Home » Language IDEs » C / C++ IDE (CDT) » new installation of eclipse-CDT does not understand C++ language
new installation of eclipse-CDT does not understand C++ language [message #963469] Mon, 29 October 2012 21:04 Go to next message
Olivier Planchon is currently offline Olivier PlanchonFriend
After several problems with Eclipse I removed my installation and downloaded this file:
http://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/juno/SR1/eclipse-parallel-juno-SR1-linux-gtk-x86_64.tar.gz
I copied the archive contents in my home directory and lauched eclipse.
I asked for a new "hellow world C++ project".
The project does not compile because the words cin and cout are not recognized.
strangely, the #include <iostream> is okay to the compiler.
I am very new to eclipse. I spent the whole day trying to get it work. Your help is more than welcome Smile
Re: new installation of eclipse-CDT does not understand C++ language [message #964371 is a reply to message #963469] Tue, 30 October 2012 13:19 Go to previous messageGo to next message
This is a screenshot of what I get.
Thanks for helping Smile
index.php/fa/12141/0/
Re: new installation of eclipse-CDT does not understand C++ language [message #964376 is a reply to message #963469] Tue, 30 October 2012 13:17 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 10/29/2012 8:51 PM, Olivier Planchon wrote:
> Hi, After several problems with Eclipse I removed my installation and
> recognized.
> Your help is more than welcome :)
Olivier,
You'll likely want the help of the Eclipse CDT forum rather than this
one. See
http://www.eclipse.org/forums/index.php/t/161206/
Bonne chance !
Re: new installation of eclipse-CDT does not understand C++ language [message #965438 is a reply to message #964376] Wed, 31 October 2012 08:28 Go to previous messageGo to next message
Axel Mueller is currently offline Axel MuellerFriend
That is an error message from the Eclipse static code analyzer CODAN (semantic error) not from the compiler. CODAN depends on a correct index about header files and symbols. The index seems to be incorrect in your case. Select your project and open the context menu. Select Index->Rebuild. This should fix your problem (usually the index is updated automatically).
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: new installation of eclipse-CDT does not understand C++ language [message #965601 is a reply to message #965438] Wed, 31 October 2012 11:12 Go to previous messageGo to next message
Axel,
Many thanks for helping.
Your trick did not worked.
I played around with options in the same menu, then found that inclusion of <iostream> was unresolved.
How can I fix this ?
[Updated on: Wed, 31 October 2012 11:13]
Report message to a moderator
Re: new installation of eclipse-CDT does not understand C++ language [message #971964 is a reply to message #965601] Mon, 05 November 2012 08:53 Go to previous message
Olivier Planchon wrote on Wed, 31 October 2012 12:12
Axel,
The include path for system headers like iostream should be found automatically by Eclipse. Did you select the correct tool chain (gcc) in Project Properties?
Before you ask
- search this forum
- google
Previous Topic:Missing "includes" item in Project Explorer (Juno)
Next Topic:Eclipse is unable to find the correct include path
Current Time: Sun Jan 21 02:45:54 GMT 2018
Powered by FUDForum. Page generated in 0.01481 seconds
