Home » Eclipse Projects » Remote Application Platform (RAP) » RAP and OSGi Services
RAP and OSGi Services [message #986932] Thu, 22 November 2012 12:17 Go to next message
Wim Jongman is currently offline Wim JongmanFriend
We have a large number of layered osgi components (stateless "singleton" services) that do not have the notion of sessions.
From the RAP ui there is a call to say "ItemService", ItemService is dynamically bound with a UserAdmin service.
When ItemService is called to receive items, it calls a method in UserAdminService to see if the user is authorized.
In the RCP environment UserAdminService uses a static UserProfile.getLoggedinUser() method but this approach will obviously not work in RAP.
Is there a way to get to the RAP session information from UserAdminService without changing the method signatures?
so in short
RAP UI (1..*) --> ItemService (1) --> UserAdmin (1) --> ?session?
Thanks for helping,
Wim
Re: RAP and OSGi Services [message #987077 is a reply to message #986932] Fri, 23 November 2012 10:17 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
Hi Wim,
You can use RWT.getSessionStore().getHttpSession() to obtain a reference
to the HttpSession. But you need to make this call from the UI thread to
get the connection to the user session. Does that help?
Regards, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: RAP and OSGi Services [message #987079 is a reply to message #987077] Fri, 23 November 2012 11:11 Go to previous messageGo to next message
Thanks for replying Ralf.
In a RAP environment, aren't there multiple UI threads?
If I consume the ItemService "singleton" from OSGi and make a call to it from a RAP UI thread, how can the ItemService know from what UI thread the call was made?
Do you think it can be done without passing some kind of information to the OSGi service?
Wim
Re: RAP and OSGi Services [message #987104 is a reply to message #987079] Fri, 23 November 2012 14:01 Go to previous messageGo to next message
Sure, there are as many UI threads as there are active user sessions.
But you don't have to pass any information as long as the call is made
in a UI thread, e.g. from a listener or in a display.asyncExec() and the
services in this call chain call each other methods directly
(synchronously).
Rest regards, Ralf
Ralf Sternberg
Re: RAP and OSGi Services [message #987188 is a reply to message #986932] Sat, 24 November 2012 10:21 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Your statements contractdict each other! Your UserAdminService is
*stateful* because it accesses a static variable, so all and everyone
depending on it is getting stateful as well.
Tom
Am 22.11.12 13:17, schrieb Wim Jongman:
> not work in RAP.
> so in short
> Thanks for helping,
> Wim
Re: RAP and OSGi Services [message #987189 is a reply to message #987104] Sat, 24 November 2012 10:22 Go to previous messageGo to next message
That's exactly the big drawback. You need to call the service on the
UI-Thread so stuff you pushed into a background-thread can't access the
stuff anymore!
Tom
Am 23.11.12 15:01, schrieb Ralf Sternberg:
> (synchronously).
> Rest regards, Ralf
Re: RAP and OSGi Services [message #987306 is a reply to message #987189] Sun, 25 November 2012 21:28 Go to previous messageGo to next message
Chris Fairhall is currently offline Chris FairhallFriend
This is a problem with any multi-user system. If you need to access a 'singleton' scoped to a specific user have a look at org.eclipse.rap.rwt.SingletonUtil to provide your scoped singletons and org.eclipse.rap.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeContext(Display, Runnable) This will allow you to access the singletons on a background thread. You'll still need to save a reference to the Display instance for the particular user though.
In my single-sourced project I used fragments to provide my own "singleton service". The RAP version used org.eclipse.rap.rwt.SingletonUtil and the RCP version used a HashMap.
I believe this is discussed in one of the single-sourcing guides from EclipseSource. You should be able to get it from http://eclipsesource.com/en/info/rcp-rap-single-sourcing-guideline/
Re: RAP and OSGi Services [message #987344 is a reply to message #987306] Mon, 26 November 2012 08:52 Go to previous message
Right, you *can* access session-scoped data from a background thread if
you have a reference to the user's display. I was hesitating to make
this statement in the first place because this API is under revision for
2.0.
As Chris states, in RAP 1.x, you can use
UICallBack.runNonUIThreadWithFakeContext(Display, Runnable).
For 2.0, stay tuned on the New & Noteworthy pages.
Regards, Ralf
Ralf Sternberg
Previous Topic:ToolItems in section#textClient gets white background instead of being transparent
Next Topic:How to create a shell out of the screen?
Current Time: Sat Apr 21 17:46:15 GMT 2018
Powered by FUDForum. Page generated in 0.02422 seconds
