Home » Archived » Test and Performance Tools Platform (TPTP) » Profiling Standalone Application
Profiling Standalone Application [message #139429] Fri, 09 January 2009 03:05 Go to next message
Patrik Dufresne is currently offline Patrik DufresneFriend
I'm really new to TPTP and I cannot manage to monitor the execution of my
JavaApplication.
Here What I did step by step :
- Install a package (libstdc++2.10-glibc2.2_2.95.4-27_i386.deb) as
describe here :
http://goodenoughjava.blogspot.com/2008/10/profiling-with-ec lipse-tptp-problem.html
- Download tptp.runtime.allInOne.linux.gtk.x86-TPTP-4.5.1.zip
- Extract the archite to my desktopn, creating a new 'eclipse' folder
- Start Eclipse and load an existing Workspace (previously create by a
standard eclipse 3.4)
- Start my JavaApplication (to ensure it's still working)
- Configuration profiling as present it this demo :
http://www.eclipse.org/tptp/performance/documents/tutorials/ arm_viewlet_ClassLink/ClassLink_viewlet_swf.html
- Start the profiling
The issue I have :
- After the execution of the Application I expect the Profiling Monitor to
display some information about my profiling, but I get nothing. In the
presentation there is a line with '<monitoring> Profiling ...' and a sub
item with 'Application Response Measure ..'. In my case, I got
'net.homeip.entreprisesmd.jnotebook.ui.JNoteBook at laptop [PID:18418] and
not subitem.
Did I miss something ??
Thanks for your help
Patrik Dufresne
Re: Profiling Standalone Application [message #139662 is a reply to message #139429] Thu, 22 January 2009 11:54 Go to previous messageGo to next message
Asaf Yaffe is currently offline Asaf YaffeFriend
Patrik,
Have you tried using the TPTP Java Profiler (not the ARM collector...)?
When launching your application with the Profile option, select any of
the "Java 1.5+..." data collectors from the Monitor tab and click Profiler.
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: Profiling Standalone Application [message #139681 is a reply to message #139662] Mon, 26 January 2009 03:20 Go to previous messageGo to next message
Hi Asaf,
Thanks for your response.
I select the "Java profiling - JRE 1.5 or newer : Execution Time
Analysis". Is it the right thing ??
Re: Profiling Standalone Application [message #139768 is a reply to message #139681] Thu, 29 January 2009 10:46 Go to previous messageGo to next message
Patrik Dufresne wrote:
> Hi Asaf,
> Thanks
Yes it is. Were you able to profile your application and get results?
Asaf
Asaf Yaffe
Re: Profiling Standalone Application [message #139949 is a reply to message #139429] Thu, 05 February 2009 07:45 Go to previous message
Richard Y.S. HUANG is currently offline Richard Y.S. HUANGFriend
Patrik,
Guess you're using the Integrated Agent Controller. Could you please use
the standalone Agent Controller and try again? You can download it from
TPTP's website: http://www.eclipse.org/tptp/home/downloads/
Please follow the below instruction to set up the standalone Agent
Controller:
http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tptp.platform.agentcontroller/src-native-new/packaging_md/ linux/getting_started.html?root=TPTP_Project&view=co
Richard Y.S. HUANG | Tivoli CAM, Eclipse TPTP | huangys@cn.ibm.com
> my JavaApplication.
> describe here :
> The issue I have :
> to display some information about my profiling, but I get nothing. In
> the presentation there is a line with '<monitoring> Profiling ...' and a
> sub item with 'Application Response Measure ..'. In my case, I got
> and not subitem.
> Patrik Dufresne
Previous Topic:Linux TPTP is not working properly
Next Topic:OC4J and Agent Controller
Current Time: Mon Feb 26 02:16:46 GMT 2018
Powered by FUDForum. Page generated in 0.02282 seconds
