Home » Modeling » EMF » Validator and generated source in xbase
Validator and generated source in xbase [message #976898] Thu, 08 November 2012 23:15 Go to next message
Michael Scharf is currently offline Michael ScharfFriend
is there a way to specify where to generate the validator class?
With xbase I have no reason to use @generated NO except for the
validator class. I use a src-gen directory for the
generated sources. But I have to modify the validator.
- is there a way to specify the directory of the validator?
- I actually use a sub-class outside of the src to implement
the validation. All I need in that case is to change the INSTANCE
of the validator. Unfortunately, the generated validator creates a
lot of warnings.
Michael
Michael Scharf
Wind River Systems GmbH
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Re: Validator and generated source in xbase [message #977155 is a reply to message #976898] Fri, 09 November 2012 04:19 Go to previous messageGo to next message
Michael,
Comments below.
On 09/11/2012 12:15 AM, Michael Scharf wrote:
No, it's generated in the util package.
Yes, we don't yet support defining constraints (other than invariant
operations).
The package, yes.
> lot of warnings.
I suppose mostly you'd like to be able to define the constraints in
Xcore itself, right?
> Michael
Re: Validator and generated source in xbase [message #978317 is a reply to message #977155] Sat, 10 November 2012 01:05 Go to previous messageGo to next message
Ed,
> I suppose mostly you'd like to be able to define the constraints in Xcore itself, right?
well, maybe, but my concern is that I want to strictly separate generated code form
hand-written code. I want to put the generated code into a src-gen directory which
essentially means it can be re-generated at any time. The validation *requires*
hand written code and this causes a problem.
I don't know if that is a known bug, but when I edit the xcore file and it contains
some errors *all* of my generated code is removed. We can easily re-produce it and
when that happens, we have to revert the generated code form the source code control
system in order to not loose the hand-written part.
That's why I *only* override the instance and I put the hand-written validator
into a non src-gen package.
Michael
On 09.11.2012 05:19, Ed Merks wrote:
> Michael,
> Comments below.
> Yes, we don't yet support defining constraints (other than invariant operations).
> The package, yes.
>> lot of warnings.
>> Michael
Michael Scharf
Re: Validator and generated source in xbase [message #978611 is a reply to message #978317] Sat, 10 November 2012 06:47 Go to previous message
Michael,
Comments below.
On 10/11/2012 2:05 AM, Michael Scharf wrote:
> Ed,
> generated code form
> directory which
> *requires*
So the best solution is not to require that.
> and it contains
That's Xtext builder behavior, but maybe we should refuse to generate
when there are errors and avoid the builder's cleanup phase where it
removes any files that didn't get regenerated. Please open a bugzilla.
> source code control
This only happens if you generated into the folder specified as
generated source folder. If you change it (via @GenModel annotations
created by the properties view) to a different folder, i.e., the src
folder, you'll get the same old behavior as standard *.genmodels.
> validator
Yes, it's not nice to have all your source wiped out. But even when
things are working properly, a clean builder will still wipe it out
unless you redirect generation (via GenModel annotations) not to use the
src-gen modeler.
> Michael
>> Michael,
>> Comments below.
>>> Hi,
>> operations).
>> The package, yes.
>>> lot of warnings.
>>> Michael
Previous Topic:[Xcore] Problem with an .xcore model refering to a class defined in a .ecore model
Next Topic:Bug ? Resolving Ecore Cross References
Current Time: Sat Apr 21 06:13:00 GMT 2018
Powered by FUDForum. Page generated in 0.02301 seconds
