Home » Modeling » EMF » Problem referencing another emf project
Problem referencing another emf project [message #982020] Mon, 12 November 2012 22:08 Go to next message
Eyal Heinemann is currently offline Eyal HeinemannFriend
Hi again,
I have two emf projects, the first I got an outer package (meaning i cant change it) and another is my own.
The first one has a "MainContainer" item which is usually the object in which the rest take place in.
In my project I need to hold in one of my projects two "MainContainer"s.
So I added in my ecorediag an EDataType that reference the interface of "MainContainer".
Since it's an EDataType I cant create an EReference to it only an EAttribute.
Also when I try to save my object it doesn't save all the data but just writes something as an attribute that can't be parsed. Any advise on the situation?
I tried reading about it and got to something that is "BaseType" but eclipse gives only the option of making the interface the base type so I'm not sure what to do.
Re: Problem referencing another emf project [message #982391 is a reply to message #982020] Tue, 13 November 2012 05:12 Go to previous messageGo to next message
Eyal,
Comments below.
On 12/11/2012 11:08 PM, Eyal Heinemann wrote:
> Hi again,
> of "MainContainer".
> EAttribute.
Yes. So you really want an EClass? Isn't MainContainer already an EClass?
> on the situation?
It needs to be an an EClass.
What exactly is MainContainer? Something you hand wrote in Java?
> Thanks
Re: Problem referencing another emf project [message #983079 is a reply to message #982391] Tue, 13 November 2012 16:59 Go to previous messageGo to next message
The MainContainer is an EClass that came from a different EMF project (what i called the first)
The problem is in order to have it in my new EMF project i can only use it as EDataType.
Is there any way to use it as an EClass?
Thanks again
Re: Problem referencing another emf project [message #983090 is a reply to message #983079] Tue, 13 November 2012 17:11 Go to previous messageGo to next message
Eyal,
Comments below.
Why?
Just load the resource containing MainContainer in the editor where you
need it and start using it.
> Thanks again
Re: Problem referencing another emf project [message #983331 is a reply to message #983090] Tue, 13 November 2012 21:24 Go to previous messageGo to next message
Worked Great!!!! thank you so much
BTW - do i need to mark your replay as answer at some way?
Re: Problem referencing another emf project [message #983739 is a reply to message #983331] Wed, 14 November 2012 05:31 Go to previous message
Eyal,
No, there's no mechanism for marking posts. I guess the last or second
to last post is usually the answer...
Previous Topic:[EMF Transaction] Buglist still correct ?
Next Topic:[XSD2Ecore] is removing removing underscore from EEnumLiteral name and not setting literal
Current Time: Wed Jun 20 19:25:39 GMT 2018
Powered by FUDForum. Page generated in 0.01707 seconds
