Home » Eclipse Projects » Eclipse 4 » Use workspace of eclipse 4.2 from eclipse 4.3
Use workspace of eclipse 4.2 from eclipse 4.3 [message #970141] Sat, 03 November 2012 21:50 Go to next message
Jim Jone is currently offline Jim JoneFriend
I have created an Eclipse 4 application using Eclipse 4.2.
Works ok.
I encountered a bug for which I was recommended to use Eclipse4.3
I downloaded Eclipse4.3 and opened my workspace (created and worked in 4.2).
When I launch my product it does not work. Error says that it can not resolve almost any of my bundles.
I don't get this. Isn't this case supposed to work out of the box?
Re: Use workspace of eclipse 4.2 from eclipse 4.3 [message #970142 is a reply to message #970141] Sat, 03 November 2012 21:53 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot CelaFriend
What does the error log say? It's most likely the javax.xml missing dependency bug which is already fixed for when creating new projects.
Re: Use workspace of eclipse 4.2 from eclipse 4.3 [message #970172 is a reply to message #970142] Sat, 03 November 2012 22:25 Go to previous messageGo to next message
If I uncheck the "Validate Plugins Automatically Prior to Launching" the error log is:
!SESSION Sun Nov 04 00:24:08 EET 2012 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2012-11-04 00:24:08.575
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
	at java.net.URLClassLoader$1.run(Unknown Source)
	at java.net.URLClassLoader.findClass(Unknown Source)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:626)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: Use workspace of eclipse 4.2 from eclipse 4.3 [message #970177 is a reply to message #970172] Sat, 03 November 2012 22:30 Go to previous messageGo to next message
Also when I go back to Eclipse 4.2 to load the workspace the UI is in bad shape:
index.php/fa/12185/0/
I have to restart 4.2 to work.
I also noticed that I can see the error log I opened in eclipse 4.3 from 4.2.
But how is that possible?
[Updated on: Sat, 03 November 2012 22:30]
Report message to a moderator
Re: Use workspace of eclipse 4.2 from eclipse 4.3 [message #972777 is a reply to message #970141] Mon, 05 November 2012 22:18 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Did you try restarting with -clean or -clearpersistedstate
It is likely that this new version does not include all the ui from your 4.2 installation.
Wim
Re: Use workspace of eclipse 4.2 from eclipse 4.3 [message #984173 is a reply to message #972777] Wed, 14 November 2012 13:22 Go to previous message
Dmitry A. is currently offline Dmitry A.Friend
Actually i have a similar problem. For Eclipse 4.3 i use this links:
http://download.eclipse.org/releases/kepler (EMF);
http://download.eclipse.org/e4/updates/0.12-I-builds/ (e4)
After installing all the components i try to use my Eclipse 4.2 workspace with Eclipse 4.3. And my app (one PartStack and 2 parts) works strange. My @PostCondtruct methods don't work. I see my part without anything. When i switch between my parts i have error in console:
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
Caused by: java.lang.NullPointerException
at s.d.manager.views.SettingsView.setFocus(SettingsView.java:329)
But my methods marked as @Focus are empty. May be someone have problem like that? My 4.2 workspace works fine with Eclipse 4.2.1.
Previous Topic:How to hide Minimize/Maximize Buttons from PartStack?
Next Topic:No MBasicPackage Interface
Current Time: Thu Jun 21 20:28:39 GMT 2018
Powered by FUDForum. Page generated in 0.02082 seconds
