Home » Newcomers » Newcomers » why eclipse3.1 do not support GBK encoding
why eclipse3.1 do not support GBK encoding [message #139314] Tue, 21 February 2006 00:46 Go to next message
Originally posted by: lijiuwei.sparknet.com.cn
eclipse3.0 can support GBK encoding,but eclipse3.1 do not support GBK;this
is a big problem to me,can anyone help me?
Re: why eclipse3.1 do not support GBK encoding [message #139325 is a reply to message #139314] Tue, 21 February 2006 08:45 Go to previous message
Tom Hofmann is currently offline Tom HofmannFriend
Hi eclipseFan,
The set of available encodings depends on the VM you are using.
Note also that the combo box on the 'General > Workspace' preference
page does not list all available encodings - you may just be able to
type in the required encoding ("GBK") into the combo and press OK. The
dialog will show an error if the encoding is not available.
-tom
> GBK;this is a big problem to me,can anyone help me?
Previous Topic:How can I change to java API on local file system?
Next Topic:Generating plugin/feature build scripts with <eclipse.scriptBuild>
Current Time: Thu May 24 08:20:03 GMT 2018
Powered by FUDForum. Page generated in 0.02298 seconds
