| Postgres inet type [message #980721] |
Sun, 11 November 2012 18:05  |
Neikius Mising name Messages: 39 Registered: April 2011 |
Member |
So, using eclipselink and inet type is nicely cast to string when reading.
But on insert something is wrong:
Caused by: org.postgresql.util.PSQLException: ERROR: column "..." is of type inet but expression is of type character varying
Hint: You will need to rewrite or cast the expression.
So I must override using descriptor customizer? Is kinda strange since I can insert into that column the IP as normal string.
This gets generated, nothing special (And it dies):
Call: INSERT INTO "table" (columns ...) VALUES (?, ?, ?, ?, ?, ?, ?)
bind => [7 parameters bound]
And this WORKS:
VALUES (... '127.0.0.1' ...);
So when I call an ordinary query I can pass inet field as standard string and it all works. When a prepared statement it called via eclipselink and inet is bound as a string everything dies. A bug certiainly, but is there any workaround or a trick to make it work? Converter doesn't seem to work.
| Re: Postgres inet type [message #984694 is a reply to message #980721] |
Wed, 14 November 2012 17:37   |
Member |
Well I can always use a native query and I will for now.
@Chris: Yes it accepts param inet as inline string in a native query. The link you posted doesn't make it exactly clear (I am using java EE!) if I can just use @QueryHint annotation on a @Entity class to override the behaviour just for it? That would be perfect I guess. Does it do escaping if you do it like that automatically?
@James: The problem is I don't know. Manual doesn't say: http://www.postgresql.org/docs/9.2/static/datatype-net-types.html And yea, I am quite sure that is the problem. Strangely though it accepts string inline no problems. I guess I need to take this to postgre people.
[Updated on: Wed, 14 November 2012 17:44] Report message to a moderator
| Re: Postgres inet type [message #985744 is a reply to message #985698] |
Thu, 15 November 2012 17:14  |
Chris Delahunt Messages: 928 Registered: July 2009 |
Query hints apply only to the query they are added to, while if the propertiy is set in the persistence.xml it will apply to every query. So the @QueryHint neededs to be added within a named query annotation, not an entity. Example 4-27 needs improvement but I don't have an example handy at the moment, I'll try fixing the example tomorrow.
FUDForum. Page generated in 0.01733 seconds
