Home » Eclipse Projects » Remote Application Platform (RAP) » require document for deploy rwt standalone to jee container like tomcat or jboss?
require document for deploy rwt standalone to jee container like tomcat or jboss? [message #984264] Wed, 14 November 2012 14:52 Go to next message
David Song is currently offline David SongFriend
hi rap teams,
I tried many times to deploy my new rwt standalone ver1.5 or ver2.0 app to jee container like Tomcat or Jboss, but they do not work. Would you please to give a doc or a tutorial to deploy rwt ver1.5 or ver2.0 standalone application to jee contaner like Tomcat or Jboss?
David
Re: require document for deploy rwt standalone to jee container like tomcat or jboss? [message #985242 is a reply to message #984264] Thu, 15 November 2012 08:59 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
Did you check the developer's guide?
http://eclipse.org/rap/developers-guide/devguide.php?topic=advanced/deployment.html
Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: require document for deploy rwt standalone to jee container like tomcat or jboss? [message #985635 is a reply to message #985242] Thu, 15 November 2012 15:03 Go to previous messageGo to next message
Thanks Ralf for your so quick reply to me
the tutorial is about how to deploy workbench rap application to jee container, but I say how to depay RWT STANDALONE APP to jee container, just like the example org.eclipse.rap.examples, I tried import org.eclipse.rap.examples and create a war configuration file to export a war file, but when deploy to jboss, an error occrors and the log is as belong:
WARN  [org.jboss.as.ee] (MSC service thread 1-1) JBAS011006: Not installing optional component org.eclipse.rap.rwt.engine.RWTServletContextListener due to exception: java.lang.ClassNotFoundException: org.eclipse.rap.rwt.engine.RWTServletContextListener from [Module "deployment.ROOT.war:main" from Service Module Loader]
	at org.jboss.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:190) [jboss-modules.jar:1.1.1.GA]
	at org.jboss.modules.ConcurrentClassLoader.performLoadClassUnchecked(ConcurrentClassLoader.java:468) [jboss-modules.jar:1.1.1.GA]
	at org.jboss.modules.ConcurrentClassLoader.performLoadClassChecked(ConcurrentClassLoader.java:456) [jboss-modules.jar:1.1.1.GA]
	at org.jboss.modules.ConcurrentClassLoader.performLoadClass(ConcurrentClassLoader.java:398) [jboss-modules.jar:1.1.1.GA]
	at org.jboss.modules.ConcurrentClassLoader.loadClass(ConcurrentClassLoader.java:120) [jboss-modules.jar:1.1.1.GA]
	at java.lang.Class.forName0(Native Method) [rt.jar:1.7.0_06]
	at java.lang.Class.forName(Class.java:264) [rt.jar:1.7.0_06]
	at org.jboss.as.server.deployment.reflect.DeploymentClassIndex.classIndex(DeploymentClassIndex.java:54) [jboss-as-server-7.1.1.Final.jar:7.1.1.Final]
	at org.jboss.as.ee.component.deployers.EEModuleConfigurationProcessor.deploy(EEModuleConfigurationProcessor.java:79)
	at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:113) [jboss-as-server-7.1.1.Final.jar:7.1.1.Final]
	at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1811) [jboss-msc-1.0.2.GA.jar:1.0.2.GA]
	at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1746) [jboss-msc-1.0.2.GA.jar:1.0.2.GA]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110) [rt.jar:1.7.0_06]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603) [rt.jar:1.7.0_06]
	at java.lang.Thread.run(Thread.java:722) [rt.jar:1.7.0_06]
and the content in warproduct file is listed as below:
<?pde version="3.5"?>
<product name="example product" uid="example" useFeatures="false" includeLaunchers="false">
   <plugins>
      <plugin id="javax.xml"/>
      <plugin id="org.eclipse.core.commands"/>
      <plugin id="org.eclipse.core.contenttype"/>
      <plugin id="org.eclipse.core.jobs"/>
      <plugin id="org.eclipse.core.runtime"/>
      <plugin id="org.eclipse.equinox.app"/>
      <plugin id="org.eclipse.equinox.common"/>
      <plugin id="org.eclipse.equinox.http.registry"/>
      <plugin id="org.eclipse.equinox.http.servlet"/>
      <plugin id="org.eclipse.equinox.http.servletbridge"/>
      <plugin id="org.eclipse.equinox.preferences"/>
      <plugin id="org.eclipse.equinox.registry"/>
      <plugin id="org.eclipse.equinox.servletbridge"/>
      <plugin id="org.eclipse.equinox.servletbridge.extensionbundle" fragment="true"/>
