Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Path in generated EMTL files differ when in debug or deployed
[Acceleo] Path in generated EMTL files differ when in debug or deployed [message #964334] Tue, 30 October 2012 12:45 Go to next message
Ansgar Radermacher is currently offline Ansgar RadermacherFriend
I use Acceleo (3.3.1) to produce code programmatically. This works fine, unless a referenced script imports other scripts (created in different Acceleo projects). In a debug environment (second Eclipse instance), the generated EMTL files reference dependent files by means of relative paths, e.g. in file1.emtl
<imports href="../../.../myplugin/.../file2.emtl#/0"/>
However, when the plugins containing file1 and file2 are deployed, the reference becomes
<imports href="platform:/plugin/myplugin/@dot/.../file2.emtl#/0"/>
The problem is that file1 needs to be referenced differently to handle both cases: either via a URI of style platform:/plugin/... or an absolute path such as file:/your/machine/....
The relative path for file2.emtl is only resolved, if file1.emtl is referenced via an absolute path (without platform:/plugin). But, we need the platform:/plugin URI style for deployed plugins. Since I prefer not to handle two different cases, I would like to configure Acceleo in a way to produce references *always* via the platform:/plugin style. Is that possible?
Ansgar
Re: [Acceleo] Path in generated EMTL files differ when in debug or deployed [message #966174 is a reply to message #964334] Wed, 31 October 2012 20:21 Go to previous message
Ed Willink is currently offline Ed WillinkFriend
You should find that the relative paths are consistent provided you have
platform: consistently defined. Unfortunately EMF provides the required
registries but no standalone initialisation support. You therefore need
to initialize correctly.
You may find
org.eclipse.ocl.examples.domain.utilities.StandaloneProjectMap helpful
for initialization. (See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=360926#c7).
In the past, Acceleo tried to be helpful for simple use cases and this
was unhelpful for more interesting usage. After reviewing my code, it no
longer seems to be necessary to fight Acceleo's helpful behaviour. But
beware of helpful Acceleo URI changes if you have trouble.
Ed Willink
> reference becomes
> absolute path such as file:/your/machine/.... The relative path for
> possible?
> Thanks
> Ansgar
Previous Topic:[Acceleo] Importing the Acceleo source code as a Maven project
Next Topic:Executing a workflow (MWE) using a Model.xmi which is not part of a resource
Current Time: Mon Feb 19 08:45:46 GMT 2018
Powered by FUDForum. Page generated in 0.01825 seconds
