Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » problems running in standard mode.
problems running in standard mode. [message #136319] Thu, 25 September 2008 13:55 Go to next message
matt murphy is currently offline matt murphy
I'm having problems running the example
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-5-0.html#2.2.3
When i get to this step I experience the following error after the testbench
is launched to run the test? Any ideas? Do I need to start and agent
controller? The document mentions that i should not have to if I'm running
local. I'm able to run the quick mode without a problem.
thanks,
matt
  • Attachment: error2.JPG
    (Size: 137.34KB, Downloaded 189 times)
Re: problems running in standard mode. [message #136389 is a reply to message #136319] Fri, 26 September 2008 06:34 Go to previous messageGo to next message
Paul Slauenwhite is currently offline Paul Slauenwhite
Hi Matt,
You do not need the Agent Controller if you are running local. There is
an Integrated Agent Controller packaged as a set of Eclipse plug-ins in
TPTP. Is your location pointing to the local host? Can you attach your
project (zipped)?
Paul
"matt murphy" <murphy@coherentlogix.com> wrote in message
news:gbgjas$oss$1@build.eclipse.org...
> testbench is launched to run the test? Any ideas? Do I need to start and
> agent controller? The document mentions that i should not have to if I'm
> running local. I'm able to run the quick mode without a problem.
> thanks,
> matt
Re: problems running in standard mode. [message #136547 is a reply to message #136389] Tue, 30 September 2008 14:27 Go to previous messageGo to next message
Hi Paul,
thanks for the reply. If by local host you mean local_deployment in the run
configuration, yes it is. Is there another place that local needs
specified?
Do I need to add the agent controller to the path?
thanks,
matt
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:gbidsc$9kp$1@build.eclipse.org...
> Hi Matt,
> is an Integrated Agent Controller packaged as a set of Eclipse plug-ins in
> project (zipped)?
> Paul
>> thanks,
>> matt
Re: problems running in standard mode. [message #136571 is a reply to message #136547] Wed, 01 October 2008 06:31 Go to previous message
Hi Matt,
Yes, I was referring to the local_deployment in the launch
configuration. There is no need to install/configure the Agent Controller,
since the Integrated Agent Controller is used.
Are you using TPTP 4.5.0?
It appears that your TPTP installation is not correct. Can you try
reinstalling TPTP and the AGR, and restart Eclipse with the -clean flag? If
this step does not resolve your issue, please attach your project.
Paul
news:gbtr30$e3p$1@build.eclipse.org...
> Hi Paul,
> run
> specified?
> thanks,
> matt
>> Hi Matt,
>> in TPTP. Is your location pointing to the local host? Can you attach
>> your project (zipped)?
>> Paul
>>> Hi,
>>> I'm running local. I'm able to run the quick mode without a problem.
>>> thanks,
>>> matt
Previous Topic:profiling c/c++ applications
Next Topic:TPTP 4.5.1 is released!
Current Time: Tue May 21 18:08:20 EDT 2013
Powered by FUDForum. Page generated in 0.01488 seconds
