Home » Archived » Visual Editor (VE) » Two files the same - 1 UI painter works the other doesn't
Two files the same - 1 UI painter works the other doesn't [message #134040] Sat, 09 December 2006 09:07 Go to next message
Eclipse User
Originally posted by: tim.nesham.geemail.com
I wrote some code in the same class that VE generated and the UI painter
does not recognize the class as a bean. I backed out my code and left what
VE generated and it still does not recognize my class as a bean, but it does
run fine. I then created a new VE class and the UI painter works. I now have
two files exactly the same, 1 the UI painter works the other doesn't. How
do I tell the UI painter, in this situation, that my class is a VE class?
See code and environment info below. I am curious as to what is the
difference?
I have started eclipse with -clean and run the clean menu option.
//Code
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Shell;
public class Test {
private Shell sShell = null ;
* This method initializes sShell
private void createSShell() {
sShell = new Shell();
sShell.setText("Shell");
sShell.setSize(new Point(300, 200));
sShell.setLayout(new GridLayout());
Environment information
*** Date: Sat Dec 09 07:42:13 CST 2006
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20060629-1905
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
804_74
-vm
C:\Program Files\Java\j2re1.4.2_12\bin\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1165668858328
eclipse.vm=C:\Program Files\Java\j2re1.4.2_12\bin\javaw.exe
eclipse.vmargs=-Duser.language=en
-Xms128M
-Xmx512M
-XX:PermSize=64M
-XX:MaxPermSize=128M
-Dosgi.splashLocation=C:\Program Files\MyEclipse\eclipse\MyEclipseSplash.bmp
-jar
C:\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse\startup.jar
java.class.version=48.0
java.endorsed.dirs=C:\Program Files\Java\j2re1.4.2_12\lib\endorsed
java.ext.dirs=C:\Program Files\Java\j2re1.4.2_12\lib\ext
java.home=C:\Program Files\Java\j2re1.4.2_12
java.io.tmpdir=C:\DOCUME~1\tnesham\LOCALS~1\Temp\
java.library.path=C:\Program
Files\Java\j2re1.4.2_12\bin;.;C:\WINDOWS\system32;C:\WINDOWS ;C:\Dev_Build\10g;C:\Ora92\bin;C:\Program
Files\IBM\WebSphere
MQ\Java\lib;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System 32\Wbem;C:\Program
Files\NetManage\Windows;C:\Program Files\IBM\WebSphere MQ\bin;C:\Program
Files\IBM\WebSphere MQ\WEMPS\bin;C:\Program
Files\Oracle\jre\1.3.1\bin;C:\Program Files\Oracle\jre\1.1.8\bin;C:\Program
Files\SlickEdit\win;C:\Program Files\QuickTime\QTSystem\;C:\Program
Files\SlickEdit\win
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_12-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_12
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_12-b03
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imag eio,javax.imageio.event,
javax.imageio.metadata,javax.imageio.plugins.jpeg,javax.imag eio.spi,javax.imageio.stream,javax.naming,javax.naming.direc tory,javax.naming.event,javax.naming.ldap,javax.naming.spi,j avax.net,javax.net.ssl
,javax.print,javax.print.attribute,javax.print.attribute.sta ndard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.secu rity.auth,javax.security.auth.callback,javax.security.auth.k erberos,javax.security.auth.login,javax.security.auth.spi
,javax.security.auth.x500,javax.security.cert,javax.sound.mi di,javax.sound.midi.spi,javax.sound.sampled,javax.sound.samp led.spi,javax.sql,javax.swing,javax.swing.border,javax.swing .colorchooser,javax.swing.event,javax.swing.filechooser
,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.me tal,javax.swing.plaf.multi,javax.swing.table,javax.swing.tex t,javax.swing.text.html,javax.swing.text.html.parser,javax.s wing.text.rtf,javax.swing.tree,javax.swing.undo
,javax.transaction,javax.transaction.xa,javax.xml.parsers,ja vax.xml.transform,javax.xml.transform.dom,javax.xml.transfor m.sax,javax.xml.transform.stream,org.ietf.jgss,org.omg.CORBA ,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable
,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.om g.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNa ming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNa ming.NamingContextPackage,org.omg.Dynamic
,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage, org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.Cod ecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging, org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBI nitInfoPackage
,org.omg.PortableServer,org.omg.PortableServer.CurrentPackag e,org.omg.PortableServer.POAManagerPackage,org.omg.PortableS erver.POAPackage,org.omg.PortableServer.portable,org.omg.Por tableServer.ServantLocatorPackage,org.omg.SendingContext
,org.omg.stub.java.rmi,org.w3c.dom,org.xml.sax,org.xml.sax.e xt,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\eclipse\configuration\org.eclipse.osgi\b undles
osgi.configuration.area=file:/C:/eclipse/configuration/
osgi.framework=file:/c:/eclipse/plugins/org.eclipse.osgi_3.2 .1.R32x_v20060919.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.1.R32x_v20060919
osgi.install.area=file:/C:/eclipse/
osgi.instance.area=file:/C:/eclipse/workspace/
osgi.instance.area.default=file:/C:/Documents and
Settings/tnesham/workspace/
osgi.logfile=C:\eclipse\workspace\.metadata\.log
osgi.manifest.cache=C:\eclipse\configuration\org.eclipse.osg i\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\j2re1.4.2_12\lib\rt.jar;C:\Program
