Home » Eclipse Projects » NatTable » Get current selections
Get current selections [message #976656] Thu, 08 November 2012 19:04 Go to next message
Rashmy A is currently offline Rashmy AFriend
What is a good way to know the current selections in NatTable?
I'm in a command handler that does not have access to the selection layer.
Rashmy
Re: Get current selections [message #977346 is a reply to message #976656] Fri, 09 November 2012 07:56 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
if you need to access the current selection, you should let your command handler know about the SelectionLayer. The only other solution is, if you are using row selection behaviour, you can use the SelectionLayer as an Eclipse selection provider. But this only works with the RowSelectionModel.
Greez,
Dirk
Previous Topic:Sandy
Next Topic:Can't compile the nattable examples
Current Time: Sun Apr 22 02:43:04 GMT 2018
Powered by FUDForum. Page generated in 0.01819 seconds
