HTML Syntax Highlighting? [message #140999] |
Wed, 28 September 2005 10:24 |
Originally posted by: pmoorhouse.legaladvicebureau.co.uk
It was my assumption that installing WST plugin would provide (x)html
syntax highlighting... is this not part of the feature set? If it is how
do I enable it?
Re: HTML Syntax Highlighting? [message #141038 is a reply to message #140999] |
Wed, 28 September 2005 14:13 |
Originally posted by: amywu.us.DELETETHISPART.ibm.com
I assume you did not really mean WST *plugin*. Installing WST only, instead
of the complete WTP should still give you (x)html syntax highlighting, and
it should already be enabled. You can find the HTML syntax highlighting
preferences under Preferences->Web and XML -> HTML Files -> HTML Styles
"Phil Moorhouse" <pmoorhouse@legaladvicebureau.co.uk> wrote in message
news:dhdr0v$j8h$1@news.eclipse.org...
> do I enable it?
FUDForum. Page generated in 0.02496 seconds
