Converting IFile to IDocument [message #982652] |
Tue, 13 November 2012 09:54 |
Kivanc Muslu Messages: 153 Registered: November 2010 |
Hi all,
I was using the following method calls to convert an IFile to an IDocument:
IDocumentProvider provider = new TextFileDocumentProvider();
provider.connect(file); // file is of IFile
IDocument document = provider.getDocument(file);
provider.disconnect(file);
However, this code runs in a headless Eclipse instance that I create (with -nosplash option) and it turns out that running any code that requires UI operations (especially access to the UI Thread) is not a good idea for headless applications. For once, on Mac, it turns out that the UI thread can only be initialized with the main thread, which causes a couple of problems.
So, I was wondering whether there is a way to convert an IFile object to an IDocument object without touching UI thread (and/or code)?
Thanks in advance, best regards,
[Updated on: Tue, 13 November 2012 09:56] Report message to a moderator
Re: Converting IFile to IDocument [message #983246 is a reply to message #982790] |
Tue, 13 November 2012 19:59 |
Hi Dani,
Thanks for the reply.
I have looked at the TextFileDocumentProvider#createFileInfo() code and created the following code sequence for my purposes:
ITextFileBufferManager manager = FileBuffers.getTextFileBufferManager();
LocationKind locationKind = LocationKind.IFILE;
IPath location = file.getFullPath();
manager.connect(location, locationKind, null);
ITextFileBuffer fileBuffer = manager.getTextFileBuffer(location, locationKind);
IDocument result = fileBuffer.getDocument();
manager.disconnect(location, locationKind, null);
return result;
When I run the code on the headless Eclipse application, I get the following error though: (the trace is quite long, sorry).
***WARNING: Display must be created on main thread due to Cocoa restrictions.
!ENTRY org.eclipse.equinox.preferences 4 2 2012-11-13 11:51:48.486
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.equinox.preferences".
!STACK 0
java.lang.ExceptionInInitializerError
at org.eclipse.jdt.ui.PreferenceConstants.initializeDefaultValues(PreferenceConstants.java:3739)
at org.eclipse.jdt.internal.ui.JavaUIPreferenceInitializer.initializeDefaultPreferences(JavaUIPreferenceInitializer.java:38)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper$1.run(PreferenceServiceRegistryHelper.java:300)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.runInitializer(PreferenceServiceRegistryHelper.java:303)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelper.java:131)
at org.eclipse.core.internal.preferences.PreferencesService.applyRuntimeDefaults(PreferencesService.java:368)
at org.eclipse.core.internal.preferences.DefaultPreferences.applyRuntimeDefaults(DefaultPreferences.java:166)
at org.eclipse.core.internal.preferences.DefaultPreferences.load(DefaultPreferences.java:237)
at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:410)
at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:663)
at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:805)
at org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractScope.java:38)
at org.eclipse.core.runtime.preferences.DefaultScope.getNode(DefaultScope.java:76)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultPreferences(ScopedPreferenceStore.java:250)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferenceNodes(ScopedPreferenceStore.java:285)
at org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet(ScopedPreferenceStore.java:475)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean(ScopedPreferenceStore.java:387)
at org.eclipse.jdt.internal.ui.preferences.MembersOrderPreferenceCache.install(MembersOrderPreferenceCache.java:61)
at org.eclipse.jdt.internal.ui.JavaPlugin.ensurePreferenceStoreBackwardsCompatibility(JavaPlugin.java:426)
at org.eclipse.jdt.internal.ui.JavaPlugin.start(JavaPlugin.java:373)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.core.internal.filebuffers.ExtensionsRegistry.getExtension(ExtensionsRegistry.java:227)
at org.eclipse.core.internal.filebuffers.ExtensionsRegistry.doGetDocumentSetupParticipants(ExtensionsRegistry.java:352)
at org.eclipse.core.internal.filebuffers.ExtensionsRegistry.getDocumentSetupParticipants(ExtensionsRegistry.java:369)
at org.eclipse.core.internal.filebuffers.ResourceExtensionRegistry.getDocumentSetupParticipants(ResourceExtensionRegistry.java:119)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBufferManager.createEmptyDocument(ResourceTextFileBufferManager.java:144)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer.initializeFileBufferContent(ResourceTextFileBuffer.java:285)
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer.create(ResourceFileBuffer.java:245)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager.connect(TextFileBufferManager.java:112)
at com.kivancmuslu.www.solstice.eclipse.ResourceUtility.convertToDocument(ResourceUtility.java:125)
at com.kivancmuslu.www.solstice.logic.serialization.FileSerialization.deserializeToDocument(FileSerialization.java:45)
at com.kivancmuslu.www.solstice.logic.serialization.TextSelectionSerialization.deserialize(TextSelectionSerialization.java:58)
at com.kivancmuslu.www.solstice.client.logic.SolsticeElementChangedNotifier.processTextSelectionChangedMessage(SolsticeElementChangedNotifier.java:41)
