Home » Eclipse Projects » Rich Client Platform (RCP) » how we add a plugin to a RCP project
how we add a plugin to a RCP project [message #987876] Wed, 28 November 2012 13:33 Go to next message
sam mn is currently offline sam mnFriend
how we add a plugin "org.eclipse.compare" to a RCP project.
tried adding following dependency to our plugin pom.xml:
<dependency>
<groupId>org.eclipse.compare</groupId>
<artifactId>org.eclipse.compare</artifactId>
<version>3.5.200-v370</version>
<scope>compile</scope>
</dependency>
and tried running the maven command to install the jar to local maven repo. However did not work.What am I missing ?, could anyone guide me.
[Updated on: Wed, 28 November 2012 13:40]
Report message to a moderator
Re: how we add a plugin to a RCP project [message #988468 is a reply to message #987876] Fri, 30 November 2012 03:55 Go to previous message
index.php/fa/12554/0/
[Updated on: Fri, 30 November 2012 09:39]
Previous Topic:Need Command Reference on Startup
Next Topic:[SOLVED] Key Binding only works when menu visible?
Current Time: Tue Jan 16 17:56:28 GMT 2018
Powered by FUDForum. Page generated in 0.01984 seconds
