Re: How to hide Minimize/Maximize Buttons from PartStack? [message #968413 is a reply to message #968410] |
Fri, 02 November 2012 12:47 |
@Sopot: he has to remove the plug-in from the product configuration, that is not a bug. And he has to start everything again from the product to update the runtime configuration. Most people don't know this and therefore update the runtime manually.
Where do you see a potential bug? To me everything sounds correct here.
Re: How to hide Minimize/Maximize Buttons from PartStack? [message #968537 is a reply to message #968494] |
Fri, 02 November 2012 14:36 |
Alex Kipling wrote on Fri, 02 November 2012 14:56@Lars A bug could be the following behaviour:
Importing "org.eclipse.e4.ui.workbench.addons.swt" makes the min/max buttons visible, even if I do not import the MinMax Addon to my e4 application Addons.
I had to remove the whole "org.eclipse.e4.ui.workbench.addons.swt" plugin, in order t ohide the Min/Max buttons for MpartStacks.
This is wrong, because it makes me unable to use another Addons.
Right behaviour should be:
the min/max Buttons are hidden by default. They are explicitely enabled by the MinMax Addon.
P.S.
I wrote you an Email to info(att)vogella.com, to call your attention to this theme.
Is that the wrong way to contact you?
IIRC there is a processor which gets executed upon bundle load that adds all addons of the bundle in the app model regardless of what you define from the e4xmi editor.. So basically you get an "all or nothing" behavior which IMHO is not right.
FUDForum. Page generated in 0.04919 seconds
