Home » Modeling » EMF » Is it not possibile to use instance of eclass as map key?
Is it not possibile to use instance of eclass as map key? [message #972588] Mon, 05 November 2012 18:52 Go to next message
John M. is currently offline John M.Friend
I am trying to use an eclass instance as key of a map.
But it is the same object with a different hashcode. Is it not possible to do that?
Re: Is it not possibile to use instance of eclass as map key? [message #972651 is a reply to message #972588] Mon, 05 November 2012 20:01 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. DamusFriend
Hi, John,
EObjects use object identity for equals() comparison. The short answer
is "no". If you need to put them in a map, you can use the
IdentityHashMap or perhaps you can create a custom map that uses
EcoreUtil::equals(EObject, EObject) for comparison if you really need
structural equivalence.
Christian
On 2012-11-05 18:52:15 +0000, John M. said:
> Hello,
> to do that?
Re: Is it not possibile to use instance of eclass as map key? [message #973227 is a reply to message #972651] Tue, 06 November 2012 06:46 Go to previous messageGo to next message
Christian,
Actually you can of course have EObjects as the keys of a map, but you
can't (i.e., it's not supported to) override hashCode or equals. As
such x.equals(y) == (x == y) is always true for EObjects. So the John's
statement "they're the same object with different hashcode" is a
contradiction, i.e., if the hash codes are different, they're definitely
not the same object. Note that using mutable objects as keys in a map
is dangerous because any mutations of the object that affect the
hashCode will definitely corrupt the map.
On 05/11/2012 9:01 PM, Christian W. Damus wrote:
> Hi, John,
> answer is "no". If you need to put them in a map, you can use the
> Cheers,
> Christian
>> Hello,
Re: Is it not possibile to use instance of eclass as map key? [message #973587 is a reply to message #973227] Tue, 06 November 2012 13:04 Go to previous message
Hi, Ed,
Yes, it's because of the mutability of EObjects that I suggested using
them as keys in a map is not practical. (I assume that the
impossibility of a thing the OP already actually did was not in
question :-)
I suppose if you don't override the equals() and hashCode() methods,
then the behaviour of the map devolves to IdentityHashMap-like, but one
is often encouraged to implement these methods in things that are map
keys.
Thanks for the clarification.
cW
On 2012-11-06 06:46:55 +0000, Ed Merks said:
> Christian,
> John's statement "they're the same object with different hashcode" is a
> definitely not the same object. Note that using mutable objects as
> keys in a map is dangerous because any mutations of the object that
> affect the hashCode will definitely corrupt the map.
>> Hi, John,
>> Cheers,
>> Christian
>>> Hello,
>>> to do that?
Previous Topic:[XCore] GenModel-Importer cannot handle cyclic package imports
Next Topic:ecorediag class instance
Current Time: Sun Apr 22 12:52:09 GMT 2018
Powered by FUDForum. Page generated in 0.02403 seconds