Files\Java\j2re1.4.2_12\lib\i18n.jar;C:\Program
Files\Java\j2re1.4.2_12\lib\sunrsasign.jar;C:\Program
Files\Java\j2re1.4.2_12\lib\jsse.jar;C:\Program
Files\Java\j2re1.4.2_12\lib\jce.jar;C:\Program
Files\Java\j2re1.4.2_12\lib\charsets.jar;C:\Program
Files\Java\j2re1.4.2_12\classes
sun.boot.library.path=C:\Program Files\Java\j2re1.4.2_12\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium i486 i386
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\eclipse
user.home=C:\Documents and Settings\tnesham
user.language=en
user.name=TNesham
user.timezone=America/Chicago
user.variant=
vendor=Apache Software Foundation
vendor-url=http://xml.apache.org/xalan-j
version=2.4.1
*** Features:
org.eclipse.emf (2.2.1.v200609210005) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.2.0.v200609210005) "EMF Service Data Objects
(SDO)"
org.eclipse.gef (3.2.1.v20060921 ) "Graphical Editing Framework"
org.eclipse.jdt (3.2.1.r321_v20060905-R4CM1Znkvre9wC-) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.1.r321_v20060905-R4CM1Znkvre9wC-) "Eclipse Java
Development Tools SDK"
org.eclipse.jem (1.2.2.v20061027_M----6zXJJzM1TEVU) "Java EMF Model"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG ) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.1.r321_v20060921-b_XVA-INSQSyMtx) "Eclipse
Platform"
org.eclipse.platform.source (3.2.1.r321_v20060921-b_XVA-INSQSyMtx ) "Eclipse
Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse RCP"
org.eclipse.rcp.source (3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse RCP
org.eclipse.sdk (3.2.1.r321_v20060801-tQ1w49KnTArT0FZ) "Eclipse Project SDK"
org.eclipse.ve (1.2.1.v20060817_M-zXJUB0fxM0dxQdc) "Visual Editor"
org.maven.ide.eclipse.feature (0.0.9) "Maven 2.0 integration"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Resolved]
com.ibm.icu (3.4.5) "International Components for Unicode for Java (ICU4J)"
[Active]
com.ibm.icu.source (3.4.5) "International Components for Unicode for Java
(ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.1.r321_v20060828) "Ant UI" [Resolved]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism"
[Active]
org.eclipse.core.expressions (3.2.1.r321_v20060721) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File System
for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.1.R32x_v20060914) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource Management
Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601 )
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Active]
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.1.v20060823) "Debug UI" [Active]
org.eclipse.draw2d (3.2.1.v20060921) "Draw2d" [Active]
org.eclipse.emf (2.2.0.v200609210005) "Eclipse Modeling Framework (EMF)"
[Resolved]
org.eclipse.emf.ant (2.2.0.v200609210005) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.2.1.v200609210005) "EMF Template Code Generator"
[Resolved]
org.eclipse.emf.codegen.ecore (2.2.1.v200609210005) "EMF Ecore Code
Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200609210005) "EMF Ecore Code
Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200609210005) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.2.1.v200609210005 ) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.1.v200609210005) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0.v200609210005) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.1.v200609210005) "EMF Model Convert Support"
[Resolved]
org.eclipse.emf.ecore (2.2.1.v200609210005) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.0.v200609210005) "EMF Ecore Change Model"
[Active]
org.eclipse.emf.ecore.change.edit (2.2.0.v200609210005) "EMF Ecore Change
Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200609210005) "EMF Ecore Edit Support"
[Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200609210005) "Sample Ecore Editor"
[Resolved]
(SDO)" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200609210005 ) "EMF Service Data
Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200609210005) "EMF Service Data
Objects (SDO) Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.1.v200609210005 ) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.1.v200609210005) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.0.v200609210005) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter ( 2.2.0.v200609210005) "EMF Model Export Support"
[Resolved]
org.eclipse.emf.importer (2.2.1.v200609210005) "EMF Model Import Support"
[Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200609210005 ) "EMF Ecore Importer"
[Resolved]
org.eclipse.emf.importer.java (2.2.1.v200609210005) "EMF Annotated Java
Importer" [Resolved]
org.eclipse.emf.importer.rose (2.2.0.v200609210005) "EMF Rose Importer"
[Resolved]
org.eclipse.emf.mapping (2.2.0.v200609210005) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200609210005) "Ecore to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200609210005) "Ecore to
Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200609210005) "Ecore to XML
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200609210005 ) "Ecore to XML
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200609210005) "EMF Mapping UI" [Resolved]
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension Registry
Support" [Active]
org.eclipse.gef (3.2.1.v20060921) "Graphical Editing Framework" [Active]
