GraphitiConnectionEditPart causes problem [message #987297] |
Sun, 25 November 2012 20:27 |
Junior Lekane Nimpa Messages: 23 Registered: September 2012 |
Junior Member |
Hello all,
The following shows how i registred two adapter factories to provide
IPropertySource objects.
<extension
point="org.eclipse.core.runtime.adapters"
id="26091990"
name="de.rwth.swc.mocca.ui.editor.properties.adapters">
<factory
adaptableType="org.eclipse.graphiti.ui.platform.GraphitiShapeEditPart"
class="de.rwth.swc.mocca.ui.editor.properties.
GraphitiShapeEditPartToIPropertySourceAdapterFactory">
<adapter type="org.eclipse.ui.views.properties.IPropertySource"/>
</factory>
<factory
adaptableType="org.eclipse.graphiti.ui.internal.parts.FreeFormConnectionEditPart"(*)
GraphitiConnectionEditPartToIPropertySourceAdapterFactory">
</factory>
</extension>
The problem is that i use the internal class FreeFormConnectionEditPart:see (*)
One Month ago it worked fine with GraphitiConnectionEditPart. I done some refactoring and put the plugin to our build. After that the factory did not get loaded. But with FreeFormConnectionEditPart the factory is loaded without problems.
Actually i don't what is wrong with GraphitiConnectionEditPart.
I guess, there is a problem somewhere in our system.
Can someone help me to see more clearly?
Thanks in advance
Junior
FUDForum. Page generated in 0.03246 seconds
