Linux SuSe 9.2 Pro debug problem [message #141237] |
Thu, 17 March 2005 20:22 |
Originally posted by: hakand.algonet.se
I have installed Eclipse and CDT versions as specified below.
I made a simple program. It compiled fine and it is possible to run.
But when I try to debug it, Eclipse crashes.
Before it chashes, it prints some information on the console. That text
disappears before I have been able to read it.
Is it possible to redirect the console to a file?
What could be the reason for the crash?
/Håkan
*** Date: 2005-03-17 21:10
*** Platform Details:
*** System properties:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=200406251208
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-showsplash
/usr/share/eclipse/eclipse -showsplash 600
-exitdata
/usr/share/eclipse/eclipse -exitdata 33580006
-data
/home/hakan/.eclipse
-vm
/usr/lib/jvm/jre/bin/java
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1111086714480
eclipse.vm=/usr/lib/jvm/jre/bin/java
eclipse.vmargs=-Xms64M
-Xmx256M
-cp
/usr/share/eclipse/startup.jar
org.eclipse.core.launcher.Main
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/usr/share/eclipse/startup.jar
java.class.version=48.0
java.endorsed.dirs=/usr/lib/jvm/java-1.4.2-sun-1.4.2.05/jre/ lib/endorsed
java.ext.dirs=/usr/lib/jvm/java-1.4.2-sun-1.4.2.05/jre/lib/e xt
java.home=/usr/lib/jvm/java-1.4.2-sun-1.4.2.05/jre
java.io.tmpdir=/tmp
java.library.path=/usr/lib/jvm/java-1.4.2-sun-1.4.2.05/jre/l ib/i386/client:/usr/lib/jvm/java-1.4.2-sun-1.4.2.05/jre/lib/ i386:/usr/lib/jvm/java-1.4.2-sun-1.4.2.05/jre/../lib/i386:/o pt/mozilla/lib
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_05-b04
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.FileSyste mPreferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_05
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_05-b04
line.separator=
org.osgi.framework.executionenvironment=
org.osgi.framework.language=sv
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.8-24-smp
org.osgi.framework.processor=i386
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.2.0
org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=/home/hakan/.eclipse/org.eclipse.platform_3 .0.0/configuration/org.eclipse.osgi/bundles
osgi.configuration.area=file:/home/hakan/.eclipse/org.eclips e.platform_3.0.0/configuration/
osgi.framework=file:/usr/share/eclipse/plugins/org.eclipse.o sgi_3.0.0/
osgi.framework.beginningstartlevel=1
osgi.framework.version=3.0.0
osgi.frameworkClassPath=core.jar, console.jar, osgi.jar, resolver.jar,
defaultAdaptor.jar, eclipseAdaptor.jar
osgi.install.area=file:/usr/share/eclipse/
osgi.instance.area=file:/home/hakan/.eclipse/
osgi.logfile=/home/hakan/.eclipse/.metadata/.log
osgi.manifest.cache=/home/hakan/.eclipse/org.eclipse.platfor m_3.0.0/configuration/org.eclipse.osgi/manifests
osgi.nl=sv_SE
osgi.os=linux
osgi.sharedConfiguration.area=file:/usr/share/eclipse/config uration/
osgi.splashLocation=/usr/share/eclipse/plugins/org.eclipse.p latform_3.0.0/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/usr/lib/jvm/java-1.4.2-sun-1.4.2.05/jre /lib/rt.jar:/usr/lib/jvm/java-1.4.2-sun-1.4.2.05/jre/lib/i18 n.jar:/usr/lib/jvm/java-1.4.2-sun-1.4.2.05/jre/lib/sunrsasig n.jar:/usr/lib/jvm/java-1.4.2-sun-1.4.2.05/jre/lib/jsse.jar: /usr/lib/jvm/java-1.4.2-sun-1.4.2.05/jre/lib/jce.jar:/usr/li b/jvm/java-1.4.2-sun-1.4.2.05/jre/lib/charsets.jar:/usr/lib/ jvm/java-1.4.2-sun-1.4.2.05/jre/classes
sun.boot.library.path=/usr/lib/jvm/java-1.4.2-sun-1.4.2.05/j re/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=unknown
