Home » Eclipse Projects » BIRT » Avoid Color in Series Palette
Avoid Color in Series Palette [message #984297] Wed, 14 November 2012 15:21 Go to next message
Ricardo Rodrigues is currently offline Ricardo RodriguesFriend
I have 9 gradient colors defined in my Series palette.
If the chart has more then 9 bars the engine creates the bars with another random color.
The problem is that some of the colors are too bright and sometimes is white like the background.
Is there a way to dynamically (script) check if the color is white or is in some range of colors, remove and add another one?
Thank you
Re: Avoid Color in Series Palette [message #985752 is a reply to message #984297] Thu, 15 November 2012 23:11 Go to previous message
Tom Yamada is currently offline Tom YamadaFriend
Ricardo, doesn't the series palette let you add more than nine gradient patterns?
Previous Topic:Automatically open a rendered report
Next Topic:reportContext.getMessage() syntax to behave like label/chart localization properties
Current Time: Thu Apr 26 00:19:09 GMT 2018
Powered by FUDForum. Page generated in 0.01266 seconds
