Problem getting 2.1 to run on Suse Linux 8.2 [message #142559] |
Sat, 11 October 2003 03:47 |
Originally posted by: paul. comp.net
I cannot get Eclipse 2.1 to run on Suse 8.2. Listed below is the stack dump.
I would aprpeciateyour assistance.
Paul
org.eclipse.swt.SWTException: Unsupported or unrecognized format
at org.eclipse.swt.SWT.error(SWT.java:2332)
at org.eclipse.swt.SWT.error(SWT.java:2262)
org.eclipse.swt.internal.image.FileFormat.load(FileFormat.ja va:73)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 24)
at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:311)
org.eclipse.jface.resource.URLImageDescriptor.getImageData(U RLImageDescriptor.java:51)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:118)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:94)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:83)
org.eclipse.jface.action.ActionContributionItem$ImageCache.g etImage(ActionContributionItem.java:117)
org.eclipse.jface.action.ActionContributionItem.updateImages (ActionContributionItem.java:719)
org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionItem.java:596)
org.eclipse.jface.action.ActionContributionItem.fill(ActionC ontributionItem.java:302)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :555)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :456)
at org.eclipse.jface.action.MenuManager.fill(MenuManager.java:2 09)
org.eclipse.jface.action.MenuManager.createMenuBar(MenuManag er.java:146)
org.eclipse.jface.window.ApplicationWindow.configureShell(Ap plicationWindow.java:244)
org.eclipse.ui.internal.WorkbenchWindow.configureShell(Workb enchWindow.java:578)
at org.eclipse.jface.window.Window.createShell(Window.java:350)
at org.eclipse.jface.window.Window.create(Window.java:301)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1068)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:874)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Re: Problem getting 2.1 to run on Suse Linux 8.2 [message #142791 is a reply to message #142559] |
Sun, 12 October 2003 19:00 |
Originally posted by: chaves.nospam.inf.ufsc.br
Did you use Konqueror to extract Eclipse ZIP? You should use unzip. See:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#konquerorUnzip
> Paul
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.04335 seconds
