Home » Modeling » Epsilon » [EVL] How to acces a element in my model
[EVL] How to acces a element in my model [message #989174] Wed, 05 December 2012 00:44 Go to next message
Sebastian Rivera is currently offline Sebastian RiveraFriend
Hi , first I attached a picture of my metamodel to explain what I need help with
From the picture you can see that a navigational class has attributes and operations.So I don't know how to make or the syntax to create a constraint that checks all the navigational attributes associated with a specific navigational class. Like check for each navigational class all of navigational attributes associated with it.
Thanks in advance for your help
pd: sorry for my English, not my native language Razz
Re: [EVL] How to acces a element in my model [message #989279 is a reply to message #989174] Wed, 05 December 2012 13:48 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris KolovosFriend
Would the following work?
context NAVIGATIONALATTRIBUTE {
constraint SomeConstraint {
check: ...
Dimitris
Re: [EVL] How to acces a element in my model [message #989343 is a reply to message #989174] Wed, 05 December 2012 18:17 Go to previous messageGo to next message
not really,I want to do something like this (i know the sintax and the code its not right)
context NAVIGATIONALCLASS {
check: self.name = "something" and self.NavigationalClassNavigationalAttribute.name="anotherthing";
Something like that so i can check all the navigational attributes associated with a navigational class in specific and check the value name in both the class and the attribute.
I hope that clarifies what i'm trying to do
thx for the help
Re: [EVL] How to acces a element in my model [message #989351 is a reply to message #989343] Wed, 05 December 2012 18:52 Go to previous messageGo to next message
If you need to check only the attributes of a specific class (X) you could use a guard to specify this e.g.
guard: self.eContainer()./*this navigates to the container NAVIGATIONALCLASS*/.name = "X"
check: ...
Dimitris
Re: [EVL] How to acces a element in my model [message #989357 is a reply to message #989351] Wed, 05 December 2012 20:10 Go to previous messageGo to next message
I think thats it , i will try it later since i cant at the moment and will comment back.
Thx alot for all the help
Re: [EVL] How to acces a element in my model [message #989594 is a reply to message #989357] Thu, 06 December 2012 22:11 Go to previous messageGo to next message
it worked perfect
I got a last question, its there a place where i can check all the things i can use with evl like the .eContainer()? , because i never knew that existed.
Thx alot again
Re: [EVL] How to acces a element in my model [message #989595 is a reply to message #989594] Thu, 06 December 2012 22:17 Go to previous messageGo to next message
Hi Sebastian,
eContainer() is a method of EObject which is the interface that all EMF model elements conform to (see http://download.eclipse.org/modeling/emf/emf/javadoc/2.4.3/org/eclipse/emf/ecore/EObject.html for more methods)
Dimitris
Re: [EVL] How to acces a element in my model [message #1724108 is a reply to message #989174] Sun, 21 February 2016 01:02 Go to previous messageGo to next message
C. Santos is currently offline C. SantosFriend
Member
Hi Dimitris,
Is it possible check if the compartment contains elements?
@gmf.node(label="name", label.text="Procedure", border.color="255,13,13")
class Procedure extends Subprograms {
@gmf.compartment
val Parameters[*] parameters;
Crystal.
Re: [EVL] How to acces a element in my model [message #1724119 is a reply to message #1724108] Sun, 21 February 2016 10:30 Go to previous messageGo to next message
Hi Crystal,
Would a constraint like the one below do the trick?
context Procedure {
  constraint HasParameters {
    check: not self.parameters.isEmpty()
Dimitris
Re: [EVL] How to acces a element in my model [message #1724131 is a reply to message #1724119] Sun, 21 February 2016 15:34 Go to previous message
Member
Yes, this worked for me.
Thank you, Dimitris Smile
Previous Topic:EOL: Call by reference and Map type
Next Topic:query 2 xml files at the same time
Current Time: Tue Jan 16 14:03:41 GMT 2018
Powered by FUDForum. Page generated in 0.02059 seconds
