Home » Modeling » UML2 Tools » How to visualize graphically .UML file(How to visualize graphically .UML file - UML2 tools)
How to visualize graphically .UML file [message #975133] Wed, 07 November 2012 16:23 Go to next message
edipo federle is currently offline edipo federleFriend
Hi, I am new here, but I i am following the http://wiki.eclipse.org/MDT/UML2/Getting_Started_with_UML2 tutorial and I dont know if I understand but, there is a way to visualize the file .uml generated? Like a UML diagram?
Re: How to visualize graphically .UML file [message #975384 is a reply to message #975133] Wed, 07 November 2012 20:52 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
Install the Papyrus UML editors from the Modeling category of the Juno
updates or Modeling wizard.
Ed Willink
> Thanks
Re: How to visualize graphically .UML file [message #975425 is a reply to message #975384] Wed, 07 November 2012 21:35 Go to previous messageGo to next message
Hi Ed, Thanks for answer, I have Papyrus installed here, I tried here, but I could not see de diagram, could give more information about this process, the file .uml that I have is what was generated from tutorial
Thanks again.
Re: How to visualize graphically .UML file [message #975879 is a reply to message #975425] Thu, 08 November 2012 06:19 Go to previous messageGo to next message
Did you think to look at http://wiki.eclipse.org/Papyrus_User_Guide?
What problems did you have following
http://wiki.eclipse.org/Papyrus_User_Guide#Create_a_diagram_from_an_existing_uml_file?
Explicit mention of Papyrus added to conclusion of UML Getting Started
tutorial.
Ed Willink
> Thanks again.
Re: How to visualize graphically .UML file [message #976120 is a reply to message #975879] Thu, 08 November 2012 10:26 Go to previous messageGo to next message
Hi Ed, Yes, I read the http://wiki.eclipse.org/Papyrus_User_Guide?#Model.2FDiagram_creation_wizard , you talk about item "Create a diagram from an existing uml file" correct?
So, I don't find the option "Initialize papyrus diagram"... I guess that the version of this manual is old...
Thanks again.
Re: How to visualize graphically .UML file [message #976246 is a reply to message #976120] Thu, 08 November 2012 12:28 Go to previous message
Sorry, I thought these problems had been fixed.
I know I had troubles in the past because I didn't expect to look in the
Model Explorer of the papyrus Perspective. Trying now I can't even get
my UML file to appear. Checking Bugzilla at least Bug 348847 and 348842
regarding Diagram creation are still open.
I suggest starting this question again using the correct newsgroup; the
eclipse.papyrus newsgroup/forum. Someone there may be more intelligent
than me.
Ed Willink
> correct?
> Thanks again.
Previous Topic:Install Error - UML Designer BeoNetwords in Indigo
Next Topic:UML2 Groovy - Opinions
Current Time: Sat May 26 02:27:22 GMT 2018
Powered by FUDForum. Page generated in 0.01993 seconds