org.eclipse.help (3.2.1.R321_v20060920) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server"
[Resolved]
org.eclipse.help.base (3.2.1.R321_v20060822) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.1.R321_v20060803) "Help System Webapp"
[Resolved]
org.eclipse.jdt (3.2.1.r321_v20060823) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing Core" [Installed]
org.eclipse.jdt.apt.ui (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing UI" [Installed]
org.eclipse.jdt.core (3.2.1.v_677_R32x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721 ) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.1.r321_v20060731) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.1.r321_v20060918) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.2.1.r321_v20060907) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java Development
User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools JUnit
support" [Active]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development Tools
JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.1.r321_v20060905) "Java Development
Tools JUnit4 runtime support" [Installed]
org.eclipse.jdt.launching (3.2.1.r321_v20060731) "Java Development Tools
Launching Support" [Active]
Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.1.r321_v20060907) "Java Development Tools UI"
[Active]
org.eclipse.jem (1.2.1.v20060918_M) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.2.2.v20061027_M) "Java EMF Model BeanInfo
(Introspection) Support" [Active]
org.eclipse.jem.proxy (1.2.0.v20060918_M) "Java EMF Model Proxy Support"
[Active]
org.eclipse.jem.ui (1.2.1.v20060918_M) "Java EMF Model UI" [Active]
org.eclipse.jem.util (1.2.1.v20060918_M) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.2.2.v20061027_M) "Java EMF Model Workbench
Support" [Active]
org.eclipse.jface (3.2.1.M20060908-1000) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding"
[Resolved]
org.eclipse.jface.text (3.2.1.r321_v20060810) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring Core"
[Active]
org.eclipse.ltk.ui.refactoring (3.2.1.r321_v20060726) "Refactoring UI"
[Active]
org.eclipse.osgi.services ( 3.1.100.v20060601) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.1.v20060810-0800) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.1.r321_v20060823) "Plug-in Development
Environment Build Support" [Resolved]
org.eclipse.pde.core (3.2.1.v20060915-0800) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) "Eclipse Plug-in Development
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605 ) "Plug-in Development Environment
Runtime" [Resolved]
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.0.v20060601) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.1.r321_v2006030) "Eclipse Platform Plug-in
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse Workbench
org.eclipse.platform.source (3.2.1.r321_v20060921-b_XVA-INSQSyMtx) "Eclipse
Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.2.1.r321_v20060921-b_XVA-INSQSyMtx) "Eclipse Platform Plug-in Developer
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.2.1.r321_v20060705) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Resolved]
org.eclipse.swt (3.2.1.v3235e) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.1.v3235) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.2.1.M20060711) "Team Support Core" [Active]
org.eclipse.team.cvs.core ( 3.2.1.M200608161750) "CVS Team Provider Core"
[Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I200606011710) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200606051140) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.1.M20060831) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.1.M20060913-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Active]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External Tools"
[Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.2.1.M20060915-1030) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.1.R321_v20060810) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal Welcome"
[Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800 ) "Common Navigator View"
[Resolved]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) "Navigator
Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation
Plug-in" [Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400 ) "Eclipse UI Win32 Enhancements"
[Resolved]
org.eclipse.ui.workbench (3.2.1.M20060906-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.2.1.v20092006) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.1.v20092006) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.1.v20092006) "Install/Update Core for
Windows" [Resolved]
org.eclipse.update.scheduler (3.2.1.v20092006) "Automatic Updates Scheduler"
[Active]
org.eclipse.update.ui (3.2.1.v20092006) "Install/Update UI" [Resolved]
org.eclipse.ve (1.2.0.v20060518_RC1) "Visual Editor" [Resolved]
org.eclipse.ve.cde ( 1.2.0.v20060918_M) "Visual Editor Common Data Editor"
[Active]
org.eclipse.ve.doc (1.2.0.v20060824_M) "Visual Editor for Java User Guide"
[Resolved]
org.eclipse.ve.java.core (1.2.1.v20060918_M) "Visual Editor Java Core"
[Active]
org.eclipse.ve.jfc (1.2.1.v20060918_M) "Visual Editor for Java Foundation
Classes" [Active]
org.eclipse.ve.propertysheet (1.2.0.v20060824_M) "Visual Editor
PropertySheet" [Active]
org.eclipse.ve.swt (1.2.1.v20060918_M) "Visual Editor for Standard Widget
