Home » Eclipse Projects » GEF » How to run the GEF redbook example
How to run the GEF redbook example [message #142304] Fri, 09 July 2004 21:37 Go to next message
Originally posted by: bandrews.bphnx.com
I am new to Eclipse and GEF and I am trying to learn from the redbook
example SAL330REditorExample. I went through the tutorial step by step,
compiled the example and tried to run it as a plug-in. The problem is the
authors don't tell you how to invoke the plug-in. I put the jar file and
plug-in.xml file in the plugins/com.ibm.itso.sal330r.editor directory,
started the runtime Workbench, but I don't see any way of invoking it.
Very frustrating! How do I do this? I believe there are no problems with
the plug-in, because I don't get any error messages in the console of the
dev Workbench.
Any help is greatly appreciated!
thanks,
Barry
Re: How to run the GEF redbook example [message #142314 is a reply to message #142304] Fri, 09 July 2004 21:45 Go to previous messageGo to next message
Originally posted by: meowmeow64.yahoo.co.kr
Which version eclipse and gef are you using? I think that one required 2.1
and gef 2.1. Mine worked fine with that setup.
When I tried with 3.0, I have to go through code and modify some of
imcompatible features on their example plugin.
Barry Andrews wrote:
> dev Workbench.
> thanks,
> Barry
Re: How to run the GEF redbook example [message #142333 is a reply to message #142314] Sat, 10 July 2004 00:01 Go to previous messageGo to next message
Hi John,
Then it will be hard for me to study how the example works because I am
using Eclipse 3.0 and GEF 3.0. But it did compile fine and I don't get any
errors, just a few deprecation warnings which should be okay.
So how do you start the editor once it is deployed?
I don't suppose you would mind zipping up your project directory for
the one you tried with 3.0 and emailing it to me? I would really
appreciate it.
bandrews_at_bphnx.com
Barry
> > Hi,
> > dev Workbench.
> > thanks,
> > Barry
Re: How to run the GEF redbook example [message #142354 is a reply to message #142333] Sat, 10 July 2004 21:08 Go to previous messageGo to next message
I sent files. check your email.
thanks,
john LEe
> Hi John,
> appreciate it.
> Barry
> > > Hi,
> > > dev Workbench.
> > > thanks,
> > > Barry
Re: How to run the GEF redbook example [message #143983 is a reply to message #142354] Thu, 22 July 2004 17:00 Go to previous messageGo to next message
Originally posted by: arungoyal03.yahoo.com
Hi John,
Is it possible to post the files somewhere so that everyone can access them
Arun
"John Lee" <meowmeow64@yahoo.co.kr> wrote in message
news:ccplrm$flv$1@eclipse.org...
> thanks,
> john LEe
> > Hi John,
am
any
> > appreciate it.
> > Regards,
> > Barry
2.1
> > > > Hi,
redbook
step,
is the
and
directory,
it.
with
of the
> > > > dev Workbench.
> > > > thanks,
> > > > Barry
Re: How to run the GEF redbook example [message #143991 is a reply to message #142354] Thu, 22 July 2004 17:02 Go to previous messageGo to next message
Hi John,
Is it possible to post the files somewhere...they will be useful for anyone
using the redbook
examples.
Arun
> thanks,
> john LEe
> > Hi John,
am
any
> > appreciate it.
> > Regards,
> > Barry
2.1
> > > > Hi,
redbook
step,
is the
and
directory,
it.
with
of the
> > > > dev Workbench.
> > > > thanks,
> > > > Barry
Re: How to run the GEF redbook example [message #144266 is a reply to message #142304] Sat, 24 July 2004 10:16 Go to previous message
Originally posted by: yogender.globalworldtech.com
Hello
I am writing GEf and RCP applicatio. I need that example you are talking
about.
Can you send me the link for that example
Yogender
> dev Workbench.
> thanks,
> Barry
Previous Topic:acyclic compound directed graph
Next Topic:Why can't i create a ScrollingGraphicalViewer in my application?
Current Time: Mon Jun 18 06:08:33 GMT 2018
Powered by FUDForum. Page generated in 0.01604 seconds