user.country=SE
user.dir=/home/hakan/workspace
user.home=/home/hakan
user.language=sv
user.name=hakan
user.timezone=Europe/Stockholm
vendor=Apache Software Foundation
vendor-url=http://xml.apache.org/xalan-j
version=2.4.1
*** Features:
org.eclipse.platform (3.0.0) "Eclipse Platform"
org.eclipse.sdk (3.0.0) "Eclipse Project SDK"
*** Plug-in Registry:
org.apache.ant (1.6.1) "Apache Ant"
org.apache.lucene (1.3.0) "Apache Lucene"
org.eclipse.ant.core (3.0.0) "Ant Build Tool Core"
org.eclipse.ant.ui (3.0.0) "Ant UI"
org.eclipse.cdt (2.1.0) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.core (2.1.0) "C/C++ Development Tools Core"
org.eclipse.cdt.core.linux (2.1.0) "C/C++ Development Tools Core for Linux"
org.eclipse.cdt.debug.core (2.1.0) "C/C++ Development Tools Debug Model"
org.eclipse.cdt.debug.mi.core (2.1.0) "C/C++ Development Tools GDB/MI CDI
Debugger Core"
org.eclipse.cdt.debug.mi.ui (2.1.0) "C/C++ Development Tools GDB/MI CDI
Debugger UI"
org.eclipse.cdt.debug.ui (2.1.0) "C/C++ Development Tools Debugger UI"
org.eclipse.cdt.doc.user (2.1.0) "C/C++ Development User Guide"
org.eclipse.cdt.launch (2.1.0) "C/C++ Development Tools Launching Support"
org.eclipse.cdt.make.core (2.1.0) "C/C++ Standard make Build Core"
org.eclipse.cdt.make.ui (2.1.0) "C/C++ Standard make Build UI"
org.eclipse.cdt.managedbuilder.core (2.1.0) "C/C++ Managed Builder Core"
org.eclipse.cdt.managedbuilder.ui (2.1.0) "C/C++ Managed Builder UI"
org.eclipse.cdt.sdk (2.1.0) "Eclipse C/C++ Development Tools SDK"
org.eclipse.cdt.source (2.1.0) "Eclipse C/C++ Development Tools (Source)"
org.eclipse.cdt.source.linux.gtk.x86 (2.1.0) "Eclipse C/C++ Development
Tools (Source)"
org.eclipse.cdt.ui (2.1.0) "C/C++ Development Tools UI"
org.eclipse.compare (3.0.0) "Compare Support"
org.eclipse.core.boot (3.0.0) "Core Boot"
org.eclipse.core.expressions (3.0.0) "Expression Language"
org.eclipse.core.filebuffers (3.0.0) "File Buffers"
org.eclipse.core.resources (3.0.0) "Core Resource Management"
org.eclipse.core.resources.linux (3.0.0) "Core Resource Management Linux
Fragment"
org.eclipse.core.runtime (3.0.0) "Core Runtime"
org.eclipse.core.runtime.compatibility (3.0.0) "Core Runtime Plug-in
Compatibility"
org.eclipse.core.variables (3.0.0) "Core Variables"
org.eclipse.debug.core (3.0.0) "Debug Core"
org.eclipse.debug.ui (3.0.0) "Debug UI"
org.eclipse.help (3.0.0) "Help System Core"
org.eclipse.help.appserver (3.0.0) "Help Application Server"
org.eclipse.help.base (3.0.0) "Help System Base"
org.eclipse.help.ide (3.0.0) "Help System IDE"
org.eclipse.help.ui (3.0.0) "Help System UI"
org.eclipse.help.webapp (3.0.0) "Help System Webapp"
org.eclipse.jdt (3.0.0) "Eclipse Java Development Tools"
org.eclipse.jdt.core (3.0.0) "Java Development Tools Core"
org.eclipse.jdt.debug (3.0.0) "JDI Debug Model"
org.eclipse.jdt.debug.ui (3.0.0) "JDI Debug UI"
org.eclipse.jdt.doc.isv (3.0.0) "Eclipse JDT Plug-in Developer Guide"
org.eclipse.jdt.doc.user (3.0.0) "Eclipse Java Development User Guide"
org.eclipse.jdt.junit (3.0.0) "Java Development Tools JUnit support"
org.eclipse.jdt.junit.runtime (3.0.0) "Java Development Tools JUnit runtime
support"
org.eclipse.jdt.launching (3.0.0) "Java Development Tools Launching Support"
org.eclipse.jdt.ui (3.0.0) "Java Development Tools UI"
org.eclipse.jface (3.0.0) "JFace"
org.eclipse.jface.text (3.0.0) "JFace Text"
org.eclipse.ltk.core.refactoring (3.0.0) "Refactoring Core"
org.eclipse.ltk.ui.refactoring (3.0.0) "Refactoring UI"
org.eclipse.osgi (3.0.0) "OSGi System Bundle"
org.eclipse.osgi.services (3.0.0) "OSGi Release 3 Services"
