Home » Newcomers » Newcomers » No class files generated
No class files generated [message #139474] Tue, 21 February 2006 20:33 Go to next message
Originally posted by: bhsu.broadviewnet.com
I "touched something" and for some reason class files are no longer being
generated.
I've checked that the "Build Automatically" option is set. But when I
force a rebuild with "Project->Build Project" this still happens. The
output folder is set to <Project-Name>/bin and there are no files in this
directory
This happens with some projects in my workspace but not others, I looked
at all the project settings and could not find any difference.
My code compiles normally by running ant from the command line. Eclipse is
able to detect compilation errors in my code. When I compile from the
command line I can run the program from within eclipse. Everything's fine
except class files are not generated
Any suggestions?
Re: No class files generated [message #140898 is a reply to message #139474] Tue, 28 February 2006 20:02 Go to previous message
Originally posted by: eclipse3.rizzoweb.com
Ben Hsu wrote:
> Hi
> being generated.
> this directory
> is able to detect compilation errors in my code. When I compile from the
> fine except class files are not generated
> Any suggestions?
Is there anything listed for that project in your Problems view? My
first suspicion would be that there is some problem in the build path,
which will prevent the build from working.
Hope this helps,
Eric
Previous Topic:$CLASSPATH to Eclipse 3.1.x?
Next Topic:Uncaught Exceptions
Current Time: Tue Feb 20 17:50:05 GMT 2018
Powered by FUDForum. Page generated in 0.02774 seconds
