Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP&TopLink essentials: Entities with composite primary keys don't work?
TPTP&TopLink essentials: Entities with composite primary keys don't work? [message #141051] Fri, 06 March 2009 12:57 Go to next message
Torben Putkonen is currently offline Torben PutkonenFriend
Member
When I try to start our application in TPTP, I get the following exception
from TopLink:
Exception in thread "main" javax.persistence.PersistenceException:
Exception [TOPLINK-28018] (Oracle TopLink Essentials - 2.0 (Build 41
(03/30/2007))):
oracle.toplink.essentials.exceptions.EntityManagerSetupExcep tion
Exception Description: predeploy for PersistenceUnit [FoobarPU] failed.
Internal Exception: Exception [TOPLINK-7150] (Oracle TopLink Essentials -
2.0 (Build 41 (03/30/2007))):
oracle.toplink.essentials.exceptions.ValidationException
Exception Description: Invalid composite primary key specification. The
names of the primary key fields or properties in the primary key class
[com.xxx.entities.FoobarPK] and those of the entity bean class [class
com.xxx.entities.Foobar] must correspond and their types must be the same.
Also, ensure that you have specified id elements for the corresponding
attributes in XML and/or an @Id on the corresponding fields or properties
of the entity class.
oracle.toplink.essentials.internal.ejb.cmp3.EntityManagerSet upImpl.predeploy(EntityManagerSetupImpl.java:615)
oracle.toplink.essentials.internal.ejb.cmp3.JavaSECMPInitial izer.callPredeploy(JavaSECMPInitializer.java:146)
oracle.toplink.essentials.internal.ejb.cmp3.JavaSECMPInitial izer.initPersistenceUnits(JavaSECMPInitializer.java:226)
oracle.toplink.essentials.internal.ejb.cmp3.JavaSECMPInitial izer.initialize(JavaSECMPInitializer.java:242)
oracle.toplink.essentials.internal.ejb.cmp3.JavaSECMPInitial izer.initializeFromMain(JavaSECMPInitializer.java:278)
oracle.toplink.essentials.internal.ejb.cmp3.JavaSECMPInitial izer.getJavaSECMPInitializer(JavaSECMPInitializer.java:81)
oracle.toplink.essentials.ejb.cmp3.EntityManagerFactoryProvi der.createEntityManagerFactory(EntityManagerFactoryProvider. java:119)
javax.persistence.Persistence.createEntityManagerFactory(Per sistence.java:83)
at com.xxx.createEntityManagerFactory(xxx.java:225)
at com.xxx.Run.main(xxx.java:50)
Caused by: Exception [TOPLINK-28018] (Oracle TopLink Essentials - 2.0
TopLink gives this exception for all our entities which use composite
primary keys. However, the application runs fine without TPTP, and also
using Eclipse's debugger.
If I use EclipseLink 1.0.1 libraries the application also works with TPTP,
however we have to use older Toplink libraries.
Do you have any ideas what could cause this incompatibility?
Re: TPTP&TopLink essentials: Entities with composite primary keys don't work? [message #141062 is a reply to message #141051] Fri, 06 March 2009 15:51 Go to previous messageGo to next message
Eugene Chan is currently offline Eugene ChanFriend
Hi Pasi,
Which JVM are you using? (java.exe -version)
Please note neither Oracle JVM nor JRocket is tested and supported by TPTP.
Eugene
"Pasi Kovanen" <Pasi.Kovanen@iki.fi> wrote in message
news:57f09fba8be47f3896617e9e6dc99fbb$1@www.eclipse.org...
> from TopLink:
> (03/30/2007))):
> at
> at
> at
> at
> at
> at
> at
> at
Re: TPTP&TopLink essentials: Entities with composite primary keys don't work? [message #141095 is a reply to message #141062] Mon, 09 March 2009 07:26 Go to previous message
Member
I have tested with JVMs:
java version "1.5.0_17"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_17-b04)
Java HotSpot(TM) Client VM (build 1.5.0_17-b04, mixed mode, sharing)
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
Java HotSpot(TM) Client VM (build 1.5.0_06-b05, mixed mode)
Previous Topic:Unable to install TPTP Profiling on a new Eclipse 3.4.2 installation.
Next Topic:IWAT0005E The host localhost was not found.?
Current Time: Thu Feb 22 09:16:51 GMT 2018
Powered by FUDForum. Page generated in 0.01609 seconds
