Home » Eclipse Projects » EclipseLink » ManyToOne and JoinTable(ManyToOne and JoinTable (remove cascade not desired))
icon5.gif  ManyToOne and JoinTable [message #987653] Tue, 27 November 2012 13:00 Go to next message
Sergio a is currently offline Sergio aFriend
My eclipseLink version is 2.1.3, im using both @ManyToOne and @JoinTable to mapping this situation:
   @ManyToOne(fetch = FetchType.EAGER)
   @JoinTable(name = "TABLE_USER_ADDRESS", joinColumns = @JoinColumn(name = "USER_ID", referencedColumnName = "USERID"),
       inverseJoinColumns = @JoinColumn(name = "ADDR_ID", referencedColumnName = "ADDRESSID"))
   private Address address;
When remove an User, jpa try to remove the Address associated. Although the address is associated with more users (hence ManyToOne).
I am new using EclipseLink jpa Smile, am I doing something wrong? How I can state that no cascade delete? (default cascade is emtpy array, I've also tried putting cascade = {})
Thanks, regards.
Re: ManyToOne and JoinTable [message #987697 is a reply to message #987653] Tue, 27 November 2012 16:17 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
JPA will not delete the Address unless you call remove() with the Address, or have set cascade remove.
JPA will delete the row from the join table, as that row is owned by the User object.
What is your SQL log?
James : Wiki : Book : Blog : Twitter
Re: ManyToOne and JoinTable [message #987798 is a reply to message #987697] Wed, 28 November 2012 08:37 Go to previous messageGo to next message
Thank you very much for the quick response.
The SQL log:
[EL Fine]: 2012-11-28 09:19:30.276--ServerSession(219730313)--Connection(764103883)--Thread(Thread[DistributedCache:MetadataCache,10,Cluster])--SELECT USERID FROM USER WHERE (USERID = ?)
	bind => [administrationUser]
[EL Fine]: 2012-11-28 09:19:30.278--ServerSession(219730313)--Connection(764103883)--Thread(Thread[DistributedCache:MetadataCache,10,Cluster])--SELECT t1.USERID FROM TABLE_USER_ADDRESS t0, USER t1 WHERE ((t0.USER_ID = ?) AND (t1.USERID = t0.USER_ID))
[EL Fine]: 2012-11-28 09:19:30.283--ClientSession(1080497174)--Connection(764103883)--Thread(Thread[DistributedCache:MetadataCache,10,Cluster])--DELETE FROM TABLE_USER_ADDRESS WHERE (USER_ID = ?)
[EL Fine]: 2012-11-28 09:19:30.287--ClientSession(1080497174)--Connection(764103883)--Thread(Thread[DistributedCache:MetadataCache,10,Cluster])--DELETE FROM USER WHERE (USER_USERGROUP = ?)
[EL Fine]: 2012-11-28 09:19:30.308--ServerSession(219730313)--Connection(764103883)--Thread(Thread[DistributedCache:MetadataCache,10,Cluster])--SELECT ADDRID FROM ADDRESS WHERE (ADDRID = ?)
	bind => [addrIDUserAdministration]
[EL Fine]: 2012-11-28 09:19:30.31--ClientSession(909751202)--Connection(764103883)--Thread(Thread[DistributedCache:MetadataCache,10,Cluster])--DELETE FROM ADDRESS WHERE (ADDRID = ?)
[EL Fine]: 2012-11-28 09:19:30.391--ClientSession(909751202)--Thread(Thread[DistributedCache:MetadataCache,10,Cluster])--SELECT 1 FROM DUAL
[EL Warning]: 2012-11-28 09:19:30.411--UnitOfWork(1335606662)--Thread(Thread[DistributedCache:MetadataCache,10,Cluster])--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.1.v20111018-r10243): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLIntegrityConstraintViolationException: ORA-02292: integrity constraint (USERADDR_TABLE_USER_ADDRESSSRID) violated - child record found
Error Code: 2292
Call: DELETE FROM ADDRESS WHERE (ADDRID = ?)
Query: DeleteObjectQuery(Address{key=AddressKey{key=addrIDUserAdministration}})
Re: ManyToOne and JoinTable [message #989099 is a reply to message #987798] Tue, 04 December 2012 15:35 Go to previous messageGo to next message
Seems to be a bug. Please log the bug and vote for it.
(the issues is in ObjectReferenceMapping.preDelete(), the isForeignKeyRelationship() check is wrong).
Re: ManyToOne and JoinTable [message #989200 is a reply to message #989099] Wed, 05 December 2012 08:34 Go to previous message
Bug created:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=395739
Thanks.
Regards.
Previous Topic: Issue with inheritance and join fetching
Next Topic:@CascadeOnDelete
Current Time: Wed Jun 20 21:28:15 GMT 2018
Powered by FUDForum. Page generated in 0.01703 seconds
