Home » Archived » Test and Performance Tools Platform (TPTP) » Can TPTP do this?
Can TPTP do this? [message #134344] Sat, 16 August 2008 16:06 Go to next message
Eric T is currently offline Eric TFriend
Hi All,
I am new to TPTP (referred by google :>). I wonder if TPTP can help me to
the following.
I have a C++ application which I would like to profile by just inserting
logs or traces. I want to record the execution call graph and the time it
take to run each function. xml file will be generated
I want to visualize this in TPTP. Call graph with hotspot, table of
functions sorted by time taken, filtering etc.
I am thinking about writing some extender of TPTP to read in the xml file
I created and somehow talk to the TPTP framework to tell it about the
execution and timing data.
Am I on the right track? Can TPTP do this?
Thanks!
Re: Can TPTP do this? [message #134360 is a reply to message #134344] Mon, 18 August 2008 17:16 Go to previous messageGo to next message
Eugene Chan is currently offline Eugene ChanFriend
Hi Eric,
Instead of extender to read in the xml file, you can log the information in
the XML4Trace format
( http://www.eclipse.org/tptp/platform/documents/resources/pro filingspec/XML4Profiling.htm)
which can then be imported as regular profile file to TPTP and be visualized
in TPTP tables and graphs.
To generate an example of profiling file, you can profile a Java application
with TPTP 4.4.1 and specify to send profile data to a file (under the
monitor tab of the profiling configuration). It's a zipped text file and you
can unzip it to inspect its content.
Eugene
"Eric" <ws1088@gmail.com> wrote in message
news:e0b639f88d2b387d01184adb41eb5260$1@www.eclipse.org...
> Hi All,
> the following.
> Thanks!
Re: Can TPTP do this? [message #134391 is a reply to message #134360] Mon, 18 August 2008 23:48 Go to previous messageGo to next message
Thanks, I think XML4Trace will work for me.
Is there a C++ library/API which I can use to generate this format?
Thanks!
Re: Can TPTP do this? [message #135214 is a reply to message #134360] Thu, 28 August 2008 21:32 Go to previous messageGo to next message
I tried Eugene's suggestion and profiled a sample java application. I got
a trcxml file and uncompress it and it has several .bin files (I assume
one .bin files represent one trace). However, I cannot uncompress the .bin
file.
Can you shed some light on how can I create my trcxml file with multiple
trace using C++ or perl (basically ASII). Thanks!
Re: Can TPTP do this? [message #135288 is a reply to message #135214] Sat, 30 August 2008 01:47 Go to previous messageGo to next message
Yunan, He is currently offline Yunan, HeFriend
Eric,
The bin file is in compressed XML format (it's called binary file). You
can find the definition by check the below link:
https://bugs.eclipse.org/bugs/attachment.cgi?id=89144
https://bugs.eclipse.org/bugs/attachment.cgi?id=93126
These two links are the attachments of Bugzilla 196713, you can also check
the discussion on compressed file format by checking link:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196713
Hope it helps.
Thanks.
Re: Can TPTP do this? [message #135849 is a reply to message #135288] Tue, 16 September 2008 14:11 Go to previous message
Hi Eric,
The source code for emitting trace XML fragments is in
org.eclipse.tptp.platform.jvmti.runtime/sec-native/src/JPIAg ent/PrintXML.cpp
(and PrintXML.h). It was not designed to be fully reuse butt take a look for
information on how to generate the events there.
Eugene
"Yunan, He" <yunan.he@intel.com> wrote in message
news:3978b90368aabf7c30607fadbfcc24d8$1@www.eclipse.org...
> Eric,
> Hope it helps.
> Thanks.
Previous Topic:profiling console application with TPTP - and nothing happens
Next Topic:language packs tptp 4.4
Current Time: Sat Feb 17 21:50:07 GMT 2018
Powered by FUDForum. Page generated in 0.01667 seconds