      <plugin id="org.eclipse.osgi"/>
      <plugin id="org.eclipse.osgi.services"/>
      <plugin id="org.eclipse.rap.examples"/>
      <plugin id="org.eclipse.rap.examples.pages"/>
      <plugin id="org.eclipse.rap.jface"/>
      <plugin id="org.eclipse.rap.jface.nl_zh" fragment="true"/>
      <plugin id="org.eclipse.rap.rwt"/>
      <plugin id="org.eclipse.rap.rwt.nl_zh" fragment="true"/>
   </plugins>
   <configurations>
      <plugin id="javax.xml" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.core.commands" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.core.contenttype" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.core.jobs" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.core.runtime" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.app" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.common" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.http.registry" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.http.servlet" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.http.servletbridge" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.preferences" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.registry" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.servletbridge" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.osgi" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.osgi.services" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.rap.examples" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.rap.examples.pages" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.rap.jface" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.rap.rwt" autoStart="true" startLevel="0" />
   </configurations>
   <warConfiguration webXml="/org.eclipse.rap.examples/WEB-INF/web.xml" launchIni="/org.eclipse.rap.examples/WEB-INF/launch.ini">
   <libraries>
      <library path="org.eclipse.equinox.servletbridge_1.2.200.v20120912-125810.jar" fromTarget="true"/>
   </libraries>
   </warConfiguration>
</product>
BTW I can run the examples application in my eclipse ide but can not export war file to run jee container.
Thank you again.
David
[Updated on: Thu, 15 November 2012 15:37]
Report message to a moderator
Re: require document for deploy rwt standalone to jee container like tomcat or jboss? [message #985995 is a reply to message #985635] Sat, 17 November 2012 06:32 Go to previous messageGo to next message
Hi Ralf, I said how to desploy RWT STANDALONE APPLICATION as WAR to jee container, NOT RAP WORKBENCH APP, would you please to give a guide?
Thank you.
David
Re: require document for deploy rwt standalone to jee container like tomcat or jboss? [message #986351 is a reply to message #984264] Tue, 20 November 2012 08:20 Go to previous messageGo to next message
ABOUT HOW TO DESPLOY RWT STANDALONE APP TO TOMCAT?
Re: require document for deploy rwt standalone to jee container like tomcat or jboss? [message #986359 is a reply to message #986351] Tue, 20 November 2012 08:47 Go to previous messageGo to next message
David,
First off, please understand that this is a forum to help each other and
not a machine where you throw your problems in and get a solution.
There's no point demanding a solution and usually shouting does not
motivate others to help you.
In your stacktrace you have a ClassNotFoundException. What did you do to
analyze this problem? What does 'ss' in the console give you? Did you
validate your dependencies?
Ralf
Ralf Sternberg
Re: require document for deploy rwt standalone to jee container like tomcat or jboss? [message #986571 is a reply to message #984264] Wed, 21 November 2012 00:55 Go to previous message
hi Ralf,
First, thanks again for your reply.Secondly, I am also very happy to help other friends. Do not bother, I encountered problems in using RAP, and I believe that other people may encounter the same problem, take a look at this post hits in, you'll know. Everyone to ask their questions, and then solve the problem, and improve the RAP together What's wrong with it?
Thank you again
Hoping Rap is getting better and better, more powerful.
David
Previous Topic:File Upload Support in RAP 2.0
Next Topic:Problems with theming in the WAR-File
Current Time: Tue May 22 04:35:56 GMT 2018
Powered by FUDForum. Page generated in 0.01815 seconds
