:1178)
05:47:07,902 ERROR at org.jboss.deployers.plugins.deployers.Deploye
rsImpl.install(DeployersImpl.java:1098)
05:47:07,902 ERROR at org.jboss.dependency.plugins.AbstractControll
05:47:07,903 ERROR at org.jboss.dependency.plugins.AbstractControll
05:47:07,904 ERROR at org.jboss.dependency.plugins.AbstractControll
05:47:07,905 ERROR at org.jboss.dependency.plugins.AbstractControll
05:47:07,906 ERROR at org.jboss.dependency.plugins.AbstractControll
05:47:07,907 ERROR at org.jboss.dependency.plugins.AbstractControll
05:47:07,907 ERROR at org.jboss.deployers.plugins.deployers.Deploye
rsImpl.process(DeployersImpl.java:781)
05:47:07,908 ERROR at org.jboss.deployers.plugins.main.MainDeployer
Impl.process(MainDeployerImpl.java:702)
05:47:07,909 ERROR at org.jboss.system.server.profileservice.reposi
tory.MainDeployerAdapter.process(MainDeployerAdapter.java:117)
tory.ProfileDeployAction.install(ProfileDeployAction.java:70)
05:47:07,910 ERROR at org.jboss.system.server.profileservice.reposi
tory.AbstractProfileAction.install(AbstractProfileAction.java:53)
05:47:07,911 ERROR at org.jboss.system.server.profileservice.reposi
tory.AbstractProfileService.install(AbstractProfileService.java:361)
05:47:07,912 ERROR at org.jboss.dependency.plugins.AbstractControll
05:47:07,913 ERROR at org.jboss.dependency.plugins.AbstractControll
05:47:07,914 ERROR at org.jboss.dependency.plugins.AbstractControll
05:47:07,915 ERROR at org.jboss.dependency.plugins.AbstractControll
05:47:07,916 ERROR at org.jboss.dependency.plugins.AbstractControll
05:47:07,917 ERROR at org.jboss.system.server.profileservice.reposi
tory.AbstractProfileService.activateProfile(AbstractProfileService.java:306)
05:47:07,917 ERROR at org.jboss.system.server.profileservice.Profil
eServiceBootstrap.start(ProfileServiceBootstrap.java:271)
05:47:07,918 ERROR at org.jboss.bootstrap.AbstractServerImpl.start(
AbstractServerImpl.java:461)
05:47:07,919 ERROR at org.jboss.Main.boot(Main.java:221)
05:47:07,919 ERROR at org.jboss.Main$1.run(Main.java:556)
05:47:07,920 ERROR at java.lang.Thread.run(Thread.java:662)
05:47:07,978 INFO Starting Coyote HTTP/1.1 on http-USDAVWSCEMT
N-5%2F10.33.33.5-8280
05:47:08,034 INFO Starting Coyote AJP/1.3 on ajp-USDAVWSCEMTN-5%2
F10.33.33.5-8209
05:47:08,054 INFO [ServerImpl] JBoss (Microcontainer) [5.1.0.GA (build: SVNTag=
[Updated on: Wed, 12 December 2012 06:03]
Re: birt parameter dialogue do not display for all the report in the customer production site [message #990355 is a reply to message #990352] Wed, 12 December 2012 07:01 Go to previous messageGo to next message
3.7 changed from the OSGi runtime to the POJO runtime. Though, 3.7.2 did offer the OSGi runtime again, as well. What folder did you add? With the pojo runtime, all your jar files just need to be in your class / build path.
Michael
Re: birt parameter dialogue do not display for all the report in the customer production site [message #990364 is a reply to message #990355] Wed, 12 December 2012 07:49 Go to previous messageGo to next message
Here is the detailed steps i used. I am wondering if i did not change the folder architecure, will the class path still need to explicitely added? if yes, how?
I downloaded the birt-runtime-3_7_2.zip and unzipped it as birt-runtime-3_7_2.
there is a birt.war file under the birt-runtime-3_7_2 folder and i compared it with our
scereports.war under <jboss-5.1.0.GA\server\sceup-reports1\deploy\scereports.war> which 90% of the content(folder architecure)
are the same which should be caused by the difference between 2.6.2 and 3.7.2.
Below is the difference:
1) the 3.7.2 version does not have lib folder under the folder of birt(unzipped from birt.war)
2) I created the lib folder under the birt folder and copied the jars in the scereports.war(unzipped) under the lib folder to the new created lib folder of birt folder.
3) birt 3.7.2 does not have platform and class folders under the /birt-runtime-3_7_2/birt/WEN-INF which i need to created and copy the related files to from scereports.war.
4) the content in the folder of /birt/WEB-INF/lib of 3.7.2 is not all the same with 2.6.2 so i need to copy all the jar files from 2.6.2 to the 3.7.2.
5)our scereports.war is deployed to <jboss-5.1.0.GA\server\sceup-reports1\deploy\scereports.war> using JbossAS 5.
