Home » Eclipse Projects » Eclipse 4 » Difference between org. .. .observable and org. .. .observable.source
Difference between org. .. .observable and org. .. .observable.source [message #986538] Tue, 20 November 2012 15:24 Go to next message
Aljoscha Steffens is currently offline Aljoscha Steffens
this is probably a stupid question but i just can't find a answer with google.
I am at the last steps of a RCP tutorial and at this step I have to add the dependency
org.eclipse.core.databinding.observable
to my META.INF. But I can only add org.eclipse.core.databinding.observable.source
When I download the example code to the tutorial they have added the "org.eclipse.core.databinding.observable". How comes that I can't find it?
My suggestion is that the .source package is simply more general, but I don't want to rely on this suggestion.
So whats the difference between .source and "normal" packages?
And since I'm already here: Can you tell me when I have to add dependencies to my product file and when they belong into the META-INF? What es the difference?
Thank you!
Re: Difference between org. .. .observable and org. .. .observable.source [message #986542 is a reply to message #986538] Tue, 20 November 2012 15:43 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
The .source one holds the Java-Source-Files whereas the one without
..source holds the .class-Files.
Tom
Am 20.11.12 21:24, schrieb Aljoscha Steffens:
> google.
> the dependency
> Thank you!
Re: Difference between org. .. .observable and org. .. .observable.source [message #986546 is a reply to message #986538] Tue, 20 November 2012 16:16 Go to previous messageGo to next message
Frank Langanke is currently offline Frank Langanke
Have a look in the /plugins directory of your eclipse installation. You should find two jars like these:
  • org.eclipse.core.databinding.observable.source_1.4.1.v20120521-2329.jar
  • org.eclipse.core.databinding.observable_1.4.1.v20120521-2329.jar
As Thomas said the first one just contains the java-sources and is optional, while you need the second one at compile and runtime.
Re: Difference between org. .. .observable and org. .. .observable.source [message #986547 is a reply to message #986538] Tue, 20 November 2012 16:18 Go to previous messageGo to next message
--- removed double post ---
[Updated on: Tue, 20 November 2012 16:19]
Report message to a moderator
Re: Difference between org. .. .observable and org. .. .observable.source [message #986797 is a reply to message #986547] Wed, 21 November 2012 11:27 Go to previous messageGo to next message
Hm okay, thank you.
I found the file in my directory but why don't I have access to it? when I type "org.eclipse.core.dat" I can just choose the source file
Re: Difference between org. .. .observable and org. .. .observable.source [message #986861 is a reply to message #986797] Thu, 22 November 2012 01:57 Go to previous messageGo to next message
Aljoscha Steffens wrote on Wed, 21 November 2012 11:27
Hm okay, thank you.
Please post your MANIFEST.MF. Maybe 'org.eclipse.core.databinding.observable' is already included? Did you customize your target definition?
Re: Difference between org. .. .observable and org. .. .observable.source [message #986868 is a reply to message #986861] Thu, 22 November 2012 02:57 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk Fauth
I checked your statement and I can also not include org.eclipse.core.databinding.observable. This is because I have the dependency to org.eclipse.core.databinding included, which itself has a depencency to the observable plugin. So you don't have to add it manually again, as it is already included transitively. Have a look at your product configuration. In the dependencies section you should find the observable plugin.
If you want to check which bundles are loaded and active you can check this via the OSGi console in Eclipse. Just open it from the console view in Eclipse and check like described here
http://www.vogella.com/articles/OSGi/article.html#osgiconsole_commands
Re: Difference between org. .. .observable and org. .. .observable.source [message #986918 is a reply to message #986868] Thu, 22 November 2012 06:18 Go to previous messageGo to next message
Am 22.11.12 08:57, schrieb Dirk Fauth:
The dependency is not the important fact but that core.databinding
reexports the obserable one.
Tom
Re: Difference between org. .. .observable and org. .. .observable.source [message #986920 is a reply to message #986918] Thu, 22 November 2012 06:25 Go to previous message
Thomas Schindl wrote on Thu, 22 November 2012 12:18
Tom
Thanks for pointing to this. I just missed the little grey arrow in the manifest editor. Smile
Previous Topic:How to pass Keyboard Events to the MPart?
Next Topic:Creation of IEclipseContext
Current Time: Thu May 23 17:32:52 EDT 2013
Powered by FUDForum. Page generated in 0.03368 seconds
