Home » Eclipse Projects » Hudson » Hudson web page stops working(web interface malfunction)
Hudson web page stops working [message #968750] Fri, 02 November 2012 18:20 Go to next message
Oren Tal is currently offline Oren TalFriend
Hello, I am facing with a strange issue in the past few weeks.
My Jenkins web page (port 8080) seem to stop responding once in two weeks while the SRV is responsive and all other proccess seem to be working (Java).
I am running it on Linux Fedore core and my Jenkins version is 1.466.2
I do not think it is a release issue as I faced it before with previous version.
There is a suspicious issue that I encountered where the jenkins loses the file handle over /var/log/jenkins/jenkins.log . after log rotation, the file just stays empty, and when I view all file handles in the system, this file is not found there.
What should I do? Any logs or data I should elabore the forum with?
java version "1.7.0_07"
Java(TM) SE Runtime Environment (build 1.7.0_07-b10)
Java HotSpot(TM) 64-Bit Server VM (build 23.3-b01, mixed mode)
Sample from the /var/log/jenkins/jenkins.log:
INFO: Beginning extraction from war file
Jenkins home directory: /jenkins-server/Home found at: System.getProperty("JENKINS_HOME")
Nov 01, 2012 2:56:42 PM winstone.Logger logInternal
INFO: HTTP Listener started: port=8080
INFO: AJP13 Listener started: port=8009
Appreciate your assistance,
Oren.
Re: Hudson web page stops working [message #969623 is a reply to message #968750] Sat, 03 November 2012 11:41 Go to previous message
Steve Christou is currently offline Steve ChristouFriend
Sorry, this is the hudson forum, not jenkins.
 * @author Steven Christou
 * @dev    Hudson-ci
Previous Topic:Hudson role-based security
Next Topic:Hudson delete old bild problem
Current Time: Sat Jan 20 13:28:43 GMT 2018
Powered by FUDForum. Page generated in 0.01834 seconds