6) jars under birt-runtime-3_7_2\ReportEngine\lib have not been used at all as i do not know how to use it.
after all the above steps, i tried to start the report service with the startup script.
Steven
[Updated on: Wed, 12 December 2012 08:07]
Re: birt parameter dialogue do not display for all the report in the customer production site [message #990470 is a reply to message #990364] Wed, 12 December 2012 15:57 Go to previous messageGo to next message
Take a look at this: http://wiki.eclipse.org/BIRT_3.7_Runtime_Deployment_Guide
Michael
Re: birt parameter dialogue do not display for all the report in the customer production site [message #991252 is a reply to message #990364] Tue, 18 December 2012 05:07 Go to previous messageGo to next message
Hi, Micheal
I did not try the upgrade guide yet till now. I tried to simulate 400 concurrent users with 30000 requests targeting the birt report url(ip:8080/scereports) and it could make the report server hang and unusable for a while. After increasing the jboss http connector threads from 200 to 400, the old issue has been gone but a new issue occurred which is less frequently than before. I also found that there were some other birt users also reporting this new issue as well without solution provided in this link, could you help have a check?
h-t-t-p:/-/www.birt-exchange.org/org/forum/index.php/topic/23414-reportdocumentwriter-severe-failed-to-save-design-exception/page__pid__112252__st__0&#entry112252
Steven
Re: birt parameter dialogue do not display for all the report in the customer production site [message #991408 is a reply to message #991252] Tue, 18 December 2012 22:44 Go to previous messageGo to next message
Can you post your new error stack in here?
Michael
Re: birt parameter dialogue do not display for all the report in the customer production site [message #991419 is a reply to message #991408] Wed, 19 December 2012 02:29 Go to previous messageGo to next message
Hi, Michael
1)THe old issue occurred again last night, now i am quite sure this error caused the issue, someone told this is a bug(h-t-t-p://download.eclipse.org/birt/downloads/build.php?build=M-R1-4.2.1RC1-201208201733), but the weird if we are facing a bug, why it could not occure everytime, it just occurs after some hours.
2012-12-19 2:30:15 org.eclipse.birt.data.engine.odaconsumer.ParameterMetaData getRuntimeParameterType
严é‡
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot get parameter type.
æ"¯æŒçš„特性
SQL error #1:ä¸
æ"¯æŒçš„特性
2) the new stack is like below:
2012-: An error happened while running the report. Cause:l.RunTask doRun
org.eclipse.birt.report.engine.api.EngineException: Failed to save design. //here did not explain the reason why could not save, disk space(most likely)?permission? Duplicate file names?
at org.eclipse.birt.report.engine.api.impl.ReportDocumentWriter.saveDesign(ReportDocumentWriter.java:216)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:222)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:85)
at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1315)
at org.eclipse.birt.report.service.BirtViewerReportService.runReport(BirtViewerReportService.java:158)
at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:81)
at org.eclipse.birt.report.service.actionhandler.BirtChangeParameterActionHandler.runReport(BirtChangeParameterActionHandler.java:58)
2) the new issue is like below and as i found there are a log of files(total 12 G up to now) of birt xml file in /tmp folder and i have asked customer to monitor this space.
[Updated on: Wed, 19 December 2012 02:32]
Re: birt parameter dialogue do not display for all the report in the customer production site [message #991700 is a reply to message #991419] Thu, 20 December 2012 02:22 Go to previous messageGo to next message
If you've already made the jump to 3.7.2, 4.2 shouldn't cause much issue, but you should definitely test it out, first. You might give it a test run. Hopefully it helps!
Michael
Re: birt parameter dialogue do not display for all the report in the customer production site [message #994525 is a reply to message #991700] Thu, 27 December 2012 15:29 Go to previous messageGo to next message
HI, Michael
here is another question just wondering whether you are aware of. when our customer want to export a new report result which got from a new deployed report to the excel file by clicking the exporting icon, it will go to the parameter window instead of a window which shoudl ask you to save the excel file. it will come to normal after many hours instead of taking effect immediately after deployed. is this a known bug ?
Steven
Re: birt parameter dialogue do not display for all the report in the customer production site [message #994908 is a reply to message #994525] Fri, 28 December 2012 16:02 Go to previous messageGo to next message
When you export a report to XLS from an already ran report, in the web viewer, it's popping up the parameter screen, for the XLS report? I've not heard of this, yet. If this is what you mean, please log a bug for this!
Michael
Re: birt parameter dialogue do not display for all the report in the customer production site [message #1011285 is a reply to message #989757] Tue, 19 February 2013 08:31 Go to previous message
Adam Sa is currently offline Adam SaFriend
Hi Steven Chen,
Did you solve your problem:
"when our customer want to export a new report result which got from a new deployed report to the excel file by clicking the exporting icon, it will go to the parameter window instead of a window which shoudl ask you to save the excel file."
or did you report it as a bug?
Previous Topic:Chart change style line
Next Topic:Cube doesnt exist
Current Time: Tue Apr 24 21:25:37 GMT 2018
Powered by FUDForum. Page generated in 0.02167 seconds
