Home » Newcomers » Newcomers » Eclipse compilation without packages and project creation(Eclipse Beginner)
Eclipse compilation without packages and project creation [message #957867] Thu, 25 October 2012 15:03 Go to next message
geek bits is currently offline geek bitsFriend
Hi all !
This is my first post @ Eclipse and I am new to Eclipse. I am a beginner in Java. I had been using Edit Plus . I create .java files in Edit Plus and compile and run in the command prompt. I find this very convenient.
Though the same can be done in Eclipse too, but by default, I need to create a New Project and then Package and Class file and then creating .java files. Compiling and running can be done in Eclipse itself or in the command prompt.
I do not need project and packages as of now as I am beginner , I am trying to get comfortable in java by trying with lot of basic programs in java for which packages and projects not needed.
My question is : Can we create .java files without creating project and packages ( as I used to do in Edit Plus ) and save it and compile it in command prompt ?
Thanks & Regards
Geek Bits
Re: Eclipse compilation without packages and project creation [message #959169 is a reply to message #957867] Fri, 26 October 2012 13:56 Go to previous message
Russell Bateman is currently offline Russell BatemanFriend
On 10/26/2012 07:43 AM, geek bits wrote:
> Hi all !
> the command prompt.
> command prompt ?
> Thanks & Regards
> Geek Bits
The short answer is no. Eclipse organizes things into projects. You're
going to find the concept easier after you've done it. You can create a
single project and put all your sample code inside it to run and debug.
You'll see, it will save you a lot of time.
Use the simple Java Project.
Use this tutorial if you want no-brainer, easy to learn instruction:
http://www.vogella.com/articles/Eclipse/article.html
See
Previous Topic:Problem with displaying Doxygen documentation in the Eclipse Help
Next Topic:start tomcat in eclipse ...
Current Time: Mon Apr 23 04:07:33 GMT 2018
Powered by FUDForum. Page generated in 0.03310 seconds