org.eclipse.osgi.util (3.0.0) "OSGi R3 Utility Classes"
org.eclipse.platform.doc.isv (3.0.0) "Eclipse Platform Plug-in Developer
Guide"
org.eclipse.platform.doc.user (3.0.0) "Eclipse Workbench User Guide"
org.eclipse.platform.source.linux.gtk.x86 (3.0.0) "%pluginName"
org.eclipse.search (3.0.0) "Search Support"
org.eclipse.swt (3.0.0) "Standard Widget Toolkit"
org.eclipse.swt.gtk (3.0.0) "Standard Widget Toolkit for GTK 2.0"
org.eclipse.team.core (3.0.0) "Team Support Core"
org.eclipse.team.cvs.core (3.0.0) "CVS Team Provider Core"
org.eclipse.team.cvs.ssh (3.0.0) "CVS SSH Core"
org.eclipse.team.cvs.ssh2 (3.0.0) "CVS SSH2"
org.eclipse.team.cvs.ui (3.0.0) "CVS Team Provider UI"
org.eclipse.team.ui (3.0.0) "Team Support UI"
org.eclipse.text (3.0.0) "Text"
org.eclipse.tomcat (4.1.30) "Tomcat Wrapper"
org.eclipse.ui (3.0.0) "Eclipse UI"
org.eclipse.ui.cheatsheets (3.0.0) "Cheat Sheets"
org.eclipse.ui.console (3.0.0) "Console"
org.eclipse.ui.editors (3.0.0) "Default Text Editor"
org.eclipse.ui.externaltools (3.0.0) "External Tools"
org.eclipse.ui.forms (3.0.0) "Eclipse Forms"
org.eclipse.ui.ide (3.0.0) "Eclipse IDE UI"
org.eclipse.ui.intro (3.0.0) "Intro Plugin"
org.eclipse.ui.presentations.r21 (3.0.0) "R21 Presentation Plug-in"
org.eclipse.ui.views (3.0.0) "Views"
org.eclipse.ui.workbench (3.0.0) "Workbench"
org.eclipse.ui.workbench.compatibility (3.0.0) "Workbench Compatibility"
org.eclipse.ui.workbench.texteditor (3.0.0) "Text Editor Framework"
org.eclipse.update.configurator (3.0.0) "Install/Update Configurator"
org.eclipse.update.core (3.0.0) "Install/Update Core"
org.eclipse.update.core.linux (3.0.0) "Install/Update Core for Linux"
org.eclipse.update.scheduler (3.0.0) "Automatic Updates Scheduler"
org.eclipse.update.ui (3.0.0) "Install/Update UI"
org.junit (3.8.1) "JUnit Testing Framework"
*** User Preferences:
#Thu Mar 17 21:10:57 CET 2005
@org.eclipse.ui=3.0.0
/instance/org.eclipse.cdt.debug.ui/org.eclipse.debug.ui.Debu gView.org.eclipse.cdt.debug.ui.cDebug.show_full_paths=true
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAU NCH_PERSPECTIVES= <?xml
version\="1.0"
encoding\="UTF-8"?>\n<launchPerspectives>\n<launchPerspective
configurationType\="org.eclipse.cdt.launch.localCLaunch" mode\="run"
perspective\="org.eclipse.cdt.ui.CPerspective"/>\n</launchPerspectives >\n
/instance/org.eclipse.cdt.debug.ui/org.eclipse.cdt.debug.ui. SharedLibrariesView.org.eclipse.cdt.debug.ui.cDebug.show_ful l_paths=true
/instance/org.eclipse.cdt.debug.ui/org.eclipse.debug.ui.Brea kpointView.org.eclipse.cdt.debug.ui.cDebug.show_full_paths=t rue
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.cdt.core/enableBackgroundTypeCache=fal se
file_export_version=3.0
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_p erspective_on_suspend=always
@org.eclipse.cdt.debug.ui=2.1.0
@org.eclipse.cdt.core=2.1.0
@org.eclipse.cdt.ui=2.1.0
@org.eclipse.debug.ui=3.0.0
*** Update Manager Log:
Configuration=Sun Mar 13 17:17:47 CET 2005
Is current configuration=false
Configuration=Sun Mar 13 17:12:56 CET 2005
Configuration=Sun Mar 13 16:17:16 CET 2005
Configuration=Sun Mar 13 17:44:20 CET 2005
Re: Linux SuSe 9.2 Pro debug problem [message #141359 is a reply to message #141237] |
Fri, 18 March 2005 15:12 |
Originally posted by: knaser.telcordia.com
Ok I found what is the problem. Eclipse can not use nMake since it's a
script. Apparantly it can not run anything other than a binary. So I created
a program which just runs the script- nMake.
"H
FUDForum. Page generated in 0.01832 seconds
