newbie: Building now takes forever [message #141929] |
Thu, 09 October 2003 20:32 |
Originally posted by: mark.rmanet.com
Started using Eclipse Version: 3.0.0 Build id: 200308281813 a couple of
days ago. (Switching from JBuilder 6) I really like Eclipse but today I
come in and start Eclipse, edit a java file, build it to test the change.
It starts a full build and the build takes forever, I started it 15
minutes before lunch and came back from lunch and it's still running for
over an hour.
The build progress gets to 100% within a couple of minutes and then stays
there, memory usage keeps going up until it's used it memory and starts
garbage collecting (I think). I've set max memory to 512m (-vmargs
-Xmx512m).
The project is large ~3000 java classes, but until today it didn't take
long for it to build. I've turned off automatic builds.
I've killed and restarted Eclipse a couple of times with the same result.
I have the Perforce tool installed if that makes any difference.
Help, at this rate I'll have to go back to JBuilder, because I can't get
anything done. I'm not sure where to look for the problem.
Mark.
Re: newbie: Building now takes forever [message #142369 is a reply to message #141929] |
Fri, 10 October 2003 17:28 |
After playing with the problem filters, the build now works again.
Something about it trying to filter the list of warning and errors.
Mark.
> over an hour.
> -Xmx512m).
> Mark.
Re: newbie: Building now takes forever [message #144517 is a reply to message #142369] |
Wed, 15 October 2003 16:40 |
Originally posted by: John_Arthorne.oti.com_
This sounds like the following bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=44443
If not, please enter a new bug report.
> Mark.
>>over an hour.
>>-Xmx512m).
>>Mark.
FUDForum. Page generated in 0.02175 seconds