Toolkit" [Active]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.junit4 (4.1.0.1) "JUnit Testing Framework Version 4" [Installed]
org.maven.ide.eclipse (0.0.9) "Maven 2.0 integration" [Active]
system.bundle (3.2.1.R32x_v20060919) "OSGi System Bundle" [Active]
*** User Preferences:
#Sat Dec 09 07:42:15 CST 2006
@org.eclipse.debug.ui=3.2.1.v20060823
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<templates/>
@org.eclipse.ui.ide=3.2.1.M20060915-1030
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.userLibr ary.SWTPLUGINS= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<userlibrary systemlibrary\="false"
version\="1">\r\n\t<archive
path\=" C\:/eclipse/plugins/com.ibm.etools.emf.event_3.0.0.v20060518 _RC1.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.maven.ide.eclipse_0.0.9.jar"/ >\r\n\t<archive
path\="C\:/eclipse/plugins/com.ibm.icu_3.4.4.1.jar"/>\r\n\t <archive
path\="C\:/eclipse/plugins/com.jcraft.jsch_0.1.28.jar"/>\r\n\t <archive
path\=" C\:/eclipse/plugins/org.eclipse.ant.core_3.1.100.v20060531.j ar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ant.ui_3.2.0.v20060531.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.compare_3.2.0.v20060605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.boot_3.1.100.v20060603. jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.commands_3.2.0.I2006060 5-
1400.jar"/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.contenttype_3.2.0.v2006 0603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.expressions_3.2.0.v2006 0605-
path\=" C\:/eclipse/plugins/org.eclipse.core.filebuffers_3.2.0.v2006 0605-1400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.filesystem.win32.x86_1. 0.0.v20060603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.filesystem_1.0.0.v20060 603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.jobs_3.2.0.v20060603.ja r "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.resources.compatibility _3.2.0.v20060603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.resources.win32_3.2.0.v 20060603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.resources_3.2.0.v200606 03.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.runtime.compatibility.a uth_3.2.0.v20060601.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.runtime.compatibility_3 .1.100.v20060603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.runtime_3.2.0.v20060603 .jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.variables_3.1.100.v2006 0605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.debug.core_3.2.0.v20060605.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.debug.ui_3.2.0.v20060605.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.draw2d_3.2.0.v20060626.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ant_2.2.0.v200606271057. jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.codegen.ecore.ui_2.2.0.v 200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.codegen.ecore_2.2.0.v200 606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.codegen.ui_2.1.0.v200606 271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.codegen_2.2.0.v200606271 057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.common.ui_2.2.0.v2006062 71057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.common_2.2.0.v2006062710 57.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.commonj.sdo_2.1.0.v20060 6271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.converter_2.2.0.v2006062 71057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.change.edit_2.1.0. v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.change_2.2.0.v2006 06271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.edit_2.2.0.v200606 271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.editor_2.2.0.v2006 06271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.sdo.edit_2.1.0.v20 0606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.sdo.editor_2.1.0.v 200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.sdo_2.2.0.v2006062 71057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.xmi_2.2.0.v2006062 71057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore_2.2.0.v20060627105 7.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.edit.ui_2.2.0.v200606271 057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.edit_2.2.0.v200606271057 .jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.exporter_2.2.0.v20060627 1057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.importer.ecore_2.2.0.v20 0606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.importer.java_2.2.0.v200 606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.importer.rose_2.2.0.v200 606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.importer_2.2.0.v20060627 1057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping.ecore2ecore.edit or_2.2.0.v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping.ecore2ecore_2.2. 0.v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping.ecore2xml.ui_2.2 .0.v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping.ecore2xml_2.2.0. v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping.ui_2.2.0.v200606 271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping_2.2.0.v200606271 057.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.emf_2.2.0.v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.equinox.common_3.2.0.v200606 03.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.equinox.preferences_3.2.0.v2 0060601.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.equinox.registry_3.2.0.v2006 0601.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.gef_3.2.0.v20060626.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.help.appserver_3.1.100.v2006 0602.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.help.base_3.2.0.v20060601.ja r "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.help.ui_3.2.0.v20060602.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.help_3.2.0.v20060602.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.apt.core_3.2.0.v20060602 -
