Home » Newcomers » Newcomers » Subclipse credentials request problem(Repository connection via svn+ssh with Subclipse prompts for credentials indefinitely)
Re: Subclipse credentials request problem [message #971003 is a reply to message #970276] |
Sun, 04 November 2012 13:53 |
On 11/04/2012 05:02 AM, Nir Lisker wrote:
> Hello,
> I'm using Subclipse to connect to an SVN repository via svn+ssh and a
> private key (the server has the paired public key). The interface is
> SVNKit (Pure Java). After I enter the svn+ssh://repository... address I
> am prompted for credentials. I specify the username and private key file
> (I did not set a passphrase so it is left blank) and confirm. The window
> pops up again and this goes on indefinitely. No console message is
> provided.
> Note 1: Marking "Save information" seems to have no effect. If there is
> a cache I'm supposed to be deleting this could help. I already deleted
> the keyring file in eclipse.
> Note 2: I wasn't sure if the private key should be in SSH2 or OpenSSH
> formats, but I tried both and there is no difference.
> Specifications:
> Windows 7 64 bit
> eclipse 4.2.1 64 bit
> Subclipse 1.8.16
> Subversion client adapter 1.8.3
> SVNKit client adapter 1.7.5.1
> If there is any other information or log file I should provide I would
> be happy to do so.
Nir,
There is a dedicated Eclipse forum for this:
http://www.eclipse.org/forums/index.php/f/73/
NNTP: eclipse.technology.subversive
I don't know how active, but if it is, someone there has a much better
chance of knowing what you're facing.
You might also contact the SVNKit forum as you appear to have extra
steps beyond what is needed when targeting pure Subversion.
Re: Subclipse credentials request problem [message #972279 is a reply to message #971212] |
Mon, 05 November 2012 13:55 |
On 11/4/2012 10:53 AM, Nir Lisker wrote:
> Thanks Russell, I didn't see that eclipse forum; it doesn't seem to be
> so active but worth a try. I posted on subclipse.tigris.org but didn't
> get any reply for several days. I'll try SVNKit's forum. Part of the
> issue is not knowing which of the components (eclipse, subclipse,
> SVNKit) is the cause.
You've chosen SVNKit because you needed a Windows solution, right? When
I used Subclipse, I accessed Subversion from both Windows and Linux, but
the repository was on a Linux server, very easily set up.
If you need a total Windows solution, this won't help very much, but
here's my experience:
http://www.javahotchocolate.com/tutorials/subclipse.html
http://www.javahotchocolate.com/tutorials/subversion.html
I hope the other forum will be active. Have you tried stackoverflow?
Because you tag your question with the technologies involved, it's very
specific and people monitoring those tags get notified immediately. It's
often very fast.
Best of luck.
Re: Subclipse credentials request problem [message #972290 is a reply to message #972279] |
Mon, 05 November 2012 14:05 |
> often very fast.
> Best of luck.
Oh, I forgot to remind you that Git is also an option and an even better
one than Subversion. I don't personally use (Eclipse) eGit, preferring
the command line, but I have a colleague here who does use it
successfully. We all use Git, though.
You can get an Atlassian/Bitbucket Git account to host your project for
free. GitHub will also do it for free, but only if you're willing to
make it public. You can also set up Git on Windows yourself, though it's
a bit more of a challenge I think than Subversion with SVNKit (see
http://therightstuff.de/CommentView,guid,b969ea4d-8d2c-42af-9806-de3631f4df68.aspx
if interested). I set up and administered Git on Linux for over a year.
The best route, though, is Bitbucket.
If you get to the point where you'd like to throw in the towel on
Subversion, I might be a lot more help to you, just ask me. (And, the
eGit forum is pretty active, I think.)
Russ
Current Time: Thu Apr 25 12:24:51 GMT 2024
Powered by FUDForum. Page generated in 0.08812 seconds
