Redhat KDE or Gnome [message #141597] |
Sat, 04 March 2006 23:42 |
Originally posted by: ejpolson.comcast.net
I'm trying to run Eclipse on Redhat WS 4 update 2.
After installing Java 5, I download the Eclipse SDK and extract it to the
same directory where Java installed /opt. When I try to launch Eclipse, I
get the following error message dialog:
JVM terminated. Exit code = 1
/usr/bin/java
-Xms40m
-Xmx256m
-Jar /opt/eclipse/startup.jar
-os linux
-ws gtk
-arch x86
-launcher /opt/eclipse/eclipse
-name Eclipse
-showsplash 600
-exitdata 90005
-vm /usr/bin/java
-vm args
-Xms40m
-Xmx256m
-jar /opt/eclipse/startup.jar
The exitdata flag changes. For instance, the last three times I tried, it
returned 90005, then a0005, then b0005.
Any ideas on what I'm doing wrong? Any help is GREATLY apreciated
Re: Redhat KDE or Gnome [message #141631 is a reply to message #141597] |
Sun, 05 March 2006 14:06 |
Originally posted by: myersj.gmail.com
It looks like you're not using the Java version you downloaded:
/usr/bin/java
You can either modify your path so that the Java you installed shows up
first on the $PATH, or you can launch eclipse with the command line
option -vm /path/to/java
Hope this helps,
- Jeff
Re: Redhat KDE or Gnome [message #141674 is a reply to message #141597] |
Mon, 06 March 2006 08:03 |
> the same directory where Java installed /opt. When I try to launch
> Eclipse, I get the following error message dialog:
> /usr/bin/java
> -Xms40m
> -Xmx256m
> -os linux
> -ws gtk
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata 90005
> -vm /usr/bin/java
> -vm args
> -Xms40m
> -Xmx256m
> it returned 90005, then a0005, then b0005.
Have you added an entry to the alternatives system and updated the Java
symlinks that point to your new Java installation? This must be done on
FC4 so I think it must also be done on RH linux. Another way is to use
JPackage.org packages which provide source-RPMs for manually creating
Java-RPMs. With the RPMs you can integrate the Java installation into
your package management.
Kind regards,
Daniel
FUDForum. Page generated in 0.08736 seconds
