Home » Modeling » TMF (Xtext) » Newline removed when model gets updated
Newline removed when model gets updated [message #965544] Wed, 31 October 2012 10:13 Go to next message
Jeff MAURY is currently offline Jeff MAURYFriend
Member
I am facing the following problem.
I want to implement a quick fix that does the following:
Imaging the following grammar:
Grammar: Item*;
Item: (label=STRING)? 'Token';
Now, under certain circonstances, my quickfix will add a label to Item that does not have a label. So it does it by updating the Item model and adding the label.
Now, imagine I have the following file content:
LABEL1 Token \n
Token\n
So when the second item gets updated with a new label, then it seems it gets inserted at the end of the previous Item, replacing whitespace characters, so I get:
LABEL1 TOKENLabel2 Token
Is there a way to change this behaviour ?
Re: Newline removed when model gets updated [message #972289 is a reply to message #965544] Mon, 05 November 2012 14:05 Go to previous messageGo to next message
Jan Koehnlein is currently offline Jan KoehnleinFriend
The quickfix relies on the serializer to transform the changes on the
semantic model back to the text.
Which serializer fragment are u using in the workflow of your language?
Please make sure to use
fragment = serializer.SerializerFragment
and not the old
fragment = parseTreeConstructor.ParseTreeConstructorFragment
If you do already use the new one, it's a bug.
Am 31.10.12 11:13, schrieb Jeff MAURY:
> Grammar: Item*;
> adding the label.
> LABEL1 Token \n
> Token\n
> Thanks
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Get professional support from the Xtext committers at www.typefox.io
Re: Newline removed when model gets updated [message #973383 is a reply to message #972289] Tue, 06 November 2012 09:38 Go to previous message
Member
I checked my .mwe2 file and I'm using the new serializer fragment:
// Serializer 2.0
fragment = serializer.SerializerFragment {
generateStub = false
I will try to setup a sample project to demonstrate the problem and then open a bug
Previous Topic:Serializing unassigned keyword needed by quick fix
Next Topic:How to speed up serialization
Current Time: Wed Apr 25 16:43:26 GMT 2018
Powered by FUDForum. Page generated in 0.01360 seconds
