Home » Modeling » TMF (Xtext) » xtext injected parser(xtext injected parser)
xtext injected parser [message #989207] Wed, 05 December 2012 08:52 Go to next message
Dana Klein is currently offline Dana KleinFriend
Member
@Inject
protected void setInjectedParser(IParser parser) {
this.parser = parser;
I want to manually run the xtext engine and i'm not sure when and where the setInjectedParser is being called.
thanks,
Re: xtext injected parser [message #989211 is a reply to message #989207] Wed, 05 December 2012 09:04 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Just make sure the class is created with Google guice. E.g. by
calling new mydslstsndalonesetup().createinjectoranddoemfregistration
if the code is called stsndalone
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @chrdietrich
Blog : christiandietrich.wordpress.com
Re: xtext injected parser [message #989212 is a reply to message #989211] Wed, 05 December 2012 09:07 Go to previous messageGo to next message
Injector i = new MydslStandaloneSetup().createInjectorAndDoEMfRegistration()
MyClass c = i.getInstance(MyClass.class)
P.S: a bit more context in such questions would be helpful
Re: xtext injected parser [message #989230 is a reply to message #989212] Wed, 05 December 2012 10:03 Go to previous messageGo to next message
Member
Ok thanks!
I will try to explain
I have my dsl as plugin.
i want to create a new app that use my dsl
so i tried to write this code:
JsonParser p = new JsonParser();
IParseResult r = p.parse(new StringReader("{}"));
//once that work it will be the file data instead of {}
but when i do the parse the node model builder is null and the following line has exception:
return doParse(ruleName, in, nodeModelBuilder.get(), 0);
and i'm not sure how to init nodeModelBuilder
i'm sure i missing some steps but i'm not quite familiar with the xtext process.
[Updated on: Wed, 05 December 2012 10:13]
Report message to a moderator
Re: xtext injected parser [message #989309 is a reply to message #989230] Wed, 05 December 2012 15:40 Go to previous message
Member
Hey thank you for the help, i'm continuing in a different path.
but thanks!
[Updated on: Wed, 05 December 2012 15:41]
Previous Topic:file parsing
Next Topic:Xtext/Xbase for writing complex math expressions
Current Time: Sun Jan 21 22:52:12 GMT 2018
Powered by FUDForum. Page generated in 0.01653 seconds
