Home » Modeling » EMF » Setting Value via FeaturePath
Setting Value via FeaturePath [message #964226] Tue, 30 October 2012 10:59 Go to next message
Ludwig Moser is currently offline Ludwig MoserFriend
Hello!
i'm trying to set a value on one of my EMF objects
so i show this by a simple example
Person
name (simple attribute)
Address (another EMF Object)
street
so if i want to set a value by code from a EStructuralFeature
i simply call
Person.eSet(nameFeature, "new Name");
i did not see something for featurePaths, so i googled...
i found a blog entry of Tom Schindl (here)
and hoped this would solve my problem, but actually the value keeps null.
		// create a test object...
		Person p= MyFactory.eINSTANCE.createPerson();
		IEMFValueProperty mProp = EMFProperties.value(featurePath);
		mProp.setValue(p, "newGUID");
is this caused because Address is null when i try it?
as all Classes are EClasses (Person and Address) it should be possible to generate the objects (empty, all with default values).
my final question is:
is there a Class/Feature/Method available to achieve what i need? (could not find anything in the emf book either.
thanks for your help
ludwig
Re: Setting Value via FeaturePath [message #964341 is a reply to message #964226] Tue, 30 October 2012 12:51 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Am 30.10.12 11:59, schrieb Ludwig Moser:
> Hello!
> Quote:
>> Person
>> street
> i simply call
> (http://tomsondev.bestsolution.at/2011/05/06/interesting-new-feature-in-emf-databinding/)
That is not true 100% because maybe you want an instance of that is
derived from Address, it might even be that Address is abstract and one
can't even create an instance.
Tom
Re: Setting Value via FeaturePath [message #965349 is a reply to message #964341] Wed, 31 October 2012 06:51 Go to previous messageGo to next message
but is this supposed to work the way i try it or not?
in the meantime i created some code which does exactly what i want, but i have a dirty workaround for getting a new instance of an EClass.
is there a way to get the EClass from an feature? (so i can create a new instance with the factory from it.)
by now i have a static function which creates an Person when i pass the String 'Person' to it (that's what i call dirty...)
btw: in my (special) case i do not have abstract classes
Re: Setting Value via FeaturePath [message #966786 is a reply to message #965349] Thu, 01 November 2012 08:20 Go to previous message
Am 31.10.12 07:51, schrieb Ludwig Moser:
Like I said we can't do what you want in a generic way so - yes it is
supposed to NOT work.
yes getEType and then use EcoreUtil.create()
in your special case that might be true but it isn't for the generic
case eclipse databinding has to deal with.
Tom
Previous Topic:Creating instance of domain EClass
Next Topic:[CDO] Access to password on the server
Current Time: Mon Feb 19 14:23:22 GMT 2018
Powered by FUDForum. Page generated in 0.02091 seconds
