[Teneo] Use objects in a query later on [message #985678] |
Thu, 15 November 2012 16:39 |
Thomas Kipar Messages: 7 Registered: January 2012 |
Junior Member |
I am quite new to Hibernate and Teneo. What I try to do is the following: I have a query to get an entity. I save this object somewhere.
Later on, I would like to reuse this object in a different query (for a join). So I have...
ClassA a = query.list().get(0);
// somewhere else...
session.createQuery("FROM ClassB b WHERE b.a = :id"); // how to I use my existing a here?
To clarify: ClassB has a reference to ClassA. Am I right that I have to introduce explicit IDs in my model in order to solve this problem? I hoped the implicit IDs genereted by Teneo would be sufficient.
Thanks in advance.
Thomas
[Updated on: Thu, 15 November 2012 17:21] Report message to a moderator
Re: [Teneo] Use objects in a query later on [message #985714 is a reply to message #985678] |
Thu, 15 November 2012 18:50 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Thomas,
As long as you are in the same session then you can re-use the same object, otherwise it is better to use the id of the
object for querying:
Query qry = session.createQuery("FROM B b WHERE b.a = :object");
qry.setParameter("object", object);
or
Query qry = session.createQuery("FROM B b WHERE b.a.id = :id");
qry.setParameter("id", object.getId());
There are several setParameter methods for different types of parameters.
gr. Martin
On 11/15/2012 05:39 PM, Thomas Kipar wrote:
> object somewhere.
> session.createQuery("FROM B b WHERE b.a = :id"); // how to I use my existing a here?
> Thanks in advance.
> Thomas
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.02516 seconds
