Home » Modeling » GMF (Graphical Modeling Framework) » On Save Action
On Save Action [message #987761] Tue, 27 November 2012 18:11 Go to next message
Nick Collier is currently offline Nick Collier
I'm generating code from my diagram and I'd like to run the generation workflow whenever the diagram is saved. What's the appropriate way to do this? I assume I should add some code to whatever runs the save but I'm not sure where this is, or even if that's the appropriate way.
thanks,
Nick
[Updated on: Tue, 27 November 2012 18:11]
Report message to a moderator
Re: On Save Action [message #987799 is a reply to message #987761] Wed, 28 November 2012 03:46 Go to previous message
Ralph Gerbig is currently offline Ralph Gerbig
in you xxxDiagramEditor you can override doSave(IProgressMonitor progressMonitor) this will do the jog. If you generation takes a lot of resources you could do it when Eclipse does an automatic build.
Ralph
Previous Topic:Canvas and Top node customization
Next Topic:Custom ModelAssistant Popup Names and Icons
Current Time: Sat May 18 23:58:49 EDT 2013
Powered by FUDForum. Page generated in 0.01669 seconds