at com.kivancmuslu.www.solstice.client.SolsticeClient.processTextSelectionChangedMessage(SolsticeClient.java:140)
at com.kivancmuslu.www.solstice.client.SolsticeClient.processMessage(SolsticeClient.java:132)
at com.kivancmuslu.www.solstice.client.SolsticeClientThread.run(SolsticeClientThread.java:70)
at java.lang.Thread.run(Thread.java:680)
Caused by: org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4361)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Display.error(Display.java:1068)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:825)
at org.eclipse.swt.widgets.Display.create(Display.java:808)
at org.eclipse.swt.graphics.Device.<init>(Device.java:130)
at org.eclipse.swt.widgets.Display.<init>(Display.java:699)
at org.eclipse.swt.widgets.Display.<init>(Display.java:690)
at org.eclipse.swt.widgets.Display.getDefault(Display.java:1386)
at org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverter.java:81)
... 61 more
!ENTRY org.eclipse.osgi 4 0 2012-11-13 11:51:48.494
!MESSAGE An error occurred while automatically activating bundle org.eclipse.jdt.ui (160).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.jdt.internal.ui.JavaPlugin.start() of bundle org.eclipse.jdt.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:283)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:308)
at org.eclipse.jface.resource.JFaceResources.getFontRegistry(JFaceResources.java:342)
at org.eclipse.jdt.internal.ui.JavaPlugin.ensurePreferenceStoreBackwardsCompatibility(JavaPlugin.java:448)
... 37 more
Root exception:
!ENTRY org.eclipse.equinox.registry 4 1 2012-11-13 11:51:48.496
!MESSAGE Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.JavaDocumentSetupParticipant.
!STACK 0
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jdt.ui (160).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.jdt.internal.ui.JavaPlugin.start() of bundle org.eclipse.jdt.ui.
... 31 more
... 37 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-11-13 11:52:16.140
!STACK 0
... 31 more
... 37 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-11-13 11:52:16.142
!STACK 0
... 31 more
... 37 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-11-13 11:52:27.484
!STACK 0
... 31 more
... 37 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-11-13 11:52:27.486
!STACK 0
... 31 more
... 37 more
It looks like ITextFileBufferManager#connect indirectly tries to access the UI thread again, causing similar exceptions. Shall I try using ITextFileBuffer without getting them through the manager?
Thank you,
Re: Converting IFile to IDocument [message #984060 is a reply to message #983246] |
Wed, 14 November 2012 11:13 |
Dani Megert Messages: 3802 Registered: July 2009 |
On 13.11.2012 20:59, Kivanc Muslu wrote:
> Hi Dani,
> locationKind);
> return result;
> restrictions.
This indicates that you also have UI plug-ins in your target. They can
extend core bundles and will be loaded if needed. You need to remove the
ui bundles from your target.
Dani
> !STACK 0
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 61 more
> !STACK 0
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> ... 31 more
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> ... 31 more
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> ... 31 more
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> ... 31 more
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.jdt.ui.
> at
> at
> at
> at
> at
> at
> at
> ... 31 more
> argument:
> at
> at
> at
> at
> at
> at
> ... 37 more
> Thank you,
Re: Converting IFile to IDocument [message #985246 is a reply to message #985232] |
Thu, 15 November 2012 09:03 |
Is there a way for me to diagnose (which bundle creates the problem) and make sure that it is not loaded. What might be the reason of that bundle loading?
Thank you,
Edit: I thought that the way I create the headless Eclipse in my plug-in (i.e., internal Eclipse), might help, here is the code:
// Get Eclipse workspace location and hash it.
String wsPath = ResourceUtility.getInstance().getWorkspacePath();
String workspacePostfix = Checksum.getInstance().hashToHexString(wsPath);
String eclipseExecutable = System.getProperty("eclipse.launcher");
String shadowWorkspacePath = CommonConstants.SHADOW_WORKSPACE_ROOT + CommonConstants.PS
+ workspacePostfix;
// We cannot have -consoleLog switch on Windows environment as it creates a command line
// for the headless Eclipse, which kills all the idea of being headless. Until we have a
// better solution, let's detect the OS and don't pass that switch when it is Windows.
ArrayList<String> eclipseArguments = new ArrayList<String>();
eclipseArguments.add(eclipseExecutable);
String osName = System.getProperty("os.name");
boolean isWindows = isWindows(osName);
if (!isWindows)
eclipseArguments.add("-consoleLog");
eclipseArguments.add("-data");
eclipseArguments.add(shadowWorkspacePath);
eclipseArguments.add("-nosplash");
eclipseArguments.add("-application");
eclipseArguments.add("com.kivancmuslu.www.solstice.client.application");
Process process = Runtime.getRuntime()
.exec(eclipseArguments.toArray(new String[eclipseArguments.size()]));
[Updated on: Thu, 15 November 2012 09:35] Report message to a moderator
FUDForum. Page generated in 0.04464 seconds
