Home » Archived » Test and Performance Tools Platform (TPTP) » PC startProcess: Error (6006), invalid executable '/usr/lib/jvm/java-6-sun-1.6.0.07/jre/bin/java'
PC startProcess: Error (6006), invalid executable '/usr/lib/jvm/java-6-sun-1.6.0.07/jre/bin/java' [message #138675] Sun, 23 November 2008 20:49 Go to next message
Yuen-Chi Lian is currently offline Yuen-Chi LianFriend
I am trying to profile in Eclipse using the IAC but it has always been
failing with the error below. The path to the Java execution is valid, so
do you have any idea why it's not working?
Thanks.
<CommonBaseEvent creationTime="2008-11-23T20:28:35.125326Z"
globalInstanceId="A929BCF30001E98A26257275523C8C09" msg="PC
monitorProcessState: Failed to monitor process 807" severity="50"
version="1.0.1">
<sourceComponentId component="ProcessController"
componentIdType="TPTPComponent" componentType="Eclipse_TPTP"
executionEnvironment="TPTPProcessController.cpp, line 1749"
instanceId="101" location="kimmy" locationType="IPV4" processId="807"
subComponent="ProcessController" threadId="807"/>
<situation categoryName="ReportSituation">
<situationType reasoningScope="INTERNAL"
reportCategory="LOG" xmlns:xsi="http://www.w3.org/2001/XMLSchema-
instance" xsi:type="ReportSituation"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-11-23T20:28:35.136641Z"
globalInstanceId="A929BCF3000215BC7637B35255E3C861" msg="PC startProcess:
bin/java'" severity="50" version="1.0.1">
executionEnvironment="TPTPProcessController.cpp, line 1528"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-11-23T20:28:35.138283Z"
globalInstanceId="A929BCF300021C2533EF51592B3CE024" msg="Client
compatibility transport layer received an error command: &quot;Unable to
Start Process : File Not Found or Not Executable&quot;" severity="30"
version="1.0.1">
<sourceComponentId component="AgentController"
componentIdType="TPTPComponent" executionEnvironment="Connect2AC.c, line
2255" instanceId="1004" location="kimmy" locationType="IPV4"
processId="794" subComponent="Client Compatibility TL" threadId="794"
componentType="Eclipse_TPTP"/>
<situationType xmlns:xsi="http://www.w3.org/2001/
XMLSchema-instance" xsi:type="ReportSituation" reasoningScope="INTERNAL"
reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-11-23T20:28:54.713932Z"
globalInstanceId="A929BD06000AE4C21792812A0D8BE516" msg="Agent Controller
shutdown requested through ACTL" severity="30" version="1.0.1">
componentIdType="TPTPComponent" executionEnvironment="ACTLServer.c, line
376" instanceId="1005" location="kimmy" locationType="IPV4"
processId="794" subComponent="Agent Compatibility TL" threadId="794"
</situation>
</CommonBaseEvent>
Re: PC startProcess: Error (6006), invalid executable '/usr/lib/jvm/java-6-sun-1.6.0.07/jre/bin/java [message #138723 is a reply to message #138675] Mon, 24 November 2008 15:21 Go to previous messageGo to next message
Eugene Chan is currently offline Eugene ChanFriend
Does your user account has executible access on
'usr/lib/jvm/java-6-sun-1.6.0.07/jre/bin/java' and related libraries and
files?
Eugene
"Yuen-Chi Lian" <yuenchi.lian@gmail.com> wrote in message
news:ggcflc$bi5$1@build.eclipse.org...
> Thanks.
> version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
Re: PC startProcess: Error (6006), invalid executable '/usr/lib/jvm/java-6-sun-1.6.0.07/jre/bin/java [message #138746 is a reply to message #138675] Mon, 24 November 2008 20:01 Go to previous message
Bing Xu is currently offline Bing XuFriend
What's the output of your '/usr/lib/jvm/java-6-sun-1.6.0.07/jre/bin/java
-version'? What's the path of your IAC config file and can you post it?
Previous Topic:LocationEditor - GeneralProperties
Next Topic:how to run in standard mode
Current Time: Sun Feb 18 07:27:20 GMT 2018
Powered by FUDForum. Page generated in 0.01952 seconds