1740.jar"/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.apt.ui_3.2.0.v20060602-1 740.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.core.manipulation_1.0.0. v20060605-
path\="C\:/eclipse/plugins/org.eclipse.jdt.core_3.2.0.v_671.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.debug.ui_3.2.0.v20060605 .jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.doc.isv_3.2.0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.jdt.doc.user_3.2.0.v20060605 -1400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.junit4.runtime_1.0.0.v20 060605-
path\=" C\:/eclipse/plugins/org.eclipse.jdt.launching_3.2.0.v2006060 5.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.ui_3.2.0.v20060605-1400. jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.jdt_3.2.0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.jem.beaninfo_1.2.0.v20060530 _RC2.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jem.proxy_1.2.0.v20060530_RC 2.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jem.ui_1.2.0.v20060518_RC1.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jem.util_1.2.0.v20060530_RC2 .jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jem.workbench_1.2.0.v2006053 0_RC2.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.jem_1.2.0.v20060530_RC2.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jface.databinding_1.0.0.I200 60605-
path\=" C\:/eclipse/plugins/org.eclipse.jface.text_3.2.0.v20060605-1 400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jface_3.2.0.I20060605-1400.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.2.0.v 20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.2.0.v20 060605-1400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.osgi.services_3.1.100.v20060 601.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.osgi.util_3.1.100.v20060601. jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.osgi_3.2.0.v20060601.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.pde.core_3.2.0.v20060605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.pde.doc.user_3.2.0.v20060605 .jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.pde.junit.runtime_3.2.0.v200 60605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.pde.runtime_3.2.0.v20060605. jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.pde.ui_3.2.0.v20060605.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.pde_3.2.0.v20060605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.platform.doc.isv_3.2.0.v2006 0612-
0900.jar"/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.platform.doc.user_3.2.0.v200 60605.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.rcp_3.2.0.v20060605.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.search_3.2.0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.swt.win32.win32.x86_3.2.0.v3 232m.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.swt_3.2.0.v3232o.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.core_3.2.0.I20060605114 0.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.cvs.core_3.2.0.M2006062 8.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.2.0.I2006060 51140.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.cvs.ssh_3.2.0.I20060601 1710.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.cvs.ui_3.2.0.I200606051 140.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.ui_3.2.0.I200606051140. jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.text_3.2.0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.browser_3.2.0.v20060602.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.cheatsheets_3.2.0.v200606 02.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.console_3.1.100.v20060605 .jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ui.editors_3.2.0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.externaltools_3.1.100.v20 060605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.forms_3.2.0.v20060602.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ui.ide_3.2.0.I20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.intro_3.2.0.v20060601.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.navigator.resources_3.2.0 .I20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.navigator_3.2.0.I20060605 -1400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.presentations.r21_3.2.0.I 20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.views.properties.tabbed_3 .2.0.I20060605-1400.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ui.views_3.2.0.I20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.win32_3.2.0.I20060605-140 0.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.2. 0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.workbench_3.2.0.I20060605 -1400.