Home » Eclipse Projects » Eclipse Platform » [SOLVED] How to make sure that a plug-in starts running on a headless Eclipse instance?
icon10.gif  [SOLVED] How to make sure that a plug-in starts running on a headless Eclipse instance? [message #975211] Wed, 07 November 2012 17:49 Go to next message
Kivanc Muslu is currently offline Kivanc MusluFriend
Hi all,
I am writing a plug-in that spawns another headless Eclipse running on a different workspace. While spawning the headless Eclipse, I run the following process:
Runtime.getRuntime().exec(new String[] {
                                                        "<Eclipse executable path>",
                                                        "-data",
                                                        "<headless workspace>",
                                                        "-nosplash", "-application",
                                                        "<identifier for the application I'd like to run on the headless instance>"});
This works great, the application that I run on the headless (implements IAppilcation) loads immediately and two Eclipse instances can communicate through the network.
I would like to do the following though: For extensibility purposes, I want to be able to run arbitrary applications (or plug-ins) that are built for this headless Eclipse. The easiest way to do it would be (1) add the application ids to the exec() above (2) built the applications within the above application that is being run. However, for modularity purposes, both are not good.
I thought about defining a new plug-in that when loads checks the workspace it is working and if the workspace is equal to the headless workspace (which will be unique), starts running (returns otherwise). However, I am having problems on ensuring that this plug-in is loaded on the headless Eclipse instance.
I know three ways to load plug-ins in Eclipse so far:
1. IActivator: does not work for me as my plug-in does not make any contributions to the headless Eclipse and hence never activated.
2. IStartup: does not work either since as far as I understand, IStartup plug-in are only called if there is a UI (the headless Eclipse does not have a UI).
3. IApplication: does not work due to the reasons stated above (basically the names are dynamically generated).
Can I make a small tweak in any of the above loading mechanisms to fit into my needs? Is there any other loading mechanism for headless Eclipses that will make sure that a plug-in gets loaded (similar to IStartup for normal Eclipse) even if its services is not needed yet?
Thanks in advance, best regards,
[Updated on: Sun, 20 October 2013 21:01]
Report message to a moderator
Re: How to make sure that a plug-in starts running on a headless Eclipse instance? [message #975839 is a reply to message #975211] Thu, 08 November 2012 05:32 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Kivanc,<br>
<br>
Does it help to use a bundle activation policy?  I think you can
specify "eager" instead of "lazy":<br>
<blockquote>Bundle-ActivationPolicy: lazy<br>
</blockquote>
<br>
<div class="moz-cite-prefix">On 07/11/2012 6:49 PM, Kivanc Muslu
wrote:<br>
</div>
<blockquote cite="mid:k7e6v2$dhl$1@xxxxxxxxe.org" type="cite">Hi
all,
<br>
<br>
Eclipse, I run the following process: <br>
<br>
<br>
"&lt;Eclipse executable path&gt;",
<br>
                                                       "-data",
<br>
"&lt;headless workspace&gt;",
<br>
<br>
"&lt;identifier for the application I'd like to run on the
headless instance&gt;"});
<br>
<br>
<br>
instances can communicate through the network. <br>
<br>
<br>
plug-in is loaded on the headless Eclipse instance. <br>
<br>
activated.
<br>
<br>
<br>
<br>
not needed yet?
<br>
<br>
Thanks in advance, best regards, </blockquote>
<br>
</body>
</html>
Re: How to make sure that a plug-in starts running on a headless Eclipse instance? [message #1147362 is a reply to message #975839] Sun, 20 October 2013 21:01 Go to previous message
Sorry for the late reply.
The way I tackled this problem is the following:
In my IApplication (that is being run on the headless Eclipse), I have defined an extension point, where other plug-ins can extend my plug-in. My IApplication, looks for the extending plug-ins and runs them in a separate thread and manages their life cycle throughout.
It was more work than I wished it would be, but so far it works quite well and (I believe) also goes along with Eclipse philosophy.
Previous Topic:Editor extensions
Next Topic:Missing Dependencies
Current Time: Wed Apr 25 07:06:19 GMT 2018
Powered by FUDForum. Page generated in 0.01769 seconds
