Home » Eclipse Projects » BIRT » Updating jar Library
Updating jar Library [message #979373] Sat, 10 November 2012 21:46 Go to next message
Christoph Kiehn is currently offline Christoph KiehnFriend
I encountered the following problem:
I use a jar library in my Brit report. When I update this .jar lib my Birt report doesn't notice it and uses still the old one.
But after restarting BIRT the report uses the updated .jar lib.
Is there a possibility to avoid the restart of BIRT?
C
Re: Updating jar Library [message #982396 is a reply to message #979373] Tue, 13 November 2012 05:20 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
Is this with the designer? Are you using the jar as a resource or placing it in the class path of the designer?
Michael
Developer Evangelist, Silanis
Re: Updating jar Library [message #986095 is a reply to message #982396] Sun, 18 November 2012 19:02 Go to previous message
thanks for the reply.
Sorry that I'm late with my answer.
I'm using the .jar File via the Ressources.
I don't know what you exactly mean with the designer. I'm using the preview of BIRT
Meanwhile I tested a bit but I couldn't find a sense full answer.
The effect never occurs on my desktop computer at my office, but sometimes on my notebook (not always!!)
If I find an answer to this problem I will post it ....
C
Previous Topic:View BIRT report through a website
Next Topic:Child data set table name needs seeded on Parent table column value
Current Time: Mon Apr 23 11:52:37 GMT 2018
Powered by FUDForum. Page generated in 0.01984 seconds