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ui_3.2.0.I20060605-1400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.update.configurator_3.2.0.v2 0060605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.update.core.win32_3.2.0.v200 60605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.update.core_3.2.0.v20060605. jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.update.scheduler_3.2.0.v2006 0605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.update.ui_3.2.0.v20060605.ja r "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ve.cde_1.2.0.v20060518_RC1.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ve.doc_1.2.0.v20060518_RC1.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ve.java.core_1.2.0.v20060620 _RC3.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ve.jfc_1.2.0.v20060620_RC3.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ve.propertysheet_1.2.0.v2006 0518_RC1.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ve.swt_1.2.0.v20060628.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ve_1.2.0.v20060518_RC1.jar "/>\r\n</userlibrary>\r\n
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13
,1155849257195" defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1155849257195" name\="j2re1.4.2_12" path\="C\:\\Program
Files\\Java\\j2re1.4.2_12"
javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api/"/>\r\n</vmType>\r\n</vmSettings>\r\n
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors version\="3.1">\r\n<info name\="*"
extension\="jpage">\r\n<editor id\="
org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info>\r\n <info name\="*"
extension\="genmodel">\r\n<editor
id\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel EditorID
"/>\r\n</info>\r\n<info name\="*" extension\="html">\r\n<editor
id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n <info name\="*"
extension\="override">\r\n<editor id\="
org.eclipse.jem.beaninfo.OverrideEditor"/>\r\n</info>\r\n <info name\="*"
extension\="ecore">\r\n<editor
id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n </info>\r\n<info
name\="sample" extension\="properties">\r\n<editor id\="
org.eclipse.pde.ui.sampleEditor"/>\r\n<defaultEditor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info name\="*"
extension\="ecore2xml">\r\n<editor id\="
org.eclipse.emf.mapping.ecore2xml.presentation.Ecore2XMLEdit orID "/>\r\n</info>\r\n<info
name\="*" extension\="htm">\r\n<editor
extension\="datagraph">\r\n<editor id\="
org.eclipse.emf.ecore.sdo.presentation.SDOEditorID"/>\r\n</info >\r\n<info
name\="*" extension\="xmi">\r\n<editor
id\="org.eclipse.emf.ecore.presentation.ReflectiveEditorID"/ >\r\n</info>\r\n<info
name\="*" extension\="jardesc">\r\n<editor id\="
org.eclipse.jdt.ui.JARDescEditor"/>\r\n<defaultEditor
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n <info name\="*"
extension\="ecore2ecore">\r\n<editor id\="
org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore EditorID "/>\r\n</info>\r\n<info
name\="*" extension\="shtml">\r\n<editor
id\="org.eclipse.ui.browser.editorSupport "/>\r\n</info>\r\n<info name\="*"
extension\="jar">\r\n<editor id\="WinZip File"/>\r\n<defaultEditor
id\="WinZip File"/>\r\n</info>\r\n<info name\="*"
extension\="class">\r\n<editor id\="C\:\\Program Files\\Cavaj Java
Decompiler\\cavaj.exe"/>\r\n<defaultEditor id\="C\:\\Program Files\\Cavaj
Java Decompiler\\cavaj.exe"/>\r\n</info>\r\n<info name\="*"
extension\="emof">\r\n<editor id\="
org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n</info >\r\n</editors>
@org.eclipse.pde.core=3.2.1.v20060915-0800
/instance/org.eclipse.ve.java.core/VISUAL_CLASS_WIZARD_SELEC TED_ELEMENT_KEY=
org.eclipse.ve.swt.cat-Shell-java.lang.Object
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
/instance/org.eclipse.pde.runtime/activate=true
@org.eclipse.ui.browser=3.2.0.v20060602
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
@org.eclipse.jdt.ui=3.2.1.r321_v20060907
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.resources=3.2.1.R32x_v20060914
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.help.ui/browser.y=0
/instance/org.eclipse.help.ui/browser.x=0
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.pde.core/platform_path=C\:\\eclipse
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
@org.eclipse.team.cvs.ui=3.2.1.M20060831
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.WAS_50_PLUGINDIR=C\:/Program
Files/WebSphere/AppServer
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.ui.workbench=3.2.1.M20060906-0800
@org.eclipse.ve.java.core=1.2.1.v20060918_M
file_export_version=3.0
@org.eclipse.jdt.launching=3.2.1.r321_v20060731
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
@org.eclipse.pde.runtime=3.2.0.v20060605
/instance/org.eclipse.help.ui/browser.h=738
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_SRC_HOME=C\:/eclipse/plugins/org.eclipse.jdt .source_3.2.1.r321_v20060905-R4CM1Znkvre9wC-/src/org.junit_3 .8.1
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/instance/org.eclipse.ve.java.core/PALETTE_WIDTH=125
/instance/org.eclipse.ui.ide/platformState=1165667813163
/instance/org.eclipse.ve.java.core/PALETTE_STATE=2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
@org.eclipse.ui.editors=3.2.1.r321_v20060721
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\ecl ipse\\workspace
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.userLibr ary.MEMBEREAR_LIBRARY=\#\# <cp
