Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT/Jface(Displya result on tabel viewer on button click using SWT/Jface)
SWT/Jface [message #986577] Wed, 21 November 2012 02:44 Go to next message
Prashant p is currently offline Prashant pFriend
Member
There is one scnerio. I have Search text field which gets autopopulated and On click of submit button it should populate Table viewer as a result of seacrh criteria. Please let me know how can i achieve this with SWT/Jface Data binding.
All process is Database driven.
Below is the code snippet.
text_workplace--> is Text field to auto populate field
text_workplace.addKeyListener(new KeyAdapter() {
public void keyReleased(KeyEvent ke) {
Connection con = null;
Statement st= null;
ResultSet resultSetWorkplaceSrch;
PreparedStatement pstmt;
String query= "SELECT WorkplaceName FROM Workplace where workplaceCode=?";
try
Class.forName("org.sqlite.JDBC");
con = DriverManager.getConnection("jdbc:sqlite:C:\\Database\\ProManager");
pstmt = con.prepareStatement(query);
pstmt.setInt(1, 1437);
resultSetWorkplaceSrch= pstmt.executeQuery();
while(resultSetWorkplaceSrch.next()){
text_workplace.setText(resultSetWorkplaceSrch.getString(1));
}catch(Exception err){
System.out.println(err);
btnSearch --> Button to display result in SWT table viewer based on value of text field.
workplaceDetail- Is POJO
btnSearch = new Button(composite, SWT.NONE);
btnSearch.setBounds(248, 120, 47, 25);
btnSearch.setText("Search");
btnSearch.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
String selected=text_workplace.getText();
IStructuredSelection selection = (IStructuredSelection) m_workplaceViewer.getSelection();
workplaceDetail = (WorkplaceDetail) selection.getFirstElement();
if (selected==""){
WorkplaceDaoImpl workplaceDaoImpl = new WorkplaceDaoImpl();
int code = 1437; workplaceDaoImpl.getWorkplaceDetailsSearchById(code);
bindingContext.updateModels();
WorkplaceDaoImpl - DAO implementation to query result from DB.
Re: SWT/Jface [message #986839 is a reply to message #986577] Wed, 21 November 2012 21:37 Go to previous message
Grant Gayed is currently offline Grant GayedFriend
If this is a question on the data binding then you should ask in the
JFace forum/newsgroup. JFace is not part of SWT.
Grant
> Statement st= null;
> workplaceCode=?";
> try {
> Class.forName("org.sqlite.JDBC"); con =
> pstmt.setInt(1, 1437); resultSetWorkplaceSrch=
> } }catch(Exception err){ System.out.println(err); } }
> @Override
> if (selected==""){
> int code = 1437;
Previous Topic:SWT Tools Update Sites
Next Topic:Multiple viewport on the same canvas
Current Time: Sat May 26 13:59:15 GMT 2018
Powered by FUDForum. Page generated in 0.01978 seconds
