Home » Archived » Test and Performance Tools Platform (TPTP) » Can't successfully launch profiler
Can't successfully launch profiler [message #137798] Fri, 31 October 2008 14:09 Go to next message
Clark Wright is currently offline Clark WrightFriend
I am trying to use tptp for some memory and cpu profiling on a standalone
app.
My config is JDK 1.5.9, Eclipse 3.4 and tptp 4.5.0.
When I first launch eclipse, if I start a profiling session, it loads to
51% (jvmti instrumenting) and hangs. The ACServer is started, the vm for
the app to be profiled is launched.
After cleaning that up, any other profiling attempts hang at 27%
(Launching Delegates).
Any suggestions or ideas as to what is going on?
Any other information I can provide?
Nothing ends up in log file.
Thank you,
- Clark.
Re: Can't successfully launch profiler [message #137871 is a reply to message #137798] Mon, 03 November 2008 14:59 Go to previous messageGo to next message
Eugene Chan is currently offline Eugene ChanFriend
Hi Clark,
Could you shut down Eclipse workbench, make sure there is no ACServer.exe
nor dangling java.exe running on your machine. Then restart Eclipse
workbench, go to Windows > Preferences > Integrated Agent Controller > Host,
and Test Connection on localhost to see if you have a successful connection
with the built-in Agent Controller (if the connection works okay, you should
also see an ACServer.exe started on your machine on demand).
Could you please check the workspace/.metadata/.log file for any error
message/stacktrace?
Eugene
"Clark Wright" <Clark.Wright@skillsoft.com> wrote in message
news:6aabf4ff21a5aa00e975f19b2683265d$1@www.eclipse.org...
> app.
> Thank you,
> - Clark.
Re: Can't successfully launch profiler [message #138102 is a reply to message #137871] Thu, 06 November 2008 15:37 Go to previous message
Eugene, thank you for the follow up.
I believe my workspace had become corrupt, and after wiping it off the
disk and starting over fresh, the test tools are now working.
- Clark.
Previous Topic:Adapter Configuration Editor does not work...
Next Topic:Lost in documentation
Current Time: Mon May 28 05:28:22 GMT 2018
Powered by FUDForum. Page generated in 0.01574 seconds