entry ignore>\#\#
/instance/org.eclipse.pde.runtime/orderType=2
/instance/org.eclipse.team.cvs.ui/pref_first_startup=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=C\:/eclipse/plugins/org.junit_3.8.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.RUNTIME_LIB=C\:/eclipse/plugins/org.eclipse.swt.wi n32.win32.x86_3.2.1.v3235.jar
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=C\:/Program
Files/Java/j2re1.4.2_12/lib/rt.jar
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=10
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.jdt.ui.override.decorator\:true,org.eclipse.jdt.ui.int erface.decorator\:false
,org.eclipse.pde.ui.binaryProjectDecorator\:false,org.eclips e.team.cvs.ui.decorator\:true,org.eclipse.ui.LinkedResourceD ecorator\:true,
@org.eclipse.jdt.core=3.2.1.v_677_R32x
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
@org.eclipse.search=3.2.1.r321_v20060726
/instance/org.eclipse.pde.runtime/orderValue=-1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<web-browsers current\="0">\r\n<system/>\r\n<external
name\="Internet Explorer" location\="C\:\\Program Files\\Internet
Explorer\\iexplore.exe"/>\r\n</web-browsers>
/instance/org.eclipse.ui.workbench/editors=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors>\r\n<descriptor label\="Scrapbook"
image\="$nl$/icons/full/obj16/jsbook_obj.gif" class\="
org.eclipse.jdt.internal.debug.ui.snippeteditor.JavaSnippetE ditor "
id\="org.eclipse.jdt.debug.ui.SnippetEditor"
plugin\="org.eclipse.jdt.debug.ui" openMode\="1" internal\="true"
open_in_place\="false"/>\r\n<descriptor label\="EMF Generator"
image\="icons/full/obj16/GenModelModelFile.gif" class\="
org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor "
id\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel EditorID "
plugin\="org.eclipse.emf.codegen.ecore.ui" openMode\="1" internal\="true"
open_in_place\="false"/>\r\n<descriptor label\="Web Browser"
image\="$nl$/icons/obj16/internal_browser.gif" launcher\="
org.eclipse.ui.internal.browser.BrowserLauncher"
id\="org.eclipse.ui.browser.editorSupport" plugin\="org.eclipse.ui.browser"
openMode\="4" internal\="false" open_in_place\="false"/>\r\n<descriptor
label\="Override Editor" image\="icons/full/obj16/file_obj.gif" class\="
org.eclipse.ui.editors.text.TextEditor"
id\="org.eclipse.jem.beaninfo.OverrideEditor" plugin\="org.eclipse.jem.ui"
openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor
label\="Sample Ecore Model Editor"
image\="icons/full/obj16/EcoreModelFile.gif" class\="
org.eclipse.emf.ecore.presentation.EcoreEditor"
plugin\="org.eclipse.emf.ecore.editor" openMode\="1" internal\="true"
open_in_place\="false"/>\r\n<descriptor label\="Code Sample Editor"
image\="$nl$/icons/obj16/build_exec.gif" class\="
org.eclipse.pde.internal.ui.samples.SampleEditor"
id\="org.eclipse.pde.ui.sampleEditor" plugin\="org.eclipse.pde.ui"
label\="Ecore to XML Mapping Editor"
image\="icons/full/obj16/Ecore2XMLModelFile.gif" class\="
org.eclipse.emf.mapping.ecore2xml.presentation.Ecore2XMLEdit or "
id\=" org.eclipse.emf.mapping.ecore2xml.presentation.Ecore2XMLEdit orID "
plugin\="org.eclipse.emf.mapping.ecore2xml.ui" openMode\="1"
internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Data Graph
Editor" image\="icons/full/obj16/SDOModelFile.gif" class\="
org.eclipse.emf.ecore.sdo.presentation.SDOEditor"
id\="org.eclipse.emf.ecore.sdo.presentation.SDOEditorID"
plugin\="org.eclipse.emf.ecore.sdo.editor" openMode\="1" internal\="true"
open_in_place\="false"/>\r\n<descriptor label\="Sample Reflective Ecore
Model Editor"
image\=" platform\:/plugin/org.eclipse.emf.edit/icons/full/obj16/Mode lFile.gif "
class\=" org.eclipse.emf.ecore.presentation.EcoreEditor"
open_in_place\="false"/>\r\n<descriptor label\="JAR Description Editor"
image\="$nl$/icons/full/obj16/jar_desc_obj.gif" class\="
id\="org.eclipse.jdt.ui.JARDescEditor" plugin\="org.eclipse.jdt.ui"
label\="Ecore to Ecore Mapping Editor"
image\="icons/full/obj16/Ecore2EcoreModelFile.gif" class\="
org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore Editor "
id\=" org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore EditorID "
plugin\="org.eclipse.emf.mapping.ecore2ecore.editor" openMode\="1"
internal\="true" open_in_place\="false"/>\r\n<descriptor label\="WinZip
File" file\="WinZip File" id\="WinZip File" openMode\="4" internal\="false"
open_in_place\="false" program_name\="WinZip File"/>\r\n<descriptor
label\="cavaj" file\="C\:\\Program Files\\Cavaj Java Decompiler\\cavaj.exe"
id\="C\:\\Program Files\\Cavaj Java Decompiler\\cavaj.exe" openMode\="4"
internal\="false" open_in_place\="false"/>\r\n</editors>
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.user_vie w_bindings= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<viewBindings>\r\n<view
id\="org.eclipse.ui.console.ConsoleView ">\r\n<perspective
id\="org.eclipse.team.cvs.ui.cvsPerspective"
userAction\="opened"/>\r\n<perspective
id\="org.eclipse.jdt.ui.JavaPerspective"
userAction\="closed"/>\r\n</view>\r\n</viewBindings>\r\n
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.pde.runtime/column4=150
/instance/org.eclipse.pde.runtime/column3=150
@org.eclipse.team.ui=3.2.1.M200608151725
/instance/org.eclipse.pde.runtime/column2=300
/instance/org.eclipse.search/org.eclipse.search.defaultPersp ective=org.eclipse.search.defaultPerspective.none
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.jdt.ui/MemberFilterActionGroup.org.ecl ipse.jdt.ui.JavaOutlinePage.4=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.M2_REPO=C\:/Documents
and Settings/tnesham/.m2/repository
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.SERVERJDK_50_PLUGINDIR=C\:/Program
Files/WebSphere/AppServer/java
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.userLibr ary.MemberEar= <?xml
version\=" 1.0" encoding\="UTF-8"?>\r\n<userlibrary systemlibrary\="false"
path\="C\:/eclipse/workspace/MemberEAR/xstream-1.1.2.jar"/ >\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/aopalliance- 1.0.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/AR_IDL.jar"/>\r\n\t <archive
path\="C\:/eclipse/workspace/MemberEAR/bcmail-jdk13-133.jar "/>\r\n\t<archive
jdk14-133.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/bcprov-jdk13-133.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/benefit-adapters-0.7.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cadre_fw.jar"/>\r\n\t <archive
path\="C\:/eclipse/workspace/MemberEAR/carrier-
service-1.1.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cbc-benefit-client-5.0.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cbc-claim-client-12.0.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cbcDrugClient_6.0.1.jar "/>\r\n\t<archive
eligibility-4.0.jar"/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-eligibility-client-4.0.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-mail-order-client-9.0.0. 1.jar
"/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-mail-order-site-locator- client-2.3.jar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-member-locator-client-5. 0.jar
"/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-member-materials-client- 5.0.jar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-message-tracking-client- 1.6.jar "/>\r\n\t<archive
osf-client-2.3.0.2.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cbc-pharmacy-client-3.0.jar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-prescriber-client-4.0.ja r
"/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-price-check-client-2.0.j ar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cbc-shared-2.3.jar"/ >\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cglib-
full-2.0.2.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/claim-adapters-1.4.jar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/claim-router-adapters-0.6.ja r "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/client-
hierarchy-1.5.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cmt-client-service-1.1.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/com.ibm.mq-1.0.jar"/ >\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/com.ibm.mqbind.jar"/ >\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/com.ibm.mqjms-
path\="C\:/eclipse/workspace/MemberEAR/common-deprecated-1.1.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/common-legacy-1.1.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/commonLogonSupport-
0.6.1.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/common-model-1.0.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/common-persistence-1.5.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/commons-
beanutils-1.6.jar"/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/commons-beanutils-core-1.7.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/commons-collections-2.1.1.ja r
"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/commons-digester.jar "/>\r\n\t<archive
Re: Two files the same - 1 UI painter works the other doesn't [message #134050 is a reply to message #134040] Sat, 09 December 2006 16:14 Go to previous messageGo to next message
Eclipse User
> difference?
> //Code
> public class Test {
snip...
When you say that the UI painter doesn't work do you mean that when you
open up the file you only see the Java editor and no gui display? If
so, you have probably opened the .java file with the Java editor and not
the Visual editor.
Close the file .java file for the class that isn't working. Right click
on the file in the Navigator/Type explorer. Select Open With... and
select Visual Editor from the menu.
Eclipse remembers the last editor that was used to open a specific file.
Re: Two files the same - 1 UI painter works the other doesn't [message #134062 is a reply to message #134050] Sun, 10 December 2006 16:47 Go to previous message
Eclipse User
That was it, thanks.
Tim
"David Wegener" <wegener@cboenospam.com> wrote in message
news:elf8vh$1vh$1@utils.eclipse.org...
> open up the file you only see the Java editor and no gui display? If so,
> you have probably opened the .java file with the Java editor and not the
> Visual editor.
Re: Two files the same - 1 UI painter works the other doesn't [message #614850 is a reply to message #134040] Sat, 09 December 2006 16:14 Go to previous message
David Wegener is currently offline David Wegener
> difference?
> //Code
> public class Test {
snip...
the Visual editor.
Re: Two files the same - 1 UI painter works the other doesn't [message #614852 is a reply to message #134050] Sun, 10 December 2006 16:47 Go to previous message
Eclipse User
Tim
> Visual editor.
Previous Topic:installation problem
Next Topic:installation problem
Current Time: Tue Oct 08 08:14:10 EDT 2013
Powered by FUDForum. Page generated in 0.08159 seconds
